[Solved] ROTENSO SOLE 3.5kW Air Conditioner (Japanese Production): SCOP, SEER, A+/A++ Class Experience
wnoto 44805 18
Is the Rotenso SOLE 3.5 kW air conditioner worth buying, and what real-world experience do users have with it?
Rotenso is described in the thread as a Chinese-made unit, with production in Guangzhou and a design office in Japan, even though some users mention it being linked to GREE/SINCLAIR or Daikin-origin solutions [#15727481] [#15806687] [#17876100] [#15757848] In practice, users report that the units work flawlessly and are quieter than LG Basic, with better performance [#15732045] One installer says the compressors are identical to Daikin’s, and another calls Rotenso a good Chinese air conditioner that can be confidently recommended [#15757848] [#18892556] Overall, the forum feedback is positive on performance and noise, but it does not support the idea that it is a Japanese-built product [#17876100] [#15727481]
  • #1 15727283
    wnoto
    Help: 58
    Rate: 744
    Has anyone ever dealt with this company's air-conditioners?
    The 3.5kW version has SCOP and SEER quite high which gives it class A + / A ++.
    p.obelix
    Refrigeration equipment specialist
    Help: 215
    Rate: 563
    Chinese, the same factory as GREE, SINCLAIR
  • #3 15727950
    wnoto
    Help: 58
    Rate: 744
    well, and I was tempted by Chinese production ...
    I will probably stay with LG 3.5kw basic.
    Or maybe something else is worth paying attention to?
    On their website, there is indeed information that production in Guangzhou :(
    maxrider
    Help: 12
    Rate: 30
    Certainly Quieter than LG basic and much better performance.
    I have installed a few of them and they work flawlessly.
    mirek301
    Help: 24
    Rate: 52
    So far, I have mounted both pieces and as independent and multi-knocks, no problem. It is not entirely true that it is Chinese, because the compressors are identical to those in Daikin.
    And LG is not the same air conditioners as a few years ago.
    Two identical units from one delivery and the noise level between them heaven and earth.
    You are thinking of something for years, a Toshiba idea or something from this shelf, unfortunately, they are not the cheapest devices.
  • #6 15805940
    pkpintercity
    Rate: 58
    today the company has installed a rotenso salt 3.5kW in my apartment so far cool, only one cool function is known to cool the water flowing outside it is water but where is it from? and a question about the dry function and how does it work in the sense of how it removes moisture from my house? Thank you for your help
    p.obelix
    Help: 215
    Rate: 563
    Water, or distillate, is produced on the cooler. Moist air flows around the radiator fins, the temperature of which is below the dew point, and this causes water to condense from the air. Then the water flows into the gutter and then somewhere outside. As for the second question, the answer is the same, but the device tries not to lower the temperature in the room.
  • #8 15806244
    mirek301
    Help: 24
    Rate: 52
    As already, let's use the terminology used.
    1.) Almost fine :) this trough is called the drain pan, sometimes a drain pump is also used, but that's a different story, this cooler is called the condenser in the outdoor unit and the evaporator in the indoor unit.
    2.) Almost fine :) In the era of inverters, the outdoor unit is the heart of the microprocessor-controlled system.
    after reading the condenser temperature and air temperature, it selects the operating parameters of the indoor unit so that it does not cool the room, and at the same time causes the precipitation of water from the water vapor contained in the air.
  • #9 15806265
    p.obelix
    Help: 215
    Rate: 563
    1.) Almost well, this trough is called a condensate tray, sometimes a drain pump is also used, but that's another story, this cooler is called a condenser.
    But you jumped out like an elastic from your panties, think about what you wrote. Correct what you wrote about the radiator. Writing to write, well, every point counts. Sometimes you have to write so that a person can understand and not use phrases such as evaporator condenser TZR EZR
  • #10 15806315
    mirek301
    Help: 24
    Rate: 52
    However, I can see that you don't have much information about ROTENSO air conditioners. It has never been installed in China and the basic technical solutions are borrowed from DAIKIN with his consent.
