Connecting Graphics Card with DVI Output to DisplayPort Monitor: Adapter Effectiveness
mateusztt 10257 7
  • #1 16270511
    mateusztt
    I have the following problem: I'm currently using a graphics card with DVI output (and D-sub and HDMI),
    however, I found a new monitor that only has a Displayport and D-sub connector.
    So the problem is how to connect it. I would prefer to avoid D-sub, hence the question or use
    will DisplayPort to DVI adapters give a better effect? Maybe someone uses such a patent?
    example adapter:
    http: // alleg ...................
    Moderated By RADU23:
    I removed the shop / auction link, leaving the exact model / product name / specification.
    3.1.18. Do not send links that will become inactive after some time. This will cause the discussion to lose any meaning.
  • #2 16270519
    Kasek21
    Help: 4981
    Rate: 3548
    It's a digital signal all the time so it should work.
    It should be because it looks different on different adapters.
    mateusztt wrote:
    I found a new monitor that only has Displayport and D-sub connectors.
    A strange combination - what is this monitor model?
  • #3 16270535
    mateusztt
    it's Dell P2016, I'm also surprised that they didn't give him DVI
  • #4 16270803
    310artur
    Help: 980
    Rate: 670
    It should but will not be. The HDMI - DS converter costs over PLN 300. Change the graphics card or look at another monitor ;) It's a pity nerve. It's easy to get out of the DS graphics card to DVI or HDMI and the other way is not so easy.
    Either DSUB or it won't work well.
  • #5 16275006
    mateusztt
    As I found out, this adapter works only one way, tz from DisplayPort to DVI
    Why this is so remains a mystery :)
    I guess I will actually have to choose some other monitor, eh ...
  • Passive adapters work only from DP output; reverse conversion requires an active
    #6 16276579
    310artur
    Help: 980
    Rate: 670
    I have been looking for a lot lately and it works like this. DP as the newest port is backwards compatible with all previous ones (HDMI DVI and even often D-SUB). Compatibility is that it contains them. But this description of the DP OUTPUT the monitor manufacturer does not make the input compatible with everything but only the compatible with DP. Therefore, you connect the passive adapter to the DP output of the graphics card and the active converter is needed the other way. And you can buy one but it costs PLN 300 +
  • #8 16279137
    310artur
    Help: 980
    Rate: 670
    But it works the other way than the author needs it right? Graphics card DP output and monitor DVI input.
The discussion revolves around connecting a graphics card with DVI output to a monitor that only has DisplayPort and D-sub connectors. Users express concerns about the effectiveness of DisplayPort to DVI adapters, noting that while DVI is a digital signal, compatibility issues may arise. One user mentions the Dell P2016 monitor, which lacks a DVI port, leading to frustration. It is highlighted that DisplayPort to DVI adapters typically work only in one direction (from DisplayPort to DVI), and using a passive adapter from DVI to DisplayPort may not yield satisfactory results. The need for an active adapter is emphasized, which can be costly. A specific adapter from DeLock is mentioned as functioning well in some cases, although there are reports of failures with certain units.
