Corolla Verso 2004: VSC, TRC OFF, Check Engine Lights & Potential Catalyst Issue
albertiniw 126502 17
What can cause VSC, TRC OFF and check engine lights in a 2004 Corolla Verso 1.8, and is the catalytic converter likely to be the problem?
Code P0420 means the ECU sees the catalytic converter efficiency as too low, but the same fault can also be caused by the rear lambda probe or its wiring, so the fault codes and live probe graphs should be checked before replacing the catalyst [#7092963][#7605195] If the waveform from the probe behind the catalyst looks too similar to the one before the catalyst, the ECU concludes the catalyst is not working properly; if the code points to a probe fault, inspect the probe and harness first [#7605195][#7604894] The fault often returns only after some distance because the catalyst monitor runs after specific driving conditions are met, so deleting the code does not fix the cause [#7092963][#7605195] Catalyst life cannot be stated precisely: one can last 400,000 km, while another fails at 35,000 km if the engine misfires and unburned fuel damages it [#7092963] In a similar Corolla Verso case, replacing the lambda probe fixed the recurring fault after about 150,000 km, so that sensor is worth checking if the catalyst itself is not clearly bad [#10925116][#10926635] Also ask the diagnostician to read the VSC/TRC error codes, because those lamps are linked to Toyota’s stability and traction systems [#7092963]
  • #1 7091797
    albertiniw
    Rate: 121
    coroll verso 1,8 benz 2004 and three lights came on while driving VSC, TRC OFF and yellow engine indicator light (check engine).
    After connecting to the computer, Fachman said that it could be from the catalyst, he deleted it and after some 60 km 3 lights came on again.
    What could be causing the problem? What is the service life of the catalytic converter? what can you do?
  • #2 7092798
    Doktorr
    Help: 287
    Rate: 1098
    What error codes have registered. What is the mileage of the car. What the diagnostician advised.
  • #3 7092899
    albertiniw
    Rate: 121
    mileage 190 thousand, the diagnostician found that the probe voltages are normal (within the limits) and suspected the catalyst, but if it's catal. shouldn't errors pop up right away after deleting ??
  • #4 7092963
    Doktorr
    Help: 287
    Rate: 1098
    I asked for error codes. If it is the fault of the catalyst, the readings of the second probe will not be correct. There are various errors with errors related to short-circuits of broken sensor cables, which "quickly" transmit their indications to the engine controller, most often they cannot be erased at all or they return immediately after starting the engine. in other cases, there must be a certain sequence of conditions under which the system will signal a failure. At the next visit to the diagnostician, please note the fault code and, if necessary, the message displayed by the diagnostic tester, the type of device used to check the vehicle. It would be wise to ask the diagnostician to check the current parameters of the device that the fault concerns and note these parameters.
    When it comes to the life of the catalysts, it is impossible to precisely determine because I know cases that the engine at 400,000 km had an efficient catalyst (without replacement), as well as another case that after 35,000 it broke down because the engine periodically did not burn for 2 cylinders and the fuel burned in the catalyst.
    By the way, the VCS indicator applies to Toyota's Vehicle Stability Control by Bosch and TRC traction control and I would suggest checking the error codes in these systems. The defect may turn out to be very prosaic, but without asking the drivers, I would not dare to suggest anything.
  • #5 7105372
    albertiniw
    Rate: 121
    so the error code is 0420, as it appears from other posts is a catalyst ???? I read somewhere that you can do something like a diagnostic probe emulator, what do you think?
  • #6 7604894
    dandi1976
    The same lights came on in my corolla verso r. 2004 1.8 petrol mileage 91700. After visiting the mechanic and connecting the computer, a damaged lambda probe was found (the computer showed a fault code saying that the probe was damaged and voltage measurements were taken for confirmation), which was then replaced. The lights came on again after driving about 60 km. Next visit to the workshop and connection of the computer - an error code saying that the second probe was damaged, the voltage measurements showed no damage, but I decided to replace the probe. After driving about 40 km, the lights came on again - a phone call to the mechanic, who said that now you need to check the harnesses for the lambda probe itself. Maybe someone has an idea what could be the reason for the lights - the computer spits out a code every time that the probe is damaged. After the last lighting of the lamps, I did not delete the error from the mechanic, but I removed the clamp from the battery, which cleared the errors. The lamps always turn on when I stand at the traffic lights for a while, they never came on when the car was moving. Do you recommend a good mechanic from Warsaw or the surrounding area?
  • #7 7604997
    korzen8989
    Rate: 16
    possible lambda probe
  • #8 7605195
    szczesiu13
    Code P 0420 means it's a catalyst! After deleting the error, it does not light up immediately, but only after driving a dozen or so kilometers, especially on the route at an equal speed. I catch this error longer while driving around the city. The probe plots in front of the catalytic converter are similar to those behind the catalytic converter, which tells the engine control unit that the catalytic converter is not working as it should. The probe downstream of the catalyst should have a different graph compared to that of the pre-catalytic converter. Compare the charts.
  • #9 7611043
    kosmoskosmos
    Rate: 27
    I came across the topic by accident. As a curiosity, I would like to mention that in my corolla verso also the above-mentioned lights were on, until the visit to the automatic car wash :)
  • #10 7873168
    albertiniw
    Rate: 121
    maybe someone has a photo of lambda probe charts before and after the catalyst ??
  • #11 8058153
    stochlik
    Rate: 8
    I am attaching a couple of lambda probe charts. Corolla E12 4ZZ. Every 500km error P0420 pops up - catalyst capacity is below the minimum. Judging by the charts, the kat is to be replaced, mileage 180 thousand. B + G. Maybe someone knowledgeable about things can determine if the catalyst is for replacement. Symptoms: no power above 3000 rpm.
  • #12 8115664
    albertiniw
    Rate: 121
    Well, unfortunately, you cannot see the lambda probe charts, and is the second probe (diagnostic) chart completely constant? what does it look like?
  • #13 8115700
    stochlik
    Rate: 8
    The chart is probably visible. Blue color - 1st probe, yellow - 2nd probe. Time-varying waveforms.
  • #14 8118216
    albertiniw
    Rate: 121
    I mean, they are not there at all, maybe, buddy, give it another try?
  • #16 10925116
    rrobertn
    Rate: 11
    What should be the voltage on the lambda probe I in Toyota Corolla Verso II, year 2007, because I do not know if the model described here is I or II.
    I had a similar problem as the one described above, every 50-60 km, the emergency mode turned on for me, it was helped by the replacement of the lambda probe, which fell after 150,000 km. Replacement of the Toyota service around PLN 800.
    greet Robert
  • #17 10926635
    rrobertn
    Rate: 11
    I was on Toyota service today. The first lambda probe for me has 1Volt
    greet Robert
  • #18 11289924
    darek72
    Rate: 28
    I put something like this in my coroll.
    Link
    And the problem with the head of the p420 does not pop up anymore.
    Darek
The discussion revolves around a 2004 Toyota Corolla Verso experiencing simultaneous illumination of the VSC, TRC OFF, and check engine lights. The user reports that after a diagnostic check, a potential catalyst issue was identified, specifically error code P0420, indicating low catalytic converter efficiency. Various responses suggest that the problem may stem from a faulty lambda probe, as multiple users have encountered similar issues with their vehicles. Recommendations include checking the lambda probe voltages, examining wiring harnesses, and considering the replacement of the catalytic converter if necessary. The lifespan of catalytic converters varies significantly, with some lasting well over 400,000 km, while others may fail sooner. Users also discuss the possibility of using diagnostic probe emulators as a workaround.