    But with a choice of GREE, MIDEA, MDV, GALANZ etc, he chose ROTENSO.
    Nice equipment for a decent cash.
  • #11 15806687
    wnoto
    Help: 58
    Rate: 744
    On their website, there is information that the factories are in China and only a design office in Japan.
  • #12 15946414
    pkpintercity
    Rate: 58
    Question, can someone explain to me what is this heating climate that works as a heat pump ????? thank you very much
    p.obelix
    Help: 215
    Rate: 563
    Your refrigerator is also a heat pump. It is not very clear what to translate so much of this on Google that the head is small. And if one cold does not exist, it is only heat.
  • #14 17876100
    freebsd
    Help: 766
    Rate: 2033
    In fact, "Total Chinese", not any Japanese product. Quote from their website:
    "The company's headquarters and development center are located in the heart of Asia. This is where unique and innovative technological solutions are created. The production facilities and development center are located in Guangzhou, China. This is where the idea becomes a solution, a complete device that makes us proud . "
  • #15 18879359
    ELEKTRONIK2
    Rate: 23
    I read the thread on a different matter, but I noticed that my colleague mirek301's attention was drawn to the wrong naming of the coolers, in the end, however, what was going on was not explained. The "" cold cooler "in the house is the one in which the refrigerant evaporates and that is why it is called EVAPORATOR, while outside there is a cooler in which the gas is condensed, therefore it is called the CONDENSER.
  • #16 18881869
    mirek301
    Help: 24
    Rate: 52
    A colleague of "p.obelix" once pointed out to me that I was thinking right, but I wrote the effects of bothering wrong, although the post was edited and the nomenclature is correct in the post. Describe the air conditioner below.
    https://pl.wikipedia.org/wiki/Klimatyzator
    - the evaporator decompresses and evaporates the liquid refrigerant, the expanding refrigerant cools the evaporator collecting heat from the environment.
    - the condenser is designed to cool the refrigerant in order to condense it again, hence its name.
  • #17 18892556
    Florian5555
    Yes, enough nonsense has fallen higher.
    Climate is basically a simple system,
    The compressor in the outdoor unit compresses the refrigerant up to the pressure in which the refrigerant changes into a liquid state, the compression process releases heat which is transferred to the environment by the condenser ("cooler") outside.
    The cooled liquid refrigerant is transported by a pipeline to the indoor unit where, thanks to the expansion valve, it changes the aggregate state in the evaporator ("cooler") back to gaseous state, and in the expansion process, cold is released in the room. Later, the gaseous refrigerant returns to the compressor and the cycle repeats itself.
    If you set the heating mode in the climate, the internal valve changes the direction of the refrigerant flow, the internal cooler takes the role of a condenser and transfers the heat to the room, and the external evaporator and transfers the cold to the outside ?
    Rotenso is a good Chinese, I can confidently recommend.
  • #18 20053528
    jamarswidnica
    In the age of globalization, everything is more or less Chinese. Many world-renowned companies have their companies in China because it is cheap there and everything is immediately available. Unfortunately, this also applies to air conditioners.
  • #19 20056996
    wnoto
    Help: 58
    Rate: 744
    I already know where they manufacture :) .
The discussion revolves around the ROTENSO SOLE 3.5kW air conditioner, highlighting its high SCOP and SEER ratings, which classify it as A+/A++. Users express mixed feelings about the brand's production origins, with some noting that it is manufactured in China, specifically Guangzhou, while others claim it utilizes technology similar to Daikin. Several users report positive experiences with the unit's performance, noting it operates quieter than basic LG models and has reliable functionality. Technical discussions clarify the roles of the evaporator and condenser in the cooling process, and the air conditioner's ability to function as a heat pump is also explained. Overall, ROTENSO is viewed as a decent option among other brands like GREE and LG, despite concerns about its Chinese manufacturing.
