Gldriverquery.exe Stopped Working Error with AMD Ryzen 1300x, GTX 1050TI on Windows 8.1
jokerinho 10488 2
  • #1 16814354
    jokerinho
    Level 4  
    Hello, today I installed the system and drivers for subassemblies. After updating and installing all drivers, there was a problem. Each time you turn on the error: "gldriverquery.exe has stopped working"
    My equipment:
    Windows 8.1
    AMD Ryzen 1300x
    GTX 1050TI
    Motherboard: asrock a320m-dgs
    Do you know about it? Gldriverquery.exe Stopped Working Error with AMD Ryzen 1300x, GTX 1050TI on Windows 8.1
    Kolobos
    IT specialist
    Help: 17174
    Rate: 10460
    Yes, if you entered the name of the file gldriverquery.exe in google then you would also know it.
    First link: http://steamcommunity.com/discussions/forum/1/1489987634016629319/?ctp=6#c1484358860946452903
    Go to C: \ Program Files (x86) \ Steam \ bin
    Right click on gldriverquery.exe
    Click the Compatibility tab
    Under Settings, check "Run this program as an administrator" (yes, even if you are already an admin)
    What can you not understand here? Even after posting to google translate.
    You have the properties of the gldriverquery.exe file marked with running with administrator rights.
  • #3 16817170
    jokerinho
    Level 4  
    Problem solved.
