Connecting Wiśniowski Up-and-Over Garage Door Drive with Beninca Bill 30 Gate & HEDY Panel
Kriss_c 5676 6
  • #1 16808900
    Kriss_c
    Level 4  
    Rate: 9
    I have a Wiśniowski up-and-over garage door with dimensions: 230 cm width, 200 cm height, mounting depth - as much as a 25 cm block.
    1. How can I use the drive for it to be able to control it with a remote control from the Beninca Bill 30 entrance gate with HEDY headquarters?
    2. How to connect the proposed drive to the HEDY control panel?
    3. As you can see in the attached picture, I have quite a considerable distance from the top of the gate to the ceiling - 60 cm.
    Can I mount the drive directly to the ceiling or do I have to lower it to any height?
    Thank you in advance for any information.
    Regards Krzysiek
    • Connecting Wiśniowski Up-and-Over Garage Door Drive with Beninca Bill 30 Gate & HEDY Panel DSC_0012.JPG (1.46 MB) You must be logged in to download this attachment.
  • #2 16808910
    Zbigniew 400
    Help: 283
    Rate: 794
    The assembly instructions specify the mounting height of the rail.
    Any drive + radio beninca or beninca drive.
  • #3 16809084
    Kriss_c
    Level 4  
    Rate: 9
    Are you proposing a specific model for a reasonable price?
    The gate will probably be opened twice a day - morning and evening, so I do not anticipate any particular load.
    The gate itself is also not the heaviest due to its size and construction (sheet metal and frame without additional insulation).
    Will these "market" meet expectations?
    eg .:
    https://www.leroymerlin.pl/ogrodzenia-i-bramy...zowych/naped-do-bram-garazowych-lm-100-systec, p418458, l524.html? gclid = EAIaIQobChMIkc2Mp-Cu1wIVBZ8bCh1Isg99EAYYBCABEgK21_D_BwE & gclsrc aw.ds = & = DCLID CP2IiazgrtcCFQiRGAodXRQHJA
    I hope that each of the drives available on the market allows easy disconnection so that you can open it manually?
  • #4 16809111
    Zbigniew 400
    Help: 283
    Rate: 794
    I would buy Beninca because
    No need to buy a radio
    You have 2 additional remote controls
    Spare parts after warranty.
  • #5 16809125
    Kriss_c
    Level 4  
    Rate: 9
    OK thanks.
  • #6 16809170
    Zbigniew 400
    Help: 283
    Rate: 794
    Just check the compatibility with the gate drive.
  • #7 16809273
    Kriss_c
    Level 4  
    Rate: 9
    I just wrote to the manufacturer for a model I can use.
The discussion revolves around connecting a Wiśniowski up-and-over garage door to a Beninca Bill 30 gate drive and HEDY control panel. The user seeks guidance on how to integrate the remote control functionality and the appropriate mounting height for the drive, given a 60 cm clearance from the gate to the ceiling. Responses suggest checking the assembly instructions for mounting height and compatibility with the gate drive. Recommendations include considering Beninca products for their ease of use and included remote controls. The user also inquires about specific models that are reasonably priced and suitable for light usage.
