App for Headphone Volume Balance Control: Mute One Channel & Adjust Channel Levels
jac_szcz 26643 8
  • #1 16821324
    jac_szcz
    Rate: 12
    I am looking for an app to balance the volume between channels in headphones ...
    To put it simply, I need to mute one handset (it's not about pulling one out of your ear ...)
    Thanks in advance for your help
  • #2 16821453
    gradek83
    Help: 930
    Rate: 2104
    The fact that one earphone sounds quieter is the earphones earwax wine that stuck the channel. Also, the music playback application should have this option.
  • #3 16821872
    jac_szcz
    Rate: 12
    Did I write that one of the headphones sounds quieter?
    I don't know why someone answers when they don't understand what they are reading ...
    Again.
    I am looking for an application that has options between the left and right headphones. It is about completely mute one channel.
    Playback program - spotify has no such functionality.
  • #4 16822233
    gradek83
    Help: 930
    Rate: 2104
    Volume Booster or Stereo Test in the play store search for such a name.
  • #5 16822285
    jac_szcz
    Rate: 12
    Volume Booster has no such function.
    Stereo Test, as the name says, is used to test the left and right channels, and that's it.
  • #8 16822492
    jac_szcz
    Rate: 12
    I managed ...
    Settings -? availability -? hearing
    There is left - right channel balance
    There was no application
    Regards
    And Poweramp actually has such a function but it is a program to play music from a file ... spotify works differently
    gradek83
    Help: 930
    Rate: 2104
    You didn't write anything that you meant spotif but you did it well
The discussion revolves around finding an application that allows users to balance headphone volume by muting one channel entirely. The original poster clarifies that they are not looking for solutions related to earwax or hardware issues, but rather a software solution. Several suggestions are made, including the use of ViperFX, which requires root access, and PowerAMP, which offers channel balance settings. However, it is noted that PowerAMP is primarily a music player for local files and does not integrate with streaming services like Spotify, which lacks the desired functionality. Other suggested apps, such as Volume Booster and Stereo Test, do not meet the requirements either.
