Excessive Fuel Consumption in Toyota Corolla 1.4 VVTi 2003 at 11-12 Liters per 100 km
Takijedenzpwa699 7695 5
  • #1 16828872
    Takijedenzpwa699
    As the topic. My Toyota burns about 11-12 liters per 100 km. I change gears at 2,000 revolutions. Help, what to do, what should I check? I will add that I just bought the car.
  • #2 16829007
    ireneusz1981
    Level 19  
    Help: 27
    Rate: 83
    such a car as long as it has been standing and it can take the oil, check after 2-3 thousand km if the oil condition is correct. As for combustion, I would diagnose the operation of the lambda probe, temperature sensors and injection time. The compression pressure can be measured. I wonder what the mileage is and if anything has been done recently.
  • #3 16829024
    Takijedenzpwa699
    The mileage is less than 190 thousand. Unfortunately, I will not do it myself. So all that's left is to go to the mechanic.
  • #4 16829503
    ireneusz1981
    Level 19  
    Help: 27
    Rate: 83
    A friend has such a car, a friend recently bought it (a year ago) and it is burned like yours. The city with fuel consumption below 10l per 100km cannot be descended and comes out around 11.5, while the route is 6.8-8l / 100km. So when you are in the city, such burning will be.
  • #5 16829549
    kwok
    Level 40  
    Help: 496
    Rate: 1342
    The car weighs well over a ton and will eat - normal. A larger engine might reduce fuel consumption a bit, but you already bought a 1.4, maybe sell ...
  • #6 16829925
    ireneusz1981
    Level 19  
    Help: 27
    Rate: 83
    As I wrote, check if the oil is not consumed. Hardly ever, check how it is in your case. Best regards.
