Error E1 on Rotenso Sole Air Conditioning S70Vi/S70Vo 6.4kW: Communication Issue & Troubleshooting
Jakubosz 21045 1
  • #1 16800409
    Jakubosz
    On the tmp display. error E1 appears. Rotenso Sole version S70Vi / S70Vo 6.4kW
    According to the description, this is a problem with communication between the internal unit. and external
    All cables checked.
    Motherboard fuse approx.
    Outdoor unit does not switch on.
    The error most likely appeared after the night was turned off several times and the climate was in the heating option.
    We know what it can be?
  • #2 16804649
    Miroslaw Cichy
    E1 is indeed a communication error between individuals. The question is what caused the power to be turned off several times (power surges or e.g. power line failure).
    If you are an end customer, it is best to contact an Authorized Installer, and if you are a representative of a company from the HVAC industry, please contact our Service Department directly, we will conduct a diagnosis of the device.
    Mirosław Cichy
    Deputy Head of Technical Department
    Rotenso Poland
    info(_at_)rotenso.pl
    facebook.com/rotenso
