Children's Car Repair: Control Board Damage, Door Switch, D2+/D2- & D1+/D1- Wires, Replacing Remote
wentyl215 13932 13
How can I identify the D1/D2 wiring on a children's ride-on car control board, what voltage should I use to power it, and can I replace the missing remote control?
D1/D2 are most likely the motor or manual/remote-control module connections, while the middle +/- pair is the board’s supply input, so power it with the correct polarity and the car’s rated voltage rather than guessing a higher one [#16835036][#16836773][#16836588][#16837985] The thread points to the original pack being about 7.2 V nominal, with one battery label shown as 6.75–6.90 V standby and 7.20–7.50 V cycle use, so 9 V or 12 V may be risky even if the relays themselves are rated 12 A / 12 V [#16836745][#16837925][#16838158] You should also inspect the door switch and the manual/remote selector, because those are likely part of the fault path [#16836588][#16836773] For the missing remote, the replies only suggest buying a replacement remote/module for the exact model or from a ride-on-car parts seller; no one confirmed that a universal remote would work or that extra soldering on the PCB is needed [#16834876][#16837925]
  • #1 16834539
    wentyl215
    Level 19  
    Help: 11
    Rate: 64
    Hello, I would like to try to repair a children's car and I have a few questions.
    In general, I suspect damage to the control board (photo below) or the switch in the door. The drive (motor) is operational, the battery needs to be replaced, but before replacing it, I want to run it from a different power supply.
    I do not know what the D2 + / D2- and D1 + / D1- wires are for, in the middle is +/- so probably the power supply of the board that is connected to the switch in the door, also the power connection to it should indicate some voltage on the board, only where and what?
    Another thing is the pilot ... the previous owners threw the remote control (if the car broke, it was unnecessary), is there any possibility to buy a remote control? Do you need to solder something on the PCB?
  • #2 16834641
    1 PAWEL
    Help: 674
    Rate: 1364
    Please enter some name, symbol, photo of the car.
  • #4 16835036
    michalek1988
    Help: 68
    Rate: 181
    Maybe D1 and D2 go to the motors, you can connect the power supply to the middle connector without any problems, remember about the correct polarity and value. I suppose the relays control driving forward, backward, turns, so if any of these functions did not work for you, it would be worth taking an interest in them. What do you build your suspicion about a damaged control board? We cannot rule out that the entire toy was redundant due to battery wear. If you can, take a picture from the side of the tracks and include it in the first post.
  • #5 16836549
    wentyl215
    Level 19  
    Help: 11
    Rate: 64
    The first post was changed, photos of the board on both sides, and a photo of the car.
    There are several buttons in the door, the most important are POWER and control change, i.e. manual, where the gas pedal, reverse and steering wheel are working, and remote control.
  • #6 16836588
    michalek1988
    Help: 68
    Rate: 181
    Do you have an original battery? you will be given the operating voltage on it. Red and black probably connects to it, check with an ohmmeter if you have a switch on this switch. If you are ok, if not, then you have to take the door apart and check why it doesn't work. There is only one engine? I would rather suspect there are 2 left and right wheels separately. Switch to manual, and without motor, check that the relays switch when you accelerate, brake, test a turn. PS did you get this board removed or was it connected in some way?
  • #7 16836745
    wentyl215
    Level 19  
    Help: 11
    Rate: 64
    The pass of the plus (power switch) works, but I assume that I will not miss the demolition of the door, because the manual switch is suspicious. One motor per wheel :D
    The board sat next to the battery and drive (3rd photo). On the battery we have a stb 6.75V-6.90V, cycle use 7.20-7.50V with Initial current less 1.75A.
  • #8 16836773
    michalek1988
    Help: 68
    Rate: 181
    D1 and D2 may be designations for the manual / pilot control module. Different colors of wires come out of the motors than on this PCB. So disassemble the door and see how things are going there, you can take pictures to make it easier for you to put it back together. It turns out that the battery has a nominal 7.2V.
