Beko RCNE365E40X - What is this error? The fridge despite the error still works
viper111 25149 3
  • #1 16777653
    viper111
    Rate: 389
    the Beko RCNE365E40X fridge was repaired - the integrated circuit on the fridge (board) was replaced with an identical one and the compressor chip (board) was replaced with a very similar, almost identical one.
    Everything worked well and here suddenly after a few days an error came out.
    Interestingly, the fridge still works nicely, cools.
    The question is what is this error?
    Beko RCNE365E40X - What is this error? The fridge despite the error still works Beko RCNE365E40X - What is this error? The fridge despite the error still works
  • #2 16778258
    Piotr2608
    Help: 851
    Rate: 4487
    E4 Defrost heater failure
    If defrost time is equal to the maximum defrost time of 60min. for 3 consecutive defrosts this error is shown. Control runs defrost heater normally.
    Check wiring
    Check defrost heater for continuity
    Check module
    ZimTech Piotr Zimny
  • #3 16779041
    jaszczur1111
    Help: 173
    Rate: 494
    Although it works temporarily, if the defrost heater does not work, after a few days you will notice it.
  • #4 16782545
    viper111
    Rate: 389
    Thanks for the hint.
    Does anyone have the opportunity to check what exactly the model of the compressor control board should be? I have Embraco VCC3 ... but not original. The original fridge was broken (I have no way to check).
