  • A custom full Dual Mono Class A integrated amplifier combines a phono preamp, Bluetooth, DAC, control logic, and speaker protection in a Modushop 1NPD02300B enclosure.
  • The phono stage uses a FET-input circuit inspired by Pioneer and Denon designs, and the power amplifiers are redesigned from the Pioneer A-09 with current, inexpensive transistors.
  • The build took seven months, and the DAC uses Cirrus Logic CS4334 converters with DIR9001 SPDIF decoders and a 4052 source selector.
  • Startup was mostly straightforward: the analog section needed only offset and bias adjustment, and the finished amplifier sounded clearly better than the earlier GainClone and Vincent.
  • The 30 cm-deep case left very little space, the heatsinks run around 75 degrees, the subtitles are too dim, and the DIR9001 needed delayed Reset timing to start correctly.
  • Elegant audio amplifier with aluminum front panel and central knob.
    By way of introduction:
    The amplifier is visually very similar to the Gamut design. It's a coincidence. Wanting to build an amplifier, I was looking for a damaged enclosure donor. The housing of the Koda AV-600X receiver caught my eye, but the knob was asymmetrically placed. I didn't find anything interesting, I started to draw something similar to this pattern myself, but with a symmetrically placed knob. There were many iterations until an almost final form emerged, very similar to the present one. Then I accidentally came across the Gamut DI 150 amplifier and noticed that it looks almost identical to the amplifier in my concept. I began to hesitate whether to change my idea to something else, because it is someone's technical idea, someone's industrial design. I started to study the regulations in this direction and it turned out that the law allows the use of an industrial design for personal use, so a stone from my heart and I started to act.
    The inspiration for the new amplifier was the occasional purchase of the Vincent SV-121 amplifier and comparing its sound with my existing amplifier, described in this topic:
    https://www.elektroda.pl/rtvforum/topic3780837.html
    It turned out that acoustically Vincent is several classes above. Unfortunately, Vincent does not have a signal output, BT and, most importantly, a phono preamplifier.
    This is where the search for an interesting scheme, design and construction began.
    The amplifier was built for seven months.
    Its design consists of separate plates of individual modules, so that you can easily upgrade, upgrade, etc.
    Everything was packed into the 1NPD02300B housing purchased from modushop.
    The input selector board is integrated with the phono preamplifier. In the phono preamplifier I used a circuit known from more expensive Pioneer and Denon designs with FET transistors at the input. The sound from this circuit is clearly better than the circuits I've made before (including the Emerald circuit, praised on the web).
    The board also has a signal output buffer for driving the previously presented Equalizer on IN-9 tubes.
    Scheme and selector board (for one channel) below:
    Schematic of an amplifier circuit board with a phono preamp.
    Amplifier PCB design.
    The preamplifier is a slightly modified circuit taken from the following source:
    https://www.electroschematics.com/class-a-preamplifier/
    Diagram of one channel and board below.
    Electronic schematic of a single amplifier channel.
    PCB layout of an amplifier showing traces and components.
    The power amplifiers are based on the Pioneer A-09 scheme, but they have been redesigned to use currently available and cheap transistors. The board has been designed to be screwed together with the transistors on the heat sink.
    Below is the schematic and PCB for one channel.
    Schematic and PCB layout of an audio amplifier for one channel.
    Audio amplifier PCB design with integrated circuit.
    The amplifier additionally has a Bluetooth receiver and a DAC also working in Dual Mono. The DAC board has been designed in such a way that it can be screwed onto the PA214 Bluetooth receiver (bought on a well-known Asian website).
    The signal in the SPDIF format is fed from Bluetooth to the DAC board. There, through the 4052 multiplexer, one of the three SPDIF (Coaxial / Optical / Bt) sources is selected, whichthen, through optocouplers, it is fed to SPDIF decoders independent for each channel, and from there to converters.
    The "primary" side of the DAC (Bluetooth receiver, selector, Toslink receiver) is powered from the power supply of the digital part, the "secondary" side (SPDIF decoders, converters) - from the output of the audio power supply switched on with a relay.
