Connecting Bell Switch to Wiśniowski Metro 800 Drive for Gate Control without Remote
JacekFilipczyk 23430 8
  • Asking how to wire a bell switch to Metro 800
    #1 17451476
    JacekFilipczyk
    Rate: 31
    Good day. I would like to connect the bell switch to the Metro 800 drive of the Wiśniowski gate in order to be able to open and close without a remote control. Unfortunately, there is no information in the manual and diagrams where you can install such a switch. The only thing I found was the possibility of connecting a key switch or a code keyboard. There is no mention of bell-type switches. Has anyone installed something similar to the Wiśniowski gates and can suggest how to connect it?
  • #2 17451567
    zybex
    Helpful for users
    Help: 2094
    Rate: 2939
    In the manual I found the wired control input (NO) in the "CONNECTIONS" section. This is where you probably need to give this button. Link .
  • #3 17453031
    JacekFilipczyk
    Rate: 31
    Yes, I saw this information, but the installer who assembled the gate stated that a 3-wire cable is needed to connect this switch. The 3 wires only go to the two switches I mentioned. He messed my head and that's why I preferred to ask. I also think that 2 wires are enough.
  • #4 17453044
    zybex
    Helpful for users
    Help: 2094
    Rate: 2939
    Personally, I have not encountered such a drive. The ones I met always had wired input. Of course, there are two wires to the button (input and ground).
  • #5 17453080
    SławekSS
    Help: 34
    Rate: 80
    Figures 21 and 26 of the manual describe exactly how to connect this button.
    One more thing, the installer is wrong.
  • #6 18646227
    gu_staw
    Rate: 16
    Hi Jacek.
    How she solved this problem.
    I have exactly the same.
    I want to connect the doorbell switch to the drive inside and additionally I have a keyboard with 8 pieces outside. How did you connect it
  • #7 19778624
    bogut
    Rate: 10
    I confirm
    12, 13 - power supply
    16, 17 - control
    I just installed an additional radio so that it was compatible with the old Wisniowski machines and could be opened with one remote control
    greet
  • #8 20615749
    mickry
    Rate: 20
    Hello, do you need 2 or 4 wires after all?
  • #9 20615796
    nikusert
    Help: 699
    Rate: 1755
    Two wires to terminals 16-17.
The discussion revolves around connecting a bell switch to the Wiśniowski Metro 800 drive for gate control without using a remote. Users highlight that the manual indicates a wired control input (NO) for connection, specifically at terminals 16-17, which require only two wires. Some users express confusion regarding the necessity of a 3-wire cable, as suggested by an installer, but others confirm that two wires suffice for the connection. Additional insights include the possibility of integrating a keyboard and the installation of a radio for compatibility with older Wiśniowski models.
