[Solved] Amica ZWM 676S - Dishwasher Does not start, salt and rinse aid LEDs are flashing
LeszekTE 31689 10
Why does an Amica ZWM 676S dishwasher turn on ECO, beep once, and then alternately flash the salt and rinse aid LEDs without starting a wash cycle?
The thread points to a control/module fault rather than a salt or rinse-aid problem, so first check the door wiring and the anti-flood sensor [#16785395] [#16793021] One reply recommends removing the door fronts and casing, tipping the dishwasher onto its back, taking off the bottom tray, and testing the door-connection cable for breaks or shorts to ground with a meter [#16785395] Amica service also reportedly diagnosed the symptom as a module problem and предложили a module replacement, while the owner suspected the module capacitors [#16793021] A different user with the same model got the dishwasher working again by resetting the programmer: hold the switch, program-selection, and start buttons simultaneously until the Eco program starts [#16833132]
  • Alternating salt and rinse aid LEDs indicate a fault code
    #1 16774711
    LeszekTE
    Rate: 9
    I have a problem with the Amica ZWM 676 S dishwasher. After starting, it turns on the ECO indicator, makes a single squeak, then blinks alternately with the salt and rinse aid level indicators. How she behaves can be seen in the video below: [film: a1bacda853] https://filmy.elektroda.pl/85_1508661555.mp4 [/ film: a1bacda853] What's wrong with her?
    Due to the fact that my nicer half is pushing, I will gladly order the repair of this dishwasher. Maybe someone from Dear Colleagues wants to take up?
    The dishwasher is in Sosnowiec.
  • #2 16774847
  • #3 16784175
    LeszekTE
    Rate: 9
    No, it is dry inside, and the outflow and inflow are unobstructed. Salt and rinse aid were topped up and I checked also the contactors in the door handle are OK.
  • #4 16785395
  • #5 16789434
    LeszekTE
    Rate: 9
    In the "door handle": there are contactors - two pieces. So that the dishwasher "knows" if it has a locked door. I checked all cables
  • #6 16793021
    LeszekTE
    Rate: 9
    Yesterday, a nice lady from Amica service contacted me - 4 days after reporting the failure. She proposed a technician visit (for PLN 170) and a module replacement for only PLN 370. She confirmed that what you can see in the video is a problem with the module, but somehow I couldn't decide to repair it at this price. Still looking for someone to repair. I suspect replacing the capacitors will solve the problem.
  • #7 16833132
    mario 2506
    I had the same problem in the same Amica ZWM476S model. After several interrupted washing cycles (no power - accidentally pressing the button). I reset the dishwasher (programmer) please press and hold the buttons: switch - program selection - start all 3 simultaneously. After that the Eco program started and the dishwasher was working. I hope it works, too, because the cost of the programmer is half the price of the dishwasher.
    Good luck
  • #8 16998872
    martynmody
    Rate: 12
    Hello, I have the same problem as Leszek, I asked for help, I replaced the programmer and it is still the same, alternately flashing salt and rinse aid, I cordially greet and wait for answer
  • #9 17124595
    Michał_J
    Rate: 10
    I have a question for my colleagues - how did this failure end because I have a similar problem in the same model of the dishwasher only apart from the salt level and rinse aid indicator lights flashing, the rinsing program indicator lights up for a moment.
  • #10 18952285
    motyll747
    Hello, and someone solved this problem? Because I have the same. greetings
  • #11 19677553
    LeszekTE
    Rate: 9
    After unplugging for 40 days and restarting, the dishwasher works as if nothing ever happened. More than six months now. Magic?
The Amica ZWM 676 S dishwasher is experiencing a malfunction where it fails to start, indicated by the ECO light turning on and the salt and rinse aid LEDs flashing alternately. Users suggest checking for internal flooding, inspecting door connection cables for damage, and verifying the functionality of contactors in the door handle. One user reported a similar issue with the Amica ZWM 476 S model, which was resolved by resetting the programmer. A service technician from Amica proposed a visit and module replacement, indicating a potential module failure. Other users have also reported similar problems, with some having replaced the programmer without resolving the issue.
