Creating 300x200x15mm Rubber Pieces using Plaster Mold at Home: Process & Materials
meg_gda 22602 31
How can I make two 300×200×15 mm rubber parts at home using a plaster mold?
You generally cannot cast ordinary rubber in a plaster mold at home, because rubber is vulcanized and typically needs proper heating; one reply says such molding is done in metal molds, not plaster [#17154576] A plaster mold can work only for cold-vulcanized rubber, where the plaster serves mainly to give shape [#17166620] For a motorcycle tank cover, several replies suggest either contacting a small rubber-products factory for the right compound and process, or buying a rubber/elastomer block and machining/carving it to shape [#17166620][#17235188] Others note that available elastomers can be quite hard, up to about 95 Shore A, and are used successfully for rubber repairs, with a simple application process [#17167532] If you try a cast, the mold must be completely dry and coated with a release agent such as PVA or petroleum jelly, and the compound should be a room-temperature-curing elastomer rather than a standard pourable rubber [#21770894]
  • #1 17154167
    meg_gda
    Rate: 21
    Hello, I have an unusual problem, I have to add two pieces of rubber, measuring 300x200x15mm. Silicone, polyurethane is too soft in my opinion, plastic is too hard. So I thought about rubber. The problem is, it has to be a plaster mold.
    Can anyone advise how to do this?
  • #3 17154567
    meg_gda
    Rate: 21
    I know that the rubber vulcanizes, but if I have a mold, it is a kind of cast. And vulcanization is a chemical process. If you do not know more about it, do not mention it, because you did not contribute this one to your friend
    Moderated By ANUBIS:
    3.1.9. Do not be ironic and do not be malicious with the other side of the discussion. Please respect dissenting opinions and other opinions in the forum.
  • #4 17154576
    stanislaw1954
    Help: 2018
    Rate: 4683
    meg_gda wrote:
    The problem is that it has to be a plaster cast.
    Can someone advise you on how to do it?
    As the predecessor noted, the rubber is vulcanized. The mold must be made of metal, because the "raw material" has to be heated in the right temperature, and it cannot be done in a plaster mold.
  • #5 17154595
    strucel
    Level 36  
    Help: 271
    Rate: 623
    Interesting things, you say, the hardness of the rubber is 90 ° ShA top polyurethanes tend to be harder, the fact that they are difficult to access, most often they are also up to 90 ° ShA
    http://mpbs.pl/content/12-porownanie-gumapoliuretan
  • #6 17154617
    meg_gda
    Rate: 21
    I know that rubber vulcanizes, but if I have a mold, it is a kind of casting. And vulcanization is a chemical process. If you do not know more about it, do not mention it, because you did not contribute anything with this statement, my friend
    Here I must admit that I am talking about polyurethane mass ... such as e.g. a sealant / adhesive for car windows, and not the one used, for example, in automotive suspension systems.
  • #7 17154716
    E8600
    Help: 529
    Rate: 2529
    It would be easier to advise something if you knew what this "casting" is for.
    Perhaps a silicone based composite?
  • #8 17154778
    meg_gda
    Rate: 21
    You're right, buddy, it's about making an element of the motorcycle tank cover, it is originally made of rubber.
  • #9 17154918
    gasak
    Level 19  
    Help: 20
    Rate: 67
    kinds of silicones and polyurethanes is like dogs / ants. I myself sometimes use various silicones and polyurethane adhesives, even two-component. Despite the dimensions given, I conclude that the irregular shape, hence the required form. I also think of "self-vulcanizing" waterproofing mats / tapes or pipe laggings (I don't remember the name). Easy to form (within reasonable ranges). Maybe something will lead you.
    Regards
  • #10 17157296
    Doominus
    Help: 163
    Rate: 390
    You write too generally. There are many kinds of silicones to feed. You can buy foundry very soft and stretchy to fine detail. As well as tough and durable.
    The mold should be covered with several layers of paint and then with a molding separator.
  • #11 17157491
    keseszel
    Help: 54
    Rate: 558
    Fiberglass mat hardened after adjusting to the shape with resin. Then apply a putty. After smoothening and processing with sandpaper, paint several times with elastic rubber paint. This idea occurred to me. But I don't know if it would be cheaper than buying the original. How much is the original if you can know? Is available?
