Evobox PVR Decoder and Digital Polsat Decoder - Unexpected Shutdown on 19 Blaupunkt TV
kamyyyyl 11421 2
  • #1 16976163
    kamyyyyl
    Level 4  
    I tried to connect my Polsat digital decoder today, after installing the antenna, etc. ... the time has come for the first installation of evobox.
    Everything is elegantly connected, the antenna is set up by eye, I start the decoder where I set the appropriate HDMI input before, after turning on the decoder, the first installation menu appears and in a moment the TV together with the decoder turn off. Initially, I thought it might be the resolution, so I switched to my TV, the decoder to the smallest resolution because my friend's TV is probably 19 "and nothing is the same, everything works fine on my TV, on another small TV, probably only 19 inches works only and only the decoder turns off together with the TV on a friend's TV. In addition, I combined in the menu with the exception of HDMI CEC. I do not know the exact model of this TV I know that it is Blaupunkt and rather certainly 19 "
  • #2 16976447
  • #3 16985555
    kamyyyyl
    Level 4  
    Only now, I was able to find some time and jump to my friend. Tv to, blaupunkt BLAUPUNKT LED 23 / 157J-GB-3B-HKDU-EU
    Added after 3 [hours] 31 [minutes]:
    Subject to close it turned out that the TV also has functions in the settings, hdmi cec, it is turned on in the factory settings
