  • Speaker configuration toggle temporarily clears audio rendering error
    #1 17751277
    amperroww
    Since I replaced the platform on my PC (MSI X370 Gaming Pro Carbon with ALC1220 and Ryzen 5 1600X) I have a problem playing videos on YT. The message "Audio rendering error. Restart the computer." Often appears. and it only helps to change the speaker configuration in the Realtek panel from stereo to quadrophone or vice versa. After restarting the computer, of course, the problem persists.
    Also thanks in advance for your help.
  • Install MSI chipset and Realtek audio drivers first
    #2 17753262
  • #3 17753747
    amperroww
    After replacing the platform, I did the clean installation format and installed these drivers. Now I have installed Flash again and it works for now, but we will see.
    System updated, I use Opera.
    Still the same. I'll try to reinstall the drivers later.
  • #4 17754009
  • #5 17765131
    amperroww
    It works fine on firefox. After re-installing drivers at Opera, it's still the same. Everything is fine with the disk.