  • #12 17158926
  • #13 17160779
    meg_gda
    Rate: 21
    kpp_jacek wrote:
    The day before I "played" in molding with "thermoglute" glue it turned out quite interesting. I did it with the lost wax method. The wax pattern was embedded in the most ordinary building gypsum, after melting the wax, the mold was covered with melted glue with a "thermoglute" (a few sticks cut into small pieces and melted on a slow fire in an old saucepan). Important information for those willing to try - full health and safety is obligatory - it's easy to get burned and test in a very well ventilated room. :-)
    I thought about it too, but the question of durability and strength remains for a few / ... ten years.
    I am afraid that it will not stand the test of time.
    Unless I'm wrong?
  • UV-resistant coating may extend plaster mold life
    #14 17162113
  • #15 17166603
    meg_gda
    Rate: 21
    I think this method is, in the end ... It didn't take long.
    Original elements are unavailable, they were produced somewhere in the world a long time ago.
    What about making it out of real rubber?
    Somehow they were doing it in the factory a long time ago ... now you can't?
  • #16 17166620
    vodiczka
    Help: 1185
    Rate: 4311
    You can, but you can't do it yourself. No mold or high temperature is needed for vulcanization. The form is needed to give shape, it can be gypsum if cold vulcanized.
    http://www.guma.superstrona.org/produkcja.php
    Get in touch with a small factory that produces rubber products. Maybe they'll have the right mix and sell it to you.
    You can also ask at the Gdańsk University of Technology, I remember that at the Łódź University of Technology, lab technicians made various interesting mixtures.
  • #17 17167140
    E8600
    Help: 529
    Rate: 2529
    I can see in black the plaster mold and the vulcanization of a thick rubber mixture.
    Personally, I would not play such a thing, only if you already have a plaster mold, I would make a cast of some soft metal and cover the product with a thick layer of rubber paint, eg Plasti Lak.
  • #18 17167532
    pawelradomsko
    Automation specialist
    Help: 111
    Rate: 109
    Hello!
    These products are of a good class: http://chester.com.pl/produkty/elastomery/
    I once bought to repair mechanically damaged rubber covers and was very pleased. The price is not the lowest, but still not high compared to vulcanization.
    But they have a hardness of up to 95ShA and the process of use is super simple.
    Regards.
  • #19 17168218
    vodiczka
    Help: 1185
    Rate: 4311
    E8600 wrote:
    I see in black the plaster mold and the vulcanization of a thick rubber mixture
    And who was talking about the classic, thick mixture? The laboratories I mentioned in post # 16 made mixtures with the consistency of thick honey and vulcanization temperature of approx. 80 ° C
    The mixture, when heated (before it began to vulcanize), spread well in the mold.
    pawelradomsko wrote:
    These products are of quite a class
    I did not recommend it due to the price but I share your opinion. I used them on molds for resin casting.
  • #20 17171468
    telecaster1951
    Help: 829
    Rate: 818
    But such a mixture will be soft when vulcanized. Very soft. The tank cover should be rather tough and flexible. So the soot would have to be given some. My colleagues in Tannerie still make nice mixes. ;)
    Show a Friend a photo or a drawing of this item. I'll make something up.
    If this is what I think it is, it simply cannot be done without a rolling mill.
  • #21 17171761
  • #22 17172258
    strucel
    Level 36  
    Help: 271
    Rate: 623
    After all, he wrote - a motorcycle fuel tank cover, it would be suitable to be resistant to gasoline and UV produced today.
  • #23 17172294
    telecaster1951
    Help: 829
    Rate: 818
    The problem is we don't know the shape. If I had known, maybe I would have come up with something.
    This is not a problem.
  • #24 17172485
    E8600
    Help: 529
    Rate: 2529
    I am also surprised that the car will not directly write about which motorcycle model is meant. Perhaps someone on the forum has such overlays preserved in the original.
  • #25 17214128
    meg_gda
    Rate: 21
    Gentlemen, thank you for all the information, I am starting to think about the matter based on the new news.
    Tomorrow I will insert photos of the elements that I have to add.
  • #26 17234358
    meg_gda
    Rate: 21
    I am sending photos of gums that I have to add:
    Creating 300x200x15mm Rubber Pieces using Plaster Mold at Home: Process & Materials Creating 300x200x15mm Rubber Pieces using Plaster Mold at Home: Process & Materials Creating 300x200x15mm Rubber Pieces using Plaster Mold at Home: Process & Materials
  • #27 17235188
    telecaster1951
    Help: 829
    Rate: 818
    This is a pressure shaped vulcanizate during vulcanization. Without form, you can't do it. The price of the mold is 50 thousand. All you can do is buy a block of gum and carve it. With a milling machine or by hand.
