Satel Integra WRL128: Remote Gate Control, Ethernet Module, Relay & Bell Button
andzuk 7470 3
  • #1 16826950
    andzuk
    I have an integra 128-wrl unit with an Ethernet module and an entrance gate, which I open (among others) with a bell button - a low-voltage cable short-circuited.
    I need to be able to open the gate remotely (via the Satela application). I would see it like this:
    After activating the input on the control panel, it generates a signal for 2 seconds and switches it off after two seconds.
    The output from the control panel is connected to a relay that closes the gate opening contacts.
    And now the questions:
    1.Can I use the standard output from the Satela control panel?
    2.Which relay should you buy to handle the short-circuit of contacts based on the signal from the control panel?
    Thanks in advance for your help.
  • #2 16827029
    dariusz.bembenek
    Stationary Alarms specialist
    Help: 455
    Rate: 615
    1. It is best to use any control panel low-current output programmed as 24. MONO switch
    2. Relay, e.g. AWZ510 (PU-1)
    The output described in point 1 correctly (i.e. deselect the timers, if they are not needed).
  • INT-ORS can provide OC output by grounding relay input
    #3 16830028
    andzuk
    Thanks for the answer.
    After a deeper analysis, it turned out that I do not have any vacancies - I have to buy an expander. And now there are a couple of options:
    - int-o and a pulsar relay
    - int-pp and pulsar relay (thanks to this I have additional inputs, which I also need for other purposes)
    -int-ors. This option is probably the most interesting, because I will be able to potentially connect 230V as well
    Just a question - from this int-ors I will be able to make OC output if needed? So connect the relay input to ground?
  • #4 16830139
    luk9753
    Help: 63
    Rate: 147
    Int-ors has no OC type outputs. Int-o also has relays only max 2A to control the gate is enough. With the switch, you choose whether it should be a relay or an OC type output