    The DAC is based on the Cirrus Logic CS4334 converters, because they are one of the few that can still be purchased on the market, and they are also easy to use.
    Amplifier schematic with digital processor and power supply circuits.
    PCB design for an amplifier with a Toslink module.
    The amplifier's control section is not too complicated and was designed parallel to the front panel to handle the backlight, buttons, have a hole for the potentiometer axis, etc. It is based on the Atmega16 microcontroller.
    A 10x5mm model bearing with a flange was fitted into the hole for the potentiometer axis, through which the potentiometer axis with a diameter of 5 mm passes. The bearing is the fulcrum of the axle.
    Effects below.
    Control board:
    Schematic diagram of an amplifier with various modules and connections.
    Printed circuit board design for an amplifier with electronic components.
    Aluminum front panel of the case:
    Sketch of the front and rear panel of a DIY amplifier.
    Panel with illuminated inscriptions under the glass (with a cutout for the IR receiver and the axis:
    Amplifier panel design with symmetrically placed knob.
    The control section is powered from a stand-by power supply connected to the power transformer switching system and soft-start.
    It is presented below:
    Power supply schematic for the digital section and transformers in the amplifier.
    Printed circuit board schematic with electronic components, traces, and connectors.
    The audio part is powered by the power supply system with independent circuits of power transistors, power stage voltage amplifier and preamplifier. In addition, through the relay, the DAC and BT are powered. The relay turns on only when selecting digital sources, so when playing audio from other sources on the DAC and BT, no voltage is applied.
    The audio power supply is shown below and is one of the two channels. The tile of the second channel is a symmetrical reflection.
    Circuit diagram of power supply for preamplifier and Bluetooth module.
    View of a printed circuit board design with red and blue traces.
    And finally, the speaker protection board. This protection is supervised by the microcontroller that controls the amplifier and is screwed directly to the loudspeaker terminals.
    Electrical schematic of an amplifier circuit.
    Audio amplifier PCB design.
    In general, the launch did not cause any major problems. The analog part started right away. only adjustment of the offset, transistor currents was required and it was possible to twist. The mechanical part turned out to be a big problem due to the use of a slightly too small housing. On paper, everything was nice to fold, but in reality it was not so colorful. The housing also required a few modifications, especially the way the radiators were screwed to the frame.
    In terms of electronics, I had the biggest difficulties with starting the DAC. The reason was my negligence, because I downplayed the requirement to delay the Reset pin relative to the power supply in the DIR9001 chip. It took me several hours to figure out what the source of the problem is. Using an inertial system on the Reset pin solved the problem.
    Below are some photos of the construction.
    Amplifier printed circuit board on a black base. Printed circuit board with electronic components on an amplifier heatsink. Interior of an audio amplifier with visible electronic components. Interior of DIY amplifier showing circuit boards and electronic components Interior of a custom audio amplifier with visible transformers and electronic components. Interior of an open audio amplifier with visible electronic components and heatsinks. Interior of an amplifier with visible components and connectors. View of the interior of an amplifier with an open casing, showing electronic components and cooling. Audio amplifier in a silver and black case on a wooden desk. Audio system on a shelf with an amplifier, CD player, and turntable. Silver audio amplifier with centrally placed knob on the front panel.
    I also add a video showing the operation of the amplifier icon illumination:
    The amplifier, as in class A, heats up mercilessly:
    Thermal image showing an electronic component with measured temperature. Thermal imaging of an electronic amplifier interior. Thermographic image of two toroidal transformers inside an audio amplifier Thermal image of an amplifier interior showing heat distribution. Thermal imaging of a DIY amplifier on the floor. Thermal image of a DIY amplifier showing temperature distribution. Thermal image of an amplifier showing temperature distribution.
    problems
    - low brightness of the subtitles backlight - they were etched on the PCB and covered with a black soldermask. Unfortunately, this is not the best solution and I am in the process of looking for something else. If you have any ideas - please give me a hint :)
    - very little space inside - I chose a casing with a depth of 30 cm. On paper everything fit, in reality it would be much better to use a larger housing,
    - too small radiators - the amplifier heats up to about 75 degrees. I wish I had taken a 3U case
    - drifting with the temperature offset - the offset must be set on a well-heated amplifier.
