Opticum Sloth Ultra - List of nc + channels for opticum sloth ultra
marvin78 6036 7
  • #1 16831339
    marvin78
    Rate: 25
    Hello, I have a question, does anyone from forum members know where to get the new channel list for opticum sloth ultra.
    Does this decoder match 310 list, if so how to upload it?
  • #3 16831765
    marvin78
    Rate: 25
    Buddy LeDy, you are probably a dermatologist, hence the question about skin.
    I know which lists and frequencies to search. https://www.google.pl/url?sa=t&source=web&rct...awania%2520kana%25C5%2582%25C3%25B3w.pdf&ved= 0ahUKEwi6u-a_jcjXAhXjO5oKHR2JAd8QFggxMAE & ultrasound = AOvVaw0f-erKDldJCRWmHWfQkAPE
    I also found
    http://forum.dvhk.to/showthread.php?t=410811
    I don't want / don't have time to rearrange the channels.
    Probably one of the forum members has already done it at home and I would like to take advantage of the fruits of his work, to the delight of my daughters, to regain their favorite fairytale channels nick and nickname jr.
    In the past, this question seemed to be answered in a matter-of-fact way.
    _kli_
    Help: 760
    Rate: 1038
    This decoder probably has a FastScan function. You enable fast scanning by the operator of which card you use and in a few seconds you have "right" list .
    I don't understand the term 'right' by the way. Right for who Only for the operator, I think. In my opinion, the right one is one that takes into account the offer and your preferences. And not someone's "see".
  • #5 16832054
    marvin78
    Rate: 25
    There is a plus, the fast scan function sorted the channels in operator order.
    But unfortunately the channels that have recently disappeared did not appear. In addition, even after inserting the nc + card, all channels are coded. The clone + card is standard in the decoder. Of course, the fta channels are lit.
  • #6 16832277
    LeDy
    Help: 1990
    Rate: 2933
    After this question
    Does this decoder match the list from 310
    I wrote about the skin. I am not a dermatologist but when I read such posts my skin is bristling. If you want, test which decoder you like. After what you wrote, I gave you the easiest way to avoid problems. If you don't want to, it's your problem.
  • #7 16832697
    marvin78
    Rate: 25
    The card reader has gone down.
    When I put the clone + in the decoder again, no LED on the card came on.
    I suspend the subject until the decoder returns from warranty repair.
  • #8 18664277
    krisfoot
    Hey, I don't know how current the topic with the channel list is. I will describe what I did with Opticum Sloth Ultra Plus with S / W version 2.1.86 which after Fast Scan did not find all channels.
    As the file with the list was not found, I started to combine. The first thing is I found information to search for channels not by NC + provider but according to TNK HD POSTPAID. It turned out well but not perfect, there were still a few channels missing.
    I searched the net for the current data of the channel that Fast Scan did not find, on the decoder I went into the menu Installation -> Search for channels and searched the transponder list for that channel, clicked OK, "v" appeared next to the transponder and then I selected the Scan option. I saved the search result and returned to Fast Scan again and chose TNK HD POSTPAID and the "delete" scanning mode, which previously no Fast Scan channels have appeared.
    I tested the described path three times on the Opticum Sloth Ultra Plus decoder and each time it helped. If I get a different model, I will let you know if this method worked.
The discussion revolves around obtaining an updated channel list for the Opticum Sloth Ultra decoder, specifically for the nc+ service. Users share various methods for channel scanning, including utilizing the FastScan function and searching for channels by different providers like TNK HD POSTPAID. Some users report issues with missing channels after scanning and difficulties with the card reader. Links to external resources for channel lists and frequencies are provided, along with personal experiences in managing channel organization and troubleshooting decoder issues.