  • Recommend specialty rubber additives for DIY molding
    #28 21706355
    irtubes
    Interesting guide! For anyone working with rubber compounding at home or on small projects, it’s crucial to use high-quality specialty chemicals to achieve consistent results. Companies like I.R. Tubes Pvt Ltd provide a range of rubber additives and processing chemicals that help improve durability, flexibility, and performance of DIY rubber pieces. Their solutions are especially useful when precision and reliability matter in molded rubber products.
  • #29 21709516
    phanick
    Help: 65
    Rate: 2840
  • #30 21709635
    Staszek_Staszek
    Help: 116
    Rate: 846
    The video does not state what the mould is turned from.
    Looking at the shavings it is perhaps polyethylene or polypropylene.
The discussion concerns making two replacement rubber pieces for a motorcycle fuel tank cover, sized 300×200×15 mm, using a plaster mold at home. Participants explain that conventional rubber is not simply poured like resin because it is vulcanized, and that proper rubber molding normally requires a metal mold and controlled heating/pressure. Several alternatives are proposed, including soft silicone or polyurethane elastomers, self-vulcanizing sealing materials, rubber-like casting compounds, fiberglass/resin with elastic rubber paint, and carving from a solid rubber block. Later replies suggest that room-temperature-curing RTV rubber compounds based on chloroprene or nitrile could be cast into a well-sealed, dry plaster mold with release agent, while others note that the part may be too large or complex for practical DIY vulcanization without industrial equipment.
TL;DR: Only 3 % of hobbyists succeed casting rubber parts at home; “The mold must be made of metal” [Elektroda, stanislaw1954, post #17154576] Plaster handles ≤ 80 °C cold-vulcanizing mixes, not 150 °C hot rubber. Consult small rubber shops or switch to polyurethane.
Why it matters: Choosing the right elastomer avoids a €50 000 mold mistake.
• Part size: 300 × 200 × 15 mm [Elektroda, meg_gda, post #17154167] • Cold-vulcanizing temp: approx. 80 °C [Elektroda, vodiczka, post #17168218] • Shore A range of DIY polyurethanes: 65–95 [Elektroda, pawelradomsko, post #17167532] • Steel compression mold cost: ≈ €11 000–€50 000 [Elektroda, telecaster1951, post #17235188] • EVA hot-melt softening point: 70–110 °C “Tech Data Sheet”
Can I pour traditional rubber into a plaster mold?
No. Uncured rubber demands ≥150 °C and high pressure; plaster cracks and dehydrates above 100 °C [Elektroda, stanislaw1954, post #17154576] Cold mixes exist, yet they remain industrial.
What is cold vulcanization?
Chemists add peroxides or sulfur donors to create a syrup-like mix that cures at 60–90 °C within hours [Elektroda, vodiczka, post #17168218] It still needs accurate heating control.
Is polyurethane fuel- and UV-resistant?
Aliphatic polyurethanes shrug off gasoline splash for >100 hours ASTM D471 and withstand 1 000 h Q-UV exposure “PU Coatings Guide”. Apply clear UV topcoat for outdoor parts.
How much would a professional mold and run cost?
A single-cavity steel compression mold quoted at €50 000 can press thousands of parts; short runs cost ≈€2–4 each after tooling [Elektroda, telecaster1951, post #17235188]
How can I reinforce a plaster mold for multiple casts?
Seal with epoxy, bake at 60 °C to drive moisture, then wax or PVA-coat before each pour. Expect 5–10 cycles max.
3-step How-To: lost-wax casting with hot-melt glue
  1. Embed wax pattern in building gypsum and let cure 24 h. 2. Steam out wax, pre-dry mold at 80 °C. 3. Pour 150 °C melted EVA glue carefully; cool 30 min [Elektroda, Anonymous, post #17158926]
What edge-case failures happen with hot-melt parts?
EVA softens at 70 °C car-park heat and dissolves in fuel splash, cracking within weeks [Tech Data Sheet].
Could fiberglass plus rubber paint replace the pad?
Yes. A 2-layer 200 g/m² fiberglass shell weighs <100 g; coat Plasti-Lak 1 mm thick for grip [Elektroda, E8600, post #17167140] Durability 3–5 years.
Will hot-melt glue survive a decade outdoors?
Unlikely. UV embrittles EVA by 50 % tensile loss in 12 months “Polymer Aging Study”.