    Sound - no comparison to anything I've had before :) Previous GainClone or Vincent are far behind.
    Regards!
    Maciek_C
    Maciek_C wrote 249 posts with rating 255, helped 14 times. Live in city Elbląg. Been with us since 2016 year.
  • #2 20661367
    Jogesh
    Help: 33
    Rate: 688
    Beautiful construction.
    As for subtitles, there are two methods:
    1. Taking on photographic film. There are digital platesetters for film. Maybe someone who prepares stencils for offset printing using the old method offers such services.
    2. Spray paint thin plexiglass black and burn the paint with a laser.
  • #3 20661407
    katakrowa
    Help: 9
    Rate: 855
    Very nice! I admire that you wanted to make "mirror" tiles.
    You can easily sell for PLN 14,999 :-)
  • Critique of amplifier module mounting and labeling method
    #4 20661410
    CMS
    Help: 258
    Rate: 2601
    The construction of beauty. However, I don't like one thing, actually two, because these are two amplifiers in one housing. It's about the way of mounting plates with power amplifiers. While it takes up little space, in the event of a failure, to replace one transistor, you have to unscrew the entire plate from the heat sink.
    I like the amber backlight. I remember how over 20 years ago I bought a fancy video recorder (which I used as a TV tuner with stereo sound, and it didn't play even 10 cassettes) and had a blue display. And since my Yamaha equipment has amber displays, the day after I bought it, I disassembled the VCR to see how to change its color. It turned out that the display actually glows green, and the blue was achieved with a purple filter. And imagine that I went to a store with supplies for advertisers, bought several different transparent foils and a piece of smoked plexiglass in the size of the display and messed around until I got the same color of the VCR display that the Yamahas had.
    As for the inscriptions, print with a laser on foil (only buy a foil dedicated to lasers, because the one for an inkjet printer can melt and you will break the printer) in negative and that's it.
  • Backlight matrix needs black soldermask for visible labels
    #5 20661442
    Maciek_C
    Help: 14
    Rate: 255
    Thank you friends for the kind words :)
    You do not need to unscrew - removing the transistors is not a problem, and to insert a new one, just slightly hook the ends of the legs. Checked ;)
    The only problem would be to replace the temperature compensation transistor, two capacitors and two mounting potentiometers. Everything else can be replaced from above.
    As for, let's call it, the backlight matrix, the main problem is that when the backlight is off, the inscriptions are invisible behind the glass. I tried with foil and plexiglass, but the print on the laser foil was piercing and the inscriptions on the plexiglass were visible from under the glass. Therefore, these combinations with black soldermask.
    Regards!
    Matt
  • #6 20661524
    CMS
    Help: 258
    Rate: 2601
    Maybe white paper with the same negative print between the foil and the glass?
    And possibly delicate white LED backlight during the day.
  • #7 20662004
    bodzioluban
    Help: 9
    Rate: 24
    The construction is ok, but aren't they sometimes ready-made modules or for self-assembly? But it looks nice.
  • Need a brighter backlit label panel solution
    #8 20662108
    Maciek_C
    Help: 14
    Rate: 255
    1. Taking on a photographic film. There are digital platesetters for film. Maybe someone who prepares stencils for offset printing using the old method offers such services.
    Thanks, I'm looking into it :)
    Could you expand on the idea? I can't visualize it in my head.
    Are you asking if I didn't use ready-made layouts or couldn't I use ready-made ones available on the net instead?
    If it's the former, then no - I designed all the boards myself and had them made at JLCPCB. The only ready-made is the Bluetooth module, screwed to the DAC board.
    As for the housing, it is a finished product from modushop. At modushop, holes were cut in it according to my design (based on technical drawings sent to them).
    I want to achieve the same effect as the current one (photos below), only that much more light would pass through it (this soldermask "cuts out a lot of light").
