Skoda Fabia: Assessing Standby Power Usage of Added Electrical Components
Hambubu787 13710 12
Do ordinary added car switches, a USB converter with nothing plugged in, or the radio circuit draw standby current, and how can I find what is causing the remaining parasitic drain?
The ordinary switches themselves do not draw current if they are working, and the USB converter should not be the main cause unless something else in that circuit is powered [#16788280] The large standby drain is more likely from the radio, an LPG controller that can draw about 150 mA, or the VAG comfort module/door-lock microswitches that prevent the car from going to sleep [#16788602] [#16789721] [#16790274] Let the car sit for about 15–20 minutes and then measure the current again, because the module should fall asleep after that time [#16790710] To locate the culprit, pull the fuses one by one and watch when the current drops; fuse 43 is mentioned as the comfort module / automatic transmission selector lock feed [#16787028] [#16790924] Also check whether the interior light reacts correctly to all doors, since a bad door-lock microswitch can keep the system awake [#16789721]
  • #1 16787017
    Hambubu787
    Hello. I added a few things in the car that require electricity. To three of them I added such switches (I add an attachment, it's something like that)
    Do they draw any electricity even when they are turned off? Somewhere I read something like this and it doesn't give me peace, besides I added usb, but there is nothing plugged in and I added the radio. All these things are plugged into the radio cables there. When I wanted to check the current at a standstill, the meter showed me 310mA which is a very large value, after removing the fuse from the radio only 130mA, although still too much. I also added a lock on the remote control but wrote that it should charge a mountain 8mA at a standstill.
    Also, I want to know if these switches draw some current and if I installed the USB converter, does it download something when nothing is connected to it, because if not everything is to blame for the radio and it consumes over 150mA. Besides, how do you find what gets the remaining 130? Pull out all fuses in turn and take measurements?
  • #3 16787062
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Attach everything you can under the key and the problem will solve itself.
  • #4 16787079
    Hambubu787
    This usb will switch and the radio may be under the key, but do these switches consume electricity? There are no LEDs or anything, the most ordinary (I added a picture) Because it gives me no peace :)
  • #5 16787135
    Kaczor64
    Rate: 43
    Start by connecting the radio to the key
  • #6 16788280
    WS
    Help: 6
    The power switches themselves do not draw (as long as they are working).
  • #7 16788602
    FAB 2002
    Help: 35
    Rate: 195
    And sometimes you don't have LPG installation? Because the controller can draw approx. 150 mA.
  • #8 16789721
    arbobo
    Help: 11
    Rate: 57
    In the Vag group, the most common reason for the power consumption at a standstill is damage to the microswitches in the door locks (the comfort module does not put the system to sleep if it cannot see the location of the door locks. Check if the interior lighting reacts to all doors.
  • #9 16790274
    Hambubu787
    I have an LPG installation. The case looks like this, all the things that I installed do not consume electricity except a radio that pulls about 160mA. 6mA probably pulls the central locking controller, there is still 140mA left. After pulling out the fuse 43. (central controller, automatic transmission control lever lock, 20A), this 6mA is probably left. I don't know if this fuse 43 is this, but I found it on the net. Should this be the case and does this driver fall asleep after some time? If so, after what and what should the consumption be then?
  • #10 16790353
    Help: 1405
    Rate: 6430
    Lift the ignition cube and see if the current drops.
  • #11 16790655
    Hambubu787
    Where is the cube?
  • #12 16790710
    moto-kord
    Help: 137
    Rate: 505
    Hambubu787 wrote:
    does this driver go to sleep after some time
    Connect the meter and check after 15-20min what the consumption is.
    Hambubu787 wrote:
    Where is the cube?
    Remove the ignition cover and switches and you will see the ignition cube.
The discussion revolves around assessing the standby power usage of additional electrical components installed in a Skoda Fabia. The user inquires whether the added switches and USB converter draw power when turned off, as they are experiencing a high current draw of 310mA at standstill, which reduces to 130mA after removing the radio fuse. Responses suggest checking all fuses to identify the source of the current draw, connecting the radio to the ignition key, and confirming that the switches themselves do not consume power when inactive. The user also mentions having an LPG installation, which could contribute to the current draw, and seeks clarification on the behavior of the central locking controller and comfort module related to fuse No. 43.
TL;DR: If your Fabia’s battery shows unexpected drain, remember: “the controller can draw approx. 150 mA.” Isolate add‑ons, wait for sleep, and verify circuits before blaming the battery. [Elektroda, FAB 2002, post #16788602]
Why it matters: Fast, methodical checks prevent repeated dead batteries and unnecessary parts swaps for Skoda Fabia owners troubleshooting parasitic draw.
