[Solved] Whirlpool AGD 6240 FD / 1 - "h2o" error - there was another reason
mmazur 45756 4
  • #1 16815850
    mmazur
    Rate: 31
    Dear colleagues, this is the case. The dishwasher as above after giving the program and starting after a while returns the error "h2o".
    In accordance with the instructions, forum and tips I checked as follows:
    - inflow (there is water, there is pressure, the filter is clean)
    - the filter at the dishwasher on the water supply clean
    - the water level sensor (I assume it is the one in the interior at the outflow) has been cleaned and is clean
    - reset done
    - power switched off and connected
    And still the "h2o" error occurs.
    Request for advice. Maybe the sensor is broken ... I don't know anymore.
    Thank you in advance.
    Regards
    Matthew
  • #2 16816047
    MARCIN.SLASK
    Home appliances specialist
    Help: 1033
    Rate: 2642
    In a similar ADG 6200 model I had a damaged module. After repairing it, the dishwasher came to life.
  • #3 16816246
    mmazur
    Rate: 31
    Thanks for the info.
    The state at the moment is that after another reset of six (i.e. draining the water), after further flushing with clean water poured into the chamber, the dishwasher makes the first wash. I will not fail but maybe it helped.
    checkmate
  • #4 16816274
    MARCIN.SLASK
    Help: 1033
    Rate: 2642
    In my case, no voltage was applied to the solenoid when it was supposed to work.
  • #5 17095822
    mmazur
    Rate: 31
    The matter was very simple ... the drain pump blocked. A wire for closing bags has fallen into the rotor. How I got there I have no idea.