    Class A amplifier, full Dual Mono Class A amplifier, full Dual Mono
  • Requesting dimensions to model and print the glass
    #9 20662259
    LemuRR 11
    Help: 37
    Rate: 447
    Prepare a 3D model of this glass so that the inscriptions are protruding (approx. 1 mm). Then find someone with a resin printer who will print it for you in transparent resin. The next step will be to pour the top layer (the one with inscriptions) with black resin. After complete hardening, polish the top layer so that the inscriptions emerge, and then pour the top layer with a slightly smoky resin (mix with pigment, such resins are available).
    What are the dimensions of this item? Maybe I can help ;)
  • Asking about transformer cooling and supply specs
    #10 20662323
    kris8888
    Help: 537
    Rate: 1930
    Great and thoughtful design, I'm impressed. Almost like it came from the factory. The only thing that puzzles me is that, due to the fact that the whole thing gets quite hot, is it right that the transformers are completely covered with a screen, which probably additionally increases their temperature.
    And the two smaller toroidal transformers mounted vertically look like they were placed loosely, but it's probably due to lack of space.
    With what supply voltage and what terminal current does it work? How much power can it deliver to the load and with what impedance?
  • #11 20662595
    efi222
    Help: 12
    Rate: 1220
    Beautiful design. I always admire my own audio equipment.
    When it comes to pictograms, I have been etching them on laminate for years. It's just that the laminate should be thin. Within 0.4, 0.6mm. Most of them are covered with dark glass with a tint of about 50% and the effect is very good. Have a look at my projects.
  • #12 20662758
    CMS
    Help: 258
    Rate: 2601
    I got the idea that you want the subtitles to be visible when they are not highlighted. :) And you want the opposite. My mistake.
  • Transformer temperatures measured at 48°C with convection openings
    #13 20662842
    Maciek_C
    Help: 14
    Rate: 255
    The dimensions of this tile are 74x154. As for 3D, I only have AutoCad and 3D modeling is a pain in the ass, but I'll try to prepare something tonight or tomorrow, thank you :)
    That is why the openings through which the wires are led out are enlarged, and a recess is cut out in the mounting plate, near the front panel. This creates convection that exchanges air under the screen. Transformers heat up to about 48 degrees (checked with a thermal imaging camera). The transformer of the digital and standby section reaches a higher temperature when listening to Bluetooth :)
    Exactly, no space and the need to mount "edgewise" :( as I wrote in the description, I regret not taking a larger case.
    The voltage of the terminals is 2x28V DC. The quiescent current of one branch is 375 mA, i.e. a total of 1.5 A per channel.
    This gives 2x35W into 8Ω and 2x70W into 4Ω :)
    I saw this method once on an electrode (it's very possible that in one of your devices :) ) and I wanted to do the same. Unfortunately, in Elbląg, 3 glaziers had windows with a maximum tint of 30% and this turned out to be too weak, hence the idea to use a soldermask (note that the hole for the IR receiver is very visible at a certain angle). This solder mask restricts the light too much.
    Maybe the key will be, as you say, getting a much darker glass and peeling off the soldermask :)
  • #14 20663076
    E8600
    Help: 529
    Rate: 2520
    It's been a long time since there was such a refined structure on the forum. I wonder how long it took from the idea to the implementation of such a miracle?
  • 74x154 tile dimensions and SVG drawing request
    #15 20663208
    LemuRR 11
    Help: 37
    Rate: 447
    Insert a drawing in SVG format, I'll convert it to a 3D model in a few moments. I will also try to print, but I do not promise success, because the working field of the printer is "on contact".
    As for dimming, self-adhesive films for tinting windows are available on Allegro. Similarly, 3 mm plexiglass can be purchased with quite low permeability.
  • #16 20663210
    mmaker
    Level 19  
    Help: 28
    Rate: 162
    I used to etch such inscriptions on a 0.3 mm laminate and put 3 mm smoked plexiglass on the front. It worked. If it's supposed to be glass, aim for tinted car window film. You probably have every 5 or 10% tones.
    In addition, a very nice amplifier, I was aiming for some class A myself, but I think I'm too old for such toys ;)
  • #17 20663375
    nyquist
    Help: 76
    Rate: 192
    A fine piece of work! I admire and envy ;)
    Out of curiosity, a question - what did you shield the power transformers with? Is it permalloy or plain copper?
