HP OfficeJet Pro 6830: Step-by-Step Guide to Remove & Replace Printhead Safely
321diwad 7026 2
  • #1 16796490
    321diwad
    I was looking on the internet how to remove the printhead but found only replacement in other printers. I tried to take it out for half an hour but I failed. If anyone knows how to do it, please help.
  • #2 16812963
    alek25
    Help: 44
    Rate: 88
    You open the flap from the carcass, wait for the ambulance to come out, pull out the carcasses, gray lever up. Just why do you want to pull the head out?
  • #3 16885382
    bodzioso
    Rate: 10
    To get to the head you need to unscrew the cover. After unscrewing you remove the two springs from the head and gently pull the head upwards. Unhook 4 cables and ready. Installation in the reverse order.
