Skoda Fabia 1 - Removing Front Seats & Battery Disconnection Query
marekwodniak 11799 7
  • #1 16768023
    marekwodniak
    Help: 14
    Rate: 194
    I need to remove the Fabia 1 front seats. Do I need to remove the battery.
  • #2 16768044
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    And for what purpose do you want to remove the battery?
  • #3 16768107
    Szyszkownik Kilkujadek
    Level 37  
    Help: 211
    Rate: 1014
    If you have heated seats, disconnect the battery minus for safety.
  • #4 16768120
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    I suspect that the colleague was more concerned about the ankle than the seat cushions but if you do not turn the key to position 1, the AirBag error indicator will not light up.
  • #5 16768125
    marqqv
    Level 32  
    Help: 162
    Rate: 609
    BK_klp wrote:
    for safety, disconnect the minus battery.
    Make sure you have the radio pin / code because the second problem will come up :D
  • #6 16768128
    Level 37  
    Help: 211
    Rate: 1014
    Anyway, it's worth disconnecting. Of course, the radio code is worth knowing. :-D
  • #7 16768136
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    If the radio has such protection and is active. By the way, I drove once 400km at night without a radio, as it fell at -20 * C :)
  • #8 16768739
    marekwodniak
    Help: 14
    Rate: 194
    Thank you for the answers, specifically I meant to unfasten the ankle pillows. I asked because they write differently. Unplug the battery and not. I did not unfasten the key was not in the ignition. I got the original covers for Skoda and to look great I need to remove the seats. Difficult to get to the bottom of the seats. But it was worth it.
The discussion revolves around the process of removing the front seats from a Skoda Fabia 1 and whether it is necessary to disconnect the battery during this procedure. Several users suggest that disconnecting the battery is advisable, especially if the seats are heated, to ensure safety and prevent triggering the AirBag error indicator. Additionally, users emphasize the importance of having the radio code available, as disconnecting the battery may lead to issues with the radio system. The original poster clarifies that their intention was to remove the ankle pillows from the seats and mentions the difficulty in accessing the bottom of the seats, but ultimately finds the effort worthwhile for the new Skoda covers.
