LTE Frequencies: Orange 1800 or 2600 for Huawei E5186? ATK 20 & SR-17P Antenna options explored
maximus407 16839 5
  • Choosing 1800 MHz over 2600 MHz for LTE range
    #1 16797375
    maximus407
    Hello, I would like to know which LTE frequency in the orange choose 1800 or 2600? I have a 4.5km transmitter. The modem is huawei e5186. Currently, I use two antennas atk 20 and LTE 800 but in the evening the transfer drops from 25Mbps in the day to 6Mbps and the ping in games exceeds 250.
    I was thinking about buying the Sorensen SR-17P antenna
    http://allegro.pl/antena-lte-sorensen-17dbi-nowosc-sr-17p-dla-graczy-i7022231920.html
  • #2 16797679
    jdubowski
    Tube devices specialist
    Help: 2511
    Rate: 2807
    The one on which the signal is stronger.
    maximus407 wrote:
    last night the transfer drops from 25Mbps in the day to 6Mbps and the ping in games exceeds 250.
    And you think that this problem will be solved by waving antennas?
  • #3 16797871
    matek451
    Help: 4356
    Rate: 5816
    At BTS, Netwotks Spring only operates LTE800 Orange. At LTE1800, it's probably just permission, maybe one day they'll start. on LTE2600 I would rather not count because it is a bandwidth to cities. The nearest active BTS LTE1800Networks is Sierosławice. BTS with all LTE bands in Końskie, Krakowska 44. To them about 8 km but through forests. On the E5186 you can force specific LTE bands and check if there is any LTE1800 and LTE2600 range.
  • #4 16803159
    maximus407
    One more question: Will the parabolic antenna receive LTE800 from BTS Wiosna? But will I have to send it to BTS LTE1800?
  • #5 16803297
    matek451
    Help: 4356
    Rate: 5816
    Try to set the ATK-20 antenna on Sierosławice or on Krakowska 44 in Końskie there also are LTE800 Orange, maybe they are less burdened with this in Spring. Well, it is also worth to force LTE1800 and check these directions. BTs LTE800 Spring looks overloaded.
  • Higher mast improved LTE speed and ping
    #6 16805985
    maximus407
    I raised the mast with the antenna by 1.5m (now about 8m) and the transfer increased in rush hours to 15Mbps - 35Mbps, and the ping decreased to 80 - 100.
    I will try to replace the coaxial cables from the antennas for shorter and better quality (currently 10m and 6m plans), but I will extend the RJ45 cable from 1.5m to 5m.
    I do not know why the same cable length (1.5 m) of CAT 5a RJ45 was 10Mbps less than CAT 7.
