Shore Rubber Hardness Scale for Elements in Tape Recorders, Photocopiers & Printers: Source?
bieganie 7938 7
  • #1 16775348
    bieganie
    Rate: 20
    I am looking at what scale of rubber hardness (Shore scale) rubber elements are produced, rolls, belts, idlers, in tape recorders, photocopiers, printers, etc. Anyone have a source?
  • #2 16775473
    telecaster1951
    Help: 829
    Rate: 818
    Can you explain what exactly you mean? Because I have no idea what you're asking.
  • #3 16775483
    niewolno2
    Level 40  
    Help: 628
    Rate: 1258
    Maybe you mean composition of rubber and hence its hardness, abrasion resistance as well as temperature resistance and various types of chemistry.
  • #4 16775825
    bieganie
    Rate: 20
    I don't know what's wrong with this question? Since I am asking the question about the hardness of rubber used in the production of elements used in electronics, it is implicitly known that, among other things, the consumption of material is the result of operation in various conditions.
  • #5 16775938
    telecaster1951
    Help: 829
    Rate: 818
    bieganie wrote:
    according to what scale of rubber hardness (Shore scale) rubber elements are produced
    Read and understand what is wrong. You ask according to what hardness scale, then you write according to the Shore scale.
    Your question is difficult to answer. All rubber strips have a hardness adapted to the specific application. The belt working with steel wheels will have different hardness and plastic wheels with different hardness. If a soft strap of 95 was used for soft polyamide, then the polyamide would wear off. If a steel hardness belt were attached to a steel wheel, the belt would end. It is difficult to answer your question.
  • #6 16776115
    bieganie
    Rate: 20
    Well, I have noticed that I am sorry. Returning to the wear of the rubber, I guess it uses differently depending on what it wipes. Asking a question I hoped that someone from the forum worked in the production of the above elements, or somewhere saw some exact table. Factories probably have them.
  • #7 16776164
    telecaster1951
    Help: 829
    Rate: 818
    Factories do not have. And if they have, they are confidential documents.
    V-belts for cars have a hardness of over 90 degrees (D) belts on plastic wheels for 3d printers, small CNC milling machines etc. is about 80 (C). How much exactly nobody will say. It is not just hardness that matters. The composition of the mixture also. Why did Stomil's stripes fall after 1000km and Pirelli stuck and 100,000? The hardness was similar, but the Polish mixture crumbled after half a year and the Italian one after 10 years was flexible.
  • #8 16776233
    bieganie
    Rate: 20
    As your knowledge is confirmed, that printer and cutter. CNC have about 80 this is also information. Generally, I meant it, assuming printing. 3d needs a lot of time for printing, this load, e.g. in a tape deck drive, where there are also rubber rollers and the assumed working time of the device, let's say similar, it can be assumed that the hardness of rubber elements is similar.
    I know that rubber is uneven
The discussion revolves around the Shore hardness scale of rubber components used in tape recorders, photocopiers, and printers. The original inquiry seeks specific information on the hardness levels of rubber elements such as rolls, belts, and idlers. Responses highlight the complexity of the question, noting that rubber hardness varies based on application and material composition. For instance, V-belts for cars typically exceed 90 degrees (D), while belts for plastic wheels in 3D printers and CNC machines are around 80 degrees (C). The conversation emphasizes that hardness alone does not determine performance; the rubber mixture's composition is also crucial. The author expresses a desire for a definitive source or table of hardness values used in manufacturing these components.