  • Steel and brass used to shield the power transformers
    #18 20663412
    Maciek_C
    Help: 14
    Rate: 255
    Thank you guys for your kind words and good advice :)
    Buddy LemuRR 11, I am very grateful for your willingness to help, but I don't want to bother you for now - I will try what you suggested first, i.e. I will remove the black soldermask from the current PCB and darken the glass with foil. If I fail at this, I will turn to You for help. Many thanks again!
    I started working on it at the end of November, finished it a week ago, spending about 6 hours a week on it.
    There is 0.3mm brass sheet on top for appearance, there is 0.7mm steel sheet underneath as magnetic screen :)
  • Custom-cut Antisol glass as a cleaner front panel solution
    #19 20663469
    efi222
    Help: 12
    Rate: 1220
    Let me have a "three cents" on tinted glass.
    Just like my colleagues, I covered plexiglass with foils, but something was always wrong. And this is a bubble, and this is some kind of scratch on the plexiglass and other artifacts (maybe I can't do it right).
    I'm done with it. I now order glass by mail order from a glazier from Gdańsk. The guy cuts to size, polishes the edges and his prices are also friendly. Such lenses really look "pro". Flawless surface. In the photos there is Antisol black 6 mm (there is also 4 mm with less darkening).
    The disadvantage of Antisol 6 mm is the limitation of IR to about 3 m.
    Fast lying directly on the ground.
    Tinted Antisol glass lying on a white sheet of paper.
    A few centimeters moved away.
    Tinted glass Antisol black 6 mm resting on white and wooden surfaces.
  • #20 20665089
    gdkj
    Help: 49
    Rate: 84
    Out of curiosity, C102 = 100µF/25V. Why so much value?
  • #21 20665509
    pikarel
    Help: 410
    Rate: 1852
    Beautiful construction, perfect workmanship, but for me it's too much steam in the whistle (I grew out of the A class several decades ago, along with the ClassA of a certain Japanese company).
    It results from the time constant for the lowest frequencies (look at how low the resistance value of the resistors connected to ground is).
  • #22 20666205
    gulson
    System Administrator
    Help: 150
    Rate: 6122
    Beautiful design, if you write to me in a parcel locker, I will send a small gift.
  • #23 20667391
    Olkus
    Level 32  
    Help: 132
    Rate: 918
    A great amplifier, everything is refined, the elements are mainly of good quality. Just congratulations ;)
    Regards,
    AND.
  • #24 20671157
    robert123
    Help: 13
    Rate: 25
    I have a question about the potentiometer - I can't read its markings from the photos - what model is it (producer I suspect Alps)? Can a colleague share the pcb source file of the preamplifier itself? Alternatively, I would buy such a pcb if it was left.
    I will also ask about the value of C104, C105 in the phono preamp, is there really 4µ7? Congratulations on a great build and best regards.
  • Corrected capacitor value to 4.7 nF
    #25 20672089
    Maciek_C
    Help: 14
    Rate: 255
    The potentiometer is RK271 Alps 2x50k
    I ordered the boards at JLCPCB, and there the minimum is 5 pieces, so I have them left for at least another such amplifier (there are 3 pieces of power amplifiers and selectors left, and 4 pieces of all others) - if anyone is interested, please contact me via PM (I don't want to make money from this, so I'll be fair to take 1/5 of what I paid for each tile).
    Of course, I can also easily share gerberas, eagle files or microcontroller code - here, too, I am asking for information on PW.
    This capacitance is obviously a mistake, it should be 4.7 nF.
    Regards
    Matt
  • #26 20672617
    OTLamp
    Tube devices specialist
    Help: 335
    Rate: 518
    Maciek_C wrote:
    and 2x70W into 4Ω
    But rather far from class A. Have you measured other key parameters such as non-linear distortion, intermodulation distortion, frequency response?
  • Reducing quiescent current to cut heat and offset drift
    #27 20672649
    kris8888
    Help: 537
    Rate: 1930
    Maciek_C wrote:
    Problems [...]
