How Do Modern TVs Normalize Audio Volume Across Channels? Designing a Basic System
231 8
  • Basic approach to automatic audio level control
    #1 21673013
    Batuhan Batuhan
  • #2 21673014
    Neil Mula
  • #3 21673015
    Jeff Malcom
  • #4 21673016
    Richard Gabric
  • AGC circuit recommended for volume normalization
    #5 21673017
    Constantin Mogos
  • #6 21673018
    WilliamM Brooks
  • #7 21673019
    HVAC Parts Warehouse
  • #8 21673020
    Batuhan Batuhan
  • AVC explanation for automatic volume control
    #9 21673021
    Sambath Kumar
The discussion addresses the issue of inconsistent audio volume levels across TV channels and how modern televisions maintain uniform volume. The primary solution involves the use of Automatic Gain Control (AGC) circuits, which automatically adjust the gain of the audio signal to maintain a consistent output level despite varying input signal strengths. AGC works by detecting the amplitude of the incoming signal and applying a compensating gain to normalize volume. Additionally, Automatic Volume Control (AVC) is mentioned as a related concept specifically for audio volume stabilization. Some responses also suggest the use of audio compressors to achieve similar effects. The implementation may involve bandpass filters, microcontroller units (MCUs), and feedback loops that generate control voltages to regulate amplifier gain. The problem is distinguished from decoder-specific volume settings, which can also affect perceived volume changes between channels.
