BENINCA JIM 3 Drive: Programming Issues with To.Go-VA 2 & To.Go-WV Remotes - Solutions?
przemek219 9474 2
  • Second remote not accepted after PGM programming
    #1 16811686
    przemek219
    Hello, I have this problem, I have the BENINCA JIM 3 drive is programming the first remote control:
    to.go-va 2
    Memorizing the new relay by switching on the PP function
    - Press the PGM button only once every 1s, the Power LED will start blinking at intervals
    every 1s
    - Within 10 seconds, press the button of the relay which is to be memorized by the function
    PP
    To exit programming, wait 10s or press the PGM button for 1s.
    the remote control works, but I can not program the second remote control, I still have 2 to.go-wv remotes
    I do it like this
    every 1s
    - I press the remote control button but it does not load, the light goes out after 10 seconds
    How do I remove the remote
    Removal of all relays from memory
    - Hold down the PGM button for 15 seconds, LED DL1 and the indicator light start flashing in the mode
    fast and go out after deletion is complete.
    - Release the PGM button, the memory has been deleted.
    and i program the first to-go-wv works but i can't program anything or to-go -va anymore
    new drive I don't know if the radio is damaged or I am doing something wrong. Please help. Regards
  • #2 17001111
    mateusz199462
    You need to change the encoding on those remotes with green buttons. You press two buttons together for 30 seconds.
  • #3 21473485
    damiankolesnik
    Still a helpful answer after all these years. You saved my day