    Isn't it better to reduce this quiescent current a bit? From what you have given, it follows that almost 170 W is unproductively converted into heat, and only in the power amplifiers themselves. But that's a lot. If this quiescent current were halved, it would still have a high value, the amplifier would work in the deep AB class (more A than B for small drive), the level of distortion would still be very low, and problems with this unstable offset and temperature would be eliminated.
    Well, unless you really care about an additional electric heater in the room.
  • Class A achieved, now tuning quiescent current
    #28 20673453
    Maciek_C
    Help: 14
    Rate: 255
    OTLamp wrote:
    Maciek_C wrote:
    and 2x70W into 4Ω
    Exactly - in full class A the amplifier works up to about 32W at 8Ω and 18W at 4Ω (determined on the basis of the current shape of the emitter resistors). Later it goes to AB.
    I did not measure the distortion - I have nothing to measure it with (an 8-bit oscilloscope will not be reliable). At full drive, the -0.5dB drop came out at 21kHz. I did not check for -3dB.
    The assumption was to make a class A amplifier and it was achieved ;) now it's time for combinations with quiescent current and other improvements :)
  • Dynamic biasing extends class A operation range
    #29 20673527
    kris8888
    Help: 537
    Rate: 1930
    But even these 375mA of quiescent current for a single power transistor now does not cause the amplifier to operate in class A for its full drive range. There is a power threshold at which one of the branches is cut off at the expense of an increase in the current in the other. It's a matter of determining what output power you are interested in working in a pure class A amplifier. Because listening at home with a power of even, for example, 30W with low-efficiency columns still gives a big impression of volume. Therefore, it is enough to set the pure class A threshold at a relatively low level, sufficient for normal listening, and to amplify the events with an AB class amplifier.
    There are some system solutions, e.g. Pioneer used them in their amplifiers, where the quiescent current is dynamically increased as the drive increases, and it is increased only in the branch that is trying to cut off at the moment. This actually causes the amplifier to work in pure class A in the full power range and at the same time it is not an additional radiator in the room.
  • Questions on offset, power ratings, and class A measurements
    #30 20687667
    aaanteka
    Help: 729
    Rate: 1194
    I have a few questions regarding the design in terms of electronics:
    Maciek_C wrote:
    was only required offset adjustment transistor currents
    Maciek_C wrote:
    offset drifting with temperature - the offset must be set on a well-heated amplifier
    1) What and how do you regulate the offset?
    2) What is its initial value and what is its drift?
    3) For what operating parameters (conditions)?
    Give this 2x35W by 8 ohms and 2x70W by 4 ohms
    4) Where did these power values come from?
    5) Calculated, physically measured?
    6) For what purpose did you do it?
    7) Why this way?
    8) What is the total gain of the sound path from the input to the output of the amplifier?
    Maciek_C wrote:
    in full class A, the amplifier works up to about 32W at 8Ω and 18W at 4Ω (determined on the basis of the current shape of the emitter resistors)
    9) Can you explain the idea behind the mentioned measurement/determination based on the shape of the current?
    10) What shape are you writing about?
The discussion revolves around the design and construction of a Class A amplifier with a full dual mono configuration. The creator initially used a Koda AV-600X receiver enclosure and aimed for a design similar to the Gamut DI 150 amplifier. Participants praised the aesthetic and technical aspects of the build, discussing various methods for achieving effective backlighting and visibility of inscriptions on the front panel. Concerns were raised about the heat management of the transformers and the quiescent current settings, with suggestions for optimizing performance and reducing heat generation. The creator confirmed the use of custom-designed PCBs and shared details about the amplifier's specifications, including power output and component choices. The conversation also touched on the potential for future improvements and measurements related to distortion and performance.
TL;DR: With 2x28V DC rails and a builder-verified "about 32W at 8Ω" in pure Class A, this FAQ helps DIY audio builders understand a full Dual Mono amp with modular boards, relay-switched digital power, and a DAC reset bug that blocked startup until Reset was delayed. [#20673453]
Why it matters: This build shows how to combine Class A sound, upgradeable module design, and practical troubleshooting in one custom integrated amplifier.
