Huawei B525 Router, Sorensen 1800MHz Antenna - Improved SINR & Internet Quality on 2600MHz Band?
Kiwi0033 15273 7
  • #1 17213903
    Kiwi0033
    Some time ago I changed the LTE mobile internet operator due to better coverage, transfer and lower network load during peak hours. Internet when it comes to downloading and uploading works quite well and almost enough for my needs.
    I have a Huawei b525 router and a Sorensen 1800MHz external antenna, and here is the problem. On the previous operator, the 1800MHz band was fine, but my current transmitter (200-300m in a straight line) sends internet in the 2600MHz band. Reading the parameters of my range, everything seems fine except for the SINR indicator which is low and jumps from 4 to 10 dB. In addition, RSRQ still jumps from -4 to -9dB. My problem is not the speed of the internet but its quality, sometimes I can lose packets in some games (not bad ping) and here the question is: will buying a new antenna receiving the 2600MHz band improve anything in the quality of the internet? Is the antenna really responsible only for the range, which is really nice and it will not help me with these unfortunate lost packages?
    In the attachment I put all the Internet parameters, I hope that someone will be able to answer my question ;)
    • Huawei B525 Router, Sorensen 1800MHz Antenna - Improved SINR & Internet Quality on 2600MHz Band? Screenshot_2018-05-10-20-10-13.png (260.24 KB) You must be logged in to download this attachment.
  • #2 17213993
    makosuu
    Help: 369
    Rate: 370
    The signal is very good, are the problems only in the evening and then disappear until the next evening? Low SINR may indicate BTS load.
  • #4 17214129
    Kiwi0033
    The transmitter is close, the range is fine but without the antenna from my apartment there are already problems (low, almost like a basement) so even on this mismatched (I think) antenna there is a noticeable plus (downloading / sending). I'm just wondering about the jumping SINR, and it is very different when it comes to losing packages. Sometimes around 19-21 I don't lose them at all, and sometimes even outside of rush hours they get lost somewhere and I can't explain it. I read a bit about these parameters but this is only quick knowledge of the Internet, I am still a layman in these matters ;)
  • #5 17218318
    Kiwi0033
    Does anyone know if changing this antenna will improve anything because I did not get an answer. Yesterday I tried to use the internal antenna and performance was worse (above all ping a lot higher). I'm tossing a new screen with range parameters. Sunday, 12:00 o'clock so there shouldn't be too much overload of the transmitter, and yet the SINR does not knock, and the RSRQ jumps like crazy from -4 to -9dB (but this is still a pretty good result).
    • Huawei B525 Router, Sorensen 1800MHz Antenna - Improved SINR & Internet Quality on 2600MHz Band? Screenshot_2018-05-13-12-11-33.png (249.29 KB) You must be logged in to download this attachment.
  • #6 17218579
    makosuu
    Help: 369
    Rate: 370
    Disconnect the antenna for a moment and see if it will be the same.
  • #7 17220241
    Kiwi0033
    After disconnecting the RSRQ and SINR antennas continue to jump, the only change is to change RSSI from around -50 to -80/90.
    matek451
    Help: 4356
    Rate: 5816
    The antenna carries the signal pickup point outside, although it is not dedicated to the 2600MHz band. SINR changes are the effect of loading this band on your LTE2600 T-mobile sector on BTS near Warsaw. A 2600MHz antenna dedicated to this band will improve the signal and stabilize the connection, but it is difficult to predict whether it will affect speed, ping.
The discussion revolves around the performance of a Huawei B525 router paired with a Sorensen 1800MHz external antenna, particularly in relation to the 2600MHz band used by the current LTE mobile internet operator. The user experiences low and fluctuating SINR (4 to 10 dB) and RSRQ (-4 to -9 dB), leading to packet loss during online gaming, despite good download and upload speeds. Responses suggest that the low SINR may be due to network congestion on the 2600MHz band. A dedicated 2600MHz antenna could potentially stabilize the connection and improve signal quality, although the exact impact on speed and ping remains uncertain. Testing with the internal antenna showed worse performance, indicating the external antenna's effectiveness in signal reception.
