Controlling two relays during encryption and decryption in the Satel Integra 128 system
duncerty 894 4
  • #1 19359029
    duncerty
    Hello, I have a satellite Integra system and I would like to switch on a relay for a short time (5sec) in one output when arming and switch on a second relay in the other output for a short time (5sec) when disarming.
    Please give me a quick answer on how I can install such a control.
  • #2 19359063
    sosarek
    Help: 9320
    Rate: 15532
    Well, why don't you have a look at the available output options (their types)? You will find what you need there.
    Z
    Pka, Poznań, 60-850
  • #3 19359103
    duncerty
    sosarek wrote:
    Well, why don't you look through the available output options (their types)? You will find what you need there.
    I have looked through , even tried , I have exhausted the possibilities and therefore decided to consult the forum .
  • #4 19359112
    sosarek
    Help: 9320
    Rate: 15532
    Well, you've been looking for something poorly....
    Write down what exactly you want to achieve.
    Z
    Pka, Poznań, 60-850
  • #5 19359340
    kood
    CCTV and Stationary Alarms specialist
    Help: 259
    Rate: 443
    105 roller shutter up with 5 secs will be activated for 5 secs when disarmed
    106 roller shutter down with 5 secs dwell time will be activated for 5 secs on arming
    Of course, control from inputs/timers/keypads should be deselected as required.
