Sony vaio PCG-71811m - 6 drivers do not work, does not search the internet.
Ildiavoloe 11310 10
How can I install the missing drivers on a Sony Vaio PCG-71811M after reinstalling Windows 7 so the wireless network and other devices work again?
Install the correct drivers for the exact Vaio variant, using the model number from the sticker on the bottom of the laptop and the hardware IDs from Device Manager [#16829350][#16830453] For the network controller with ID PCI\VEN_168C&DEV_002B, download the AR9285 Windows 7 x64 driver, unpack it, and update the driver by pointing Device Manager to the unpacked folder [#16830503][#16830591] The PCI device with ID PCI\VEN_10EC&DEV_5209 is the card reader, and the missing Bluetooth device USB\VID_0489&PID_E027 can be installed from the extracted driver package rather than by running the EXE directly [#16830453][#16830503] When doing manual updates, select the option to include subfolders and make sure you search for the driver version that matches Windows 7 64-bit [#16828993]
  • Manual driver install from Sony package failing
    #1 16828959
    Ildiavoloe
    Hello. I have to warn you that I am dark when it comes to such computer crap. Today, after quite a long break, because for 2 years, I turned on the laptop, it does not turn on properly, only in? Bios? Options pop up like, network enable, boot etc, you probably know what's going on :) How have I managed to recover the system from two years ago, another error appeared - no internet, does not search the network from the router, in? program? With driver updates a triangle pops up next to: generic Bluetooth adapter, pci device, network controller, pci simple communications controller, system management bus controller, ethernet controller. I downloaded these drivers from the Sony website, typing each separately in googles + "sony Vaio pcg71811m, pasted on the desktop and when clicking on the driver update I set a manual search from the desktop but in vain. program compatibility that this program may not be installed correctly -> click reinstall using the recommended settings -> allow and no response
    If you could, I would ask for detailed help, because I know nothing about it, and I want to repair it. Thank you very much and sorry that I described it probably not very succinctly and to the point :)
    DejoDejo
    Help: 35
    Rate: 75
    When searching for drivers, you must also enter the system version, manual driver updates should be selected next to "include subfolders" ;)
  • #3 16828999
    Ildiavoloe
    I downloaded according to the system, Windows 7, 64 bits, I also selected subfolders but nothing :(
    DejoDejo
    Help: 35
    Rate: 75
    When downloading drivers for Vaio, apart from the model name you provided, you also need the number provided on the bottom of the laptop, e.g. VPCEH2D1E
  • Hardware IDs for missing Wi‑Fi, PCI and Bluetooth drivers
    #6 16830453
    Ildiavoloe
    Okay, I connected the phone to my laptop and turned on tethering, I downloaded some of the ones I had at the beginning, but still the most important, probably responsible for them, wifi search, that is:
    NETWORK CONTROLLER I provide hardware identifiers
    PCI \ VEN_168C & DEV_002B & SUBSYS_E037105B & REV_01
    PCI \ VEN_168C & DEV_002B & CC_028000
    and PCI DEVICE
    PCI \ VEN_10EC & DEV_5209 & REV_01 & SUBSYS_908B104D
    PCI \ VEN_10EC & DEV_5209 & SUBSYS_908B104D
    PCI \ VEN_10EC & DEV_5209 & CC_FF0000
    and the last GENERIC BLUETOOTH ADAPTER
    USB \ VID_0489 & PID_E027 & REV_0001
    USB \ VID_0489 & PID_E027 with bluetooth this is displayed to me
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    To Wifi (network controller) download e.g. from here:
    https://www.ath-drivers.eu/download-driver-fo...os-chipset-with-id-37-and-Windows7-64bit.html
    Card reader (pci device):
    http://www.realtek.cz/realtek-download.php?realtek=RTS5208&system=6
    Bluetooth:
    https://drp.su/en/hwids/USB%5CVID_0489&PID_E027?os=windows-7-x64 click on Download Driver, unpack the downloaded exe file with 7zip and install from the device manager. Don't just run this exe file!
  • #8 16830574
    Ildiavoloe
    I downloaded the driver for the network controller, but there is a folder and a system file ".sys", I have no idea how to install it
    pci made it! Hurrah
    bluetooth installs as you wrote, there is no exclamation mark for a moment, but unfortunately only a moment because the error mentioned above pops up again: code 43
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    On the page you click on:
    Download driver
    AR9285 / 10.0.0.336
    After downloading, unpack and install from the device manager by selecting driver updates and pointing to the directory with unpacked drivers.
  • #10 16830654
    Ildiavoloe
    The internet works thank you, you are an angel :)
  • #11 16830658
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    As for bluetooth, it is best to download it from the Sony website, along with the software.
The user experienced issues with their Sony Vaio PCG-71811M laptop after a two-year hiatus, specifically with driver malfunctions and no internet connectivity. They reported problems with several drivers, including the network controller and Bluetooth adapter. Suggestions included ensuring the correct Windows version was selected when downloading drivers, using hardware identifiers for precise driver searches, and manually installing drivers through the device manager. After following the advice and downloading the appropriate drivers, the user successfully restored internet connectivity, although Bluetooth issues persisted with error code 43.
