Amica ZWM 436WD Dishwasher: Glass Indicator Flashing and Appliance Not Functioning
Szymon2001 42576 9
Why is the glass indicator flashing and my Amica ZWM436WD dishwasher not starting or working properly?
The dishwasher is likely in flood-protection mode because water has collected in the drip tray under the machine, not inside the tub [#17802474] Tilt the empty dishwasher heavily backwards or to the side as a test to let the water drain out; if it starts working again afterward, that confirms the issue [#16319108][#17802529] This is only a temporary fix, because the fault will return after a wash if there is still a leak [#17802759] If that happens, you need to find the leak and repair it, or call service if the unit is under warranty [#17802759][#16319108]
  • #1 16318713
    Szymon2001
    Hello, I recently bought an amica ZWM436WD dishwasher glass indicator. Please help . Even the dishwasher does not want to work. Urgent !
  • #2 16319108
    guciq
    Help: 24
    Rate: 134
    Take a small test - tilt the empty dishwasher heavily to the side. If the water comes from below, clean it and try running the program again. If it happens often, you will need to check where it is coming from
  • #3 16319229
    Lodxx
    Home appliances specialist
    Help: 105
    Rate: 245
    Yes, and after such a test, throw the dishwasher in the trash, pour the pump or electronics by accident. If everything was okay and you have a guarantee, call the service let them do it.
  • #4 17802304
    i780
    Rate: 47
    I have a similar problem, but with the ZWM 636WD dishwasher - the theme author's model is probably twin (narrower). After pressing the switch the ECO program indicator lights up, in a moment it jumps on the glass itself, blinks, squeaks and pumps out water several times. The program cannot be changed, only the switch button responds. I disconnected from the network for a few minutes, I did a reset with a combination of buttons: switch + program selection + start and nothing.
  • #5 17802318
  • #6 17802386
    i780
    Rate: 47
    There's no water.
  • #7 17802401
  • #8 17802474
    Chupacabra
    Help: 247
    Rate: 868
    Robo-technical wrote:
    Check if water is standing below in the floor
    i780 wrote:
    There's no water.
    Just look for this water in the drip tray under the dishwasher compartment and not inside.
  • #9 17802529
    i780
    Rate: 47
    The flood sensor was a good lead. I don't know where he is, but I did a little googling and the fastest thing I could do was to spill any water by tilting the dishwasher backwards. So I did, some water leaked and the dishwasher was working. Thank you
    Writing a post about lack of water, of course, I was looking for it inside the dishwasher :oops:
  • #10 17802759
    Chupacabra
    Help: 247
    Rate: 868
    What you did was, of course, an ad hoc act. If there is a leak, the fault will come back after one wash. Then you need to identify the location of the leak and remove it or call the service.
The Amica ZWM 436WD dishwasher is experiencing issues with a flashing glass indicator and non-functionality. Users suggest performing a tilt test to check for water accumulation beneath the appliance, which may indicate a leak. If water is found, it should be cleaned out to restore functionality. Other users have reported similar problems with the ZWM 636WD model, noting that the ECO program indicator lights up but fails to operate correctly. Troubleshooting steps include checking the flood sensor, solenoid valve contacts, and ensuring the flow meter is functioning. If problems persist, contacting service support is recommended, especially if the appliance is under warranty.