Do simple toggle switches consume power when they’re off?
No. A basic, healthy mechanical toggle switch with no indicator LED draws no current when off. As one expert put it, “The power switches themselves do not draw (as long as they are working).” If you still see draw, suspect wiring, a stuck relay, or devices on constant power. [Elektroda, WS, post #16788280]
How should I wire add-ons like radio or USB to avoid battery drain?
Put accessories on an ignition-switched feed (“under the key”), not on a permanent battery feed. That way they shut off when you remove the key, eliminating standby draw from those devices without needing to unplug anything. This approach also simplifies troubleshooting later. [Elektroda, Strumien swiadomosci swia, post #16787062]
My aftermarket radio shows about 160 mA at rest. Is that normal?
No. About 160 mA parasitic draw from the radio is excessive for sleep current. Move the radio to an ignition-switched circuit or fix its wiring so it powers down fully when the car sleeps. Retest after the vehicle’s modules go to sleep. [Elektroda, Hambubu787, post #16790274]
What’s the quickest way to find what’s draining my Fabia’s battery?
Use a meter in series with the battery negative and pull fuses one by one until the current drops. Note the circuit, trace the offending device, and repair or rewire. This systematic approach isolates the problematic branch efficiently. [Elektroda, Kaczor64, post #16787028]
How long should I wait before reading the true sleep current?
Connect the meter, lock the car, and wait 15–20 minutes so modules can sleep. Only then judge whether the draw is acceptable. If the current keeps fluctuating, a module is staying awake and you must continue isolating circuits. [Elektroda, moto-kord, post #16790710]
Could my LPG installation be the cause of a large parasitic draw?
Yes. An LPG controller can add notable standby current; one experienced user notes it can be “approx. 150 mA.” If you have LPG, pull its fuse or disconnect its feed to confirm. Restore power after testing to avoid fault codes. [Elektroda, FAB 2002, post #16788602]
What does fuse 43 power on the Fabia, and why does it matter?
Fuse 43 is tied to the comfort module on the Fabia. If pulling fuse 43 drops your draw, investigate the comfort module, door locks, or related wiring. Recheck after sleep to confirm the module isn’t waking repeatedly. [Elektroda, FAB 2002, post #16790924]
Interior light misbehaving—could door lock microswitches keep the car awake?
Yes. Failed door-lock microswitches can stop the comfort module from sleeping because it “cannot see the location of the door locks.” Check if the interior light responds correctly to each door; fix any lock with faulty feedback. [Elektroda, arbobo, post #16789721]
What is the “ignition cube,” and how can it help diagnosis?
The ignition cube is the ignition switch/connector assembly. Lifting or disconnecting it temporarily can show if an ignition-circuit fault is holding modules awake. If current drops when it’s disconnected, inspect the switch and related feeds. [Elektroda, moto-kord, post #16790710]
Is 130 mA sleep current acceptable on a Fabia?
No. In the discussed case, users considered 130 mA still too high after initial fixes. Continue isolating circuits until you reach a lower, stable sleep draw after waiting the sleep period. Treat 130 mA as a problem to solve. [Elektroda, Hambubu787, post #16787017]
How do I connect an aftermarket radio to avoid standby draw?
“Start by connecting the radio to the key.” Use the ACC/ignition-switched supply so the head unit powers down when you remove the key. Verify memory and constant feeds are correct to retain presets without leaving the unit awake. [Elektroda, Kaczor64, post #16787135]
Do central locking/remote lock modules draw power at rest?
Yes, a small amount. In the referenced case, the central locking controller drew about 6 mA at rest. That’s modest, but add-ons like radios or LPG controllers can dwarf it. Balance your measurements across all circuits. [Elektroda, Hambubu787, post #16790274]
How do I check true sleep current step-by-step?
  1. Connect an ammeter in series with the negative battery terminal and secure the leads.
  2. Lock the car and wait 15–20 minutes for all modules to sleep.
  3. Read and record the stabilized current, then begin circuit isolation if it’s high. [Elektroda, moto-kord, post #16790710]
What’s a common edge case that keeps Fabia systems awake?
Damaged door-lock microswitches prevent the comfort module from recognizing closed/locked status, so it never sleeps. The tell is interior lighting that doesn’t match door state. Repair or replace the affected lock mechanism. [Elektroda, arbobo, post #16789721]