  • #9 16836803
    wentyl215
    Level 19  
    Help: 11
    Rate: 64
    Okay, we already have something ... the manual switch did not touch, briefly at 6V, consumption 0.2A, and when pressing the gas pedal for a moment 1.7A and then constant 1.2A - the wheel turns quite weak, of course the amperage increases with increasing voltage and automatically the drive accelerates.
    So now the question is, to what voltage can I connect this toy to the maximum? There is 12V on the switches / relays, unfortunately not the maximum voltage on the drive.
  • Starting current is high due to vehicle inertia
    #10 16837211
    michalek1988
    Help: 68
    Rate: 181
    I already answered you, in the previous post, you have work voltage and work voltage there. The starting current is high, because you have to move the whole mass of the vehicle, overcome the inertia. In an "adult" car, you also need to add more throttle to make it move, and when you accelerate, you can let it go completely and the car will keep moving. Check out the rest of the features we talked about.
  • #11 16837223
    wojtek 9007
    Level 40  
    Help: 711
    Rate: 847
    Hello - there is a symbol on the side of the printed circuit board (PCB) on its base
    determine what voltage was supplied to the car.
    Added after 41 [seconds]:
  • Battery voltage and remote replacement questions
    #12 16837925
    wentyl215
    Level 19  
    Help: 11
    Rate: 64
    I have the T9K-R1, in a black housing, but there is nothing on the plastic. The car is powered by 6V because it is the original battery, but I am wondering about the battery, e.g. 9V or even 12V. The car normally has a cut for the second motor / drive, also with higher voltage, maybe the plate will last because as I wrote earlier ... the relays are 12V, I just don't know if the motor will fail ...
    @ michalek1988 there is nothing to look at there, the fault has been detected and it works. Now I have a dilemma with the battery, if I can with more voltage, I will take one. And also the question of the pilot himself. On the part of spare parts, it comes out that it is enough to buy a remote control for PLN 38 and it should work, right?
  • #13 16837985
    wojtek 9007
    Level 40  
    Help: 711
    Rate: 847
    Currently, for 6V power supply, the diagram probably looks like this;
    And this is the scheme for 12V;
  • #14 16838158
    wentyl215
    Level 19  
    Help: 11
    Rate: 64
    It will be useful ... I don't know what yet, but I'll come up with something and let you know about the results.
    There is still this pilot.
    btw. I misread the relay, so as not to confuse anyone, it has a value of 12A ...
The discussion revolves around troubleshooting and repairing a children's car, focusing on potential control board damage and door switch issues. The user suspects the control board may be faulty and seeks clarification on the function of D1+/D1- and D2+/D2- wires, which are believed to connect to the motors. The user also inquires about replacing a lost remote control and whether soldering is required on the PCB. Responses suggest checking the battery voltage, testing the door switch, and examining the relays for proper function. The user confirms the car operates on a nominal 6V battery and considers using a higher voltage, while also confirming the relays are rated for 12V. A remote control can be purchased for approximately PLN 38, which should be compatible with the car.
TL;DR: Peak draw hit 1.7 A at 6 V; “consumption 0.2 A idle… 1.7 A on pedal, then 1.2 A.” [Elektroda, wentyl215, post #16836803] Why it matters: This FAQ helps parents and repairers diagnose kids’ ride-on cars—board faults, door switches, motor wiring, and remote replacement—without frying parts.
What do the D1+/D1− and D2+/D2− wires do on these cars?
They route drive/control signals between the board, motors, and the manual/remote module. In this model, D1/D2 are tied to the control path used for selecting manual vs. remote operation, rather than direct battery input. “D1 and D2 may be designations for the manual/pilot control module.” [Elektroda, michalek1988, post #16836773]
How can I safely power the board on the bench?
Feed a regulated supply to the middle +/- power connector with correct polarity. Then switch to manual and press the pedal to observe relay clicks and motor output. “You can connect the power supply to the middle connector… remember correct polarity.” [Elektroda, michalek1988, post #16835036]
What’s the nominal system voltage for this car?