Alternative What it achieved Main drawback reported
PCB with black soldermask under glass Labels stayed hidden when off Passed too little light
Etched thin laminate + smoked plexiglass Proven workable by multiple users Needs darker cover material
Tinted glass Most "pro" finish and cleaner surface Can reduce IR range
Laser-printed film on foil Simple and cheap Print could show through
Key insight: The strongest lesson is thermal and mechanical planning. The electronics started easily, but the 30 cm chassis and undersized heatsinks pushed temperatures to about 75°C and made the build much harder than expected.
  • Power rails were 2x28V DC, with 375 mA per branch and 1.5 A total quiescent current per channel. The builder calculated 2x35 W into 8Ω and 2x70 W into 4Ω, then checked that practice gave a few watts more. [#20662842]
  • Pure Class A operation was not full-scale. The builder later estimated about 32 W into 8Ω and 18 W into 4Ω before the stage moved into AB operation. [#20673453]
  • Thermal behavior was the main hardware limit. The chassis reached about 75°C after 1 hour of moderate playback into speakers in a 23°C room. [#20687891]
  • The front-panel insert measured 74 x 154 mm. Suggested label solutions included etched 0.3-0.6 mm laminate, smoked plexiglass, tinted glass, and window-tint film. [#20663210]
  • The control section used an Atmega16, and the volume control was an Alps RK271 2x50k potentiometer. Spare JLCPCB boards, Gerbers, Eagle files, and MCU code were offered privately. [#20661024]
What does a full Dual Mono amplifier design mean, and what advantages does it bring in a Class A build?
A full Dual Mono design means the left and right channels are built as largely separate signal and power paths. In this build, each channel has its own mirrored audio supply board, and even the DAC works in Dual Mono. That separation reduces shared supply interaction, simplifies channel-by-channel servicing, and fits the builder’s modular upgrade goal in a hot Class A amplifier. [#20661024]
How was this Class A amplifier divided into separate modules, and why does that make future upgrades easier?
It was split into separate boards for input selector and phono stage, preamp, power amp, DAC, control, standby and soft-start, audio power supply, and speaker protection. The builder explicitly said the design uses separate module plates so parts can be upgraded or replaced easily. That modular layout also let him mirror one channel and keep digital, control, and audio sections physically distinct. [#20661024]
Why did the DIR9001 DAC chip fail to start correctly, and how do you delay the Reset pin relative to the power supply?
The DIR9001 failed because Reset came too early relative to the supply voltage. The builder said he underestimated the need to delay the chip’s Reset pin, which cost him several hours of debugging. He fixed it by adding an inertial delay circuit on Reset, so power stabilized first and the SPDIF receiver then started correctly. [#20661024]
How do you determine when a Class A amplifier based on the Pioneer A-09 topology leaves pure Class A and starts working in AB?
You determine it by watching output-stage current behavior as drive rises. 1. Load the amp with 4Ω or 8Ω resistors and feed a sine wave. 2. Measure voltage across the emitter resistors while increasing output. 3. Mark the point where emitter current at the sine peak no longer stays clear of zero and begins to deform. The builder used that method and estimated the transition near 32 W at 8Ω and 18 W at 4Ω. [#20687839]
What output power can this 2x28V DC amplifier deliver into 8Ω and 4Ω, and how were those values calculated and checked?
It can deliver about 2x35 W into 8Ω and 2x70 W into 4Ω. The builder said those values were first calculated with margin for bridge drops and ripple, then verified practically and came out a few watts higher. He also stated the amplifier runs from 2x28V DC rails with 375 mA quiescent current per branch. [#20687839]
How do you adjust DC offset in this power amplifier, and why does the offset drift with temperature until the amp is fully warmed up?
You adjust DC offset with potentiometer R9 on the power-amplifier board. The builder set the amplifier to about -100 mV when cold, which moved to about +20 mV after warm-up. The drift matters because this Class A design runs very hot, so transistor operating points shift with temperature until the chassis and output stage stabilize. [#20687839]
What is DC offset in a power amplifier, and why is offset drift a concern in a hot-running Class A design?
