Windows 7 - No letter "Ł" - after pressing Alt + L the system locks
szafranek72 11229 3
  • #1 16785682
    szafranek72
    Rate: 57
    On a computer with Win7 HP x64 somehow disappeared the possibility of entering the letter "Ł" - the key combination Right Alt + L or Right Alt + Shift + L blocks the system exactly as if I had pressed Win + L.
    I don't know what's going on, the computer is used rarely, the last thing was installed is the standard Windows update.
    Intel graphics - keyboard shortcuts are disabled.
    how to solve it?
    Kolobos
    IT specialist
    Help: 17174
    Rate: 10460
    After replacing the keyboard for another problem, you still get it?
  • #3 16785694
    szafranek72
    Rate: 57
    in the physical sense? there is no such - comp. operated remotely.
    you gave me an idea because I was updating the remote management program, I will check if any shortcuts have been activated here.
    Added after 24 [minutes]:
    Yes and that was it - I just discovered a bug in the new prog version. for remote access.
    A shortcut to send the "Win + L" shortcut to the remote set to Ctrl + Alt + L, but it is also sent after pressing Alt + L. I set sending to Ctrl + L and eliminated the problem.
    Thank you for targeting :)
    edit: radmin 3.5.1
  • #4 16785814
    tzok
    Help: 3177
    Rate: 6558
    Can you tell us what remote control program this problem is in?