It’s a 6 V system. The original battery is 6 V, with charge guidance marked on its label. One expert summed it up: “the battery has a nominal 7.2 V.” That 7.2 V is the charging level for a 6 V lead-acid pack. [Elektroda, michalek1988, post #16836773]
What current should I expect during a pedal press?
Expect a surge near start, then a lower steady draw. A measured case showed 0.2 A idle, ~1.7 A on pedal, then ~1.2 A continuous at 6 V. This aligns with overcoming inertia at launch. “The starting current is high.” [Elektroda, wentyl215, post #16836803]
Can I upgrade from 6 V to 9 V or 12 V for more speed?
The harness and some relays can be arranged for 12 V systems, but this unit shipped 6 V. Moving to 9–12 V increases stress and risk of motor failure, as the owner already feared. If attempted, re‑configure wiring per 12 V schematics and derate loads. [Elektroda, wentyl215, post #16837925]
How do the door switches affect operation?
The door panel hosts POWER and the mode selector. In MANUAL, the pedal, reverse, and steering wheel work. In REMOTE, the car expects RF commands. If power passes but mode switching fails, inspect and test the door switch assembly. [Elektroda, wentyl215, post #16836549]
What do the onboard relays control?
They switch drive functions such as forward/reverse and possibly steering. Faulty relays can kill one function. A contributor notes relays govern motion directions; test relay clicks under pedal input when in MANUAL. [Elektroda, michalek1988, post #16835036]
I misread my relay spec—what’s the correct rating?
The relay was clarified as 12 A (current rating), not 12 V. Misreading this leads to wrong replacement parts and overheating risks. “So as not to confuse anyone, it has a value of 12A.” [Elektroda, wentyl215, post #16838158]
How do I identify my control board for parts?
Check the silk/label on the PCB or housing. This thread’s board shows T9K‑R1 in a black housing. Use that ID when sourcing remotes or modules so the RF pairing and connectors match. [Elektroda, wentyl215, post #16837925]
Can I buy a replacement remote and will it pair?
Yes, suppliers list replacement remotes for these modules. Match the remote to your board model (e.g., T9K‑R1). The poster found remotes around 38 PLN; ensure compatibility and pairing instructions from the seller. [Elektroda, wentyl215, post #16837925]
Is one motor used per wheel on this car?
Yes. The owner confirmed one motor per wheel, and the chassis even has provisions for a second drive. That layout affects current draw and wiring choices during upgrades. [Elektroda, wentyl215, post #16836745]
What battery charging numbers should I follow?
Use the label values: standby 6.75–6.90 V, cycle 7.20–7.50 V, initial current under 1.75 A. These are typical for 6 V sealed lead‑acid packs and prevent overcharge damage. [Elektroda, wentyl215, post #16836745]
How do I test if the manual mode works without the motor installed?
Switch to MANUAL, power the board correctly, and press the pedal while listening for relay clicks. Check voltage on motor leads during pedal press. If relays don’t switch, trace the door mode switch. [Elektroda, michalek1988, post #16836588]
Any edge cases I should know before raising voltage?
Edge case: wiring and board may accept 12 V arrangements, but the motor can fail early when over‑volted. The owner explicitly questioned 9–12 V and motor survivability. Proceed only after confirming motor specs and gearing. [Elektroda, wentyl215, post #16837925]
Quick how-to: bench‑test the drive circuit in 3 steps
  1. Connect a regulated supply to the board’s middle +/- with correct polarity.
  2. Set to MANUAL, press pedal, listen for relay clicks.
  3. Measure voltage at motor outputs during pedal press to confirm switching. [Elektroda, michalek1988, post #16835036]
Where can I see wiring for 6 V vs 12 V setups?
Reference the shared diagrams that outline 6 V and 12 V configurations. They show battery, switch, and drive wiring differences for correct reconfiguration. Use them before any voltage change. [Elektroda, wojtek 9007, post #16837985]