"DC offset" is a power-amplifier output condition that leaves a steady DC voltage at the speaker terminals, instead of a zero-centered audio-only signal, and its key characteristic is that heat can shift this voltage as transistor conditions change. In this build, offset moved from about -100 mV cold to +20 mV hot, so the builder had to set it on a fully warmed amplifier. [#20687839]
Which transistors were used instead of the original Pioneer A-09 parts, and how well do TIP3055 and TIP2955 fit this redesign?
The builder confirmed he used the transistors shown in his redesign, including TIP3055 and TIP2955 as the output devices. He also stated the Pioneer A-09-based stage was redrawn around cheap, currently available parts. In practice, the analog section started immediately and only needed current and offset adjustment, which suggests the TIP3055/TIP2955 pair fit the redesign functionally. [#20687891]
What is SPDIF, and how was it routed here between the Bluetooth module, 4052 multiplexer, DIR9001 receivers, and CS4334 DACs?
"SPDIF" is a digital audio interface that carries stereo PCM data as a serial bitstream, and its key characteristic is that one source can be selected, decoded, and then converted to analog by a separate DAC stage. Here, SPDIF from Bluetooth, coaxial, or optical first goes into a 4052 multiplexer, then through optocouplers to separate DIR9001 decoders for each channel, and finally into CS4334 converters. [#20661024]
Why was the DAC and Bluetooth supply switched by relay only for digital inputs, and what noise or power benefits does that give?
The DAC and Bluetooth supply was relay-switched so those circuits only receive power when a digital input is selected. The builder said the digital section’s secondary side is powered from the audio supply through a relay, and when analog sources play, no voltage is applied to DAC or Bluetooth. That reduces unnecessary powered digital activity inside the chassis and avoids keeping extra sections energized all the time. [#20661024]
What are the best ways to make illuminated front-panel inscriptions visible only when lit, using PCB soldermask, etched laminate, smoked plexiglass, tinted glass, or laser-printed film?
The best thread-backed options were etched thin laminate behind dark cover material or darker tinted glass. The builder’s PCB with black soldermask hid labels well when off, but blocked too much light. Other users recommended 0.3-0.6 mm etched laminate with smoked plexiglass, laser-negative print on film, or darker glass such as Antisol, because those methods preserve the hidden-until-lit effect better than weak tint. [#20663469]
Tinted glass vs smoked plexiglass vs car-window film: which works best for hiding IR receiver cutouts and front-panel labels in an amplifier?
Tinted glass gave the most professional finish in this discussion. One experienced user said foil on plexiglass kept producing bubbles, scratches, and artifacts, then switched to cut and polished tinted glass with better visual results. The main limit was IR: with 6 mm black Antisol glass, the remote range dropped to about 3 m, so darker hiding can cost remote performance. [#20663469]
How hot is too hot for a Class A amplifier heatsink, and what case size or radiator changes would help if the chassis reaches about 75°C?
About 75°C was high enough here that the builder regretted the chassis choice and wanted larger heatsinks. He used a 30 cm deep case and later said he wished he had chosen a 3U enclosure with bigger radiators. In practice, that means the thermal design was workable but undersized, especially for a 1.5 A per-channel quiescent current Class A build. [#20661024]
How do soft-start and speaker protection work in an Atmega16-controlled amplifier with standby power and relay-switched transformers?
The Atmega16 control board runs from a standby supply and manages transformer switching, soft-start, and speaker protection relays. The builder said the control section handles backlight, buttons, and power switching, while the speaker-protection board is supervised by the microcontroller and mounts directly at the speaker terminals. That setup lets the amp power up in a controlled sequence and disconnect speakers under fault conditions. [#20661024]
What model was the volume potentiometer in this build, and where can I get the preamplifier PCB files, Gerbers, or spare JLCPCB boards?
The volume potentiometer was an Alps RK271 2x50k. The builder said he still had extra JLCPCB boards left, including 3 power-amplifier and selector boards and 4 of the other boards, because the minimum order was 5 pieces. He also offered to share Gerbers, Eagle files, and microcontroller code, asking interested people to contact him by private message. [#20672089]
