Yiuhua 852d + vs WEP 872d - plastic welder which is better, more durable
zlotowinfo 12156 13
Which of these budget hot-air stations is the better and more durable choice for plastic welding: Yiuhua 852D+ or WEP 872D?
There is no clear durability winner in the thread, but the advice leans toward the compressor-in-station design rather than a fan-in-handle unit, and the participants treat these machines as basically the same Chinese platform [#16837416][#16837910] The heater is said to be the same in all of them and easy to replace, and the compressor is also a replaceable part [#16838435] One reply clarifies that 852D+ is the compressor version, while 852D is the fan/pump version [#16839732] The thread’s final buying decision was WEP 872D because it offered real temperature readout for both hot air and the soldering iron, plus a better price and free shipping [#16838306] It is also noted that this class of device is really a hot-air soldering station rather than a true plastic welder [#16838391]
  • #1 16836276
    zlotowinfo
    Help: 7
    Rate: 59
    Which one is really better (after all, another manufacturer).
    The most important, of course: power and durability of the heater and the compressor.
    PLN 234 Yiuhua 852d + (219 + 15) allegro 6821205084 and 5140587172,
    PLN 248 WEP 872d allegro: 6950866288
    A colleague had 853d (the one with the meter, but he never used the meter)
    Prefer the compressor, 853d is very similar to 852d +.
    A colleague claims that this 853d showed the temperature on a regular basis.
    The video shows that 852d + does not do this, https://www.youtube.com/watch?v=AzAu5csiI34,
  • #2 16837416
    tzok
    Help: 3176
    Rate: 6549
    If you are wondering between the "fan" in the handle and the compressor in the station, then without hesitation I point to the compressor in the station.
  • #3 16837457
    zlotowinfo
    Help: 7
    Rate: 59
    As I wrote "I prefer those with a compressor", so it is not subject to discussion.
    It is about: "Yiuhua 852d + vs WEP 872d - plastic welder which is better, more durable".
  • #4 16837742
    tzok
    Help: 3176
    Rate: 6549
    852D has just a fan ... 852D + has a compressor. Either way WEP
  • #5 16837818
    zlotowinfo
    Help: 7
    Rate: 59
    I have already written that I am only interested in the compressor and you keep yours, I will improve the posts if it bothers you so much ...
  • #6 16837910
    marek216
    Help: 1077
    Rate: 932
    You are aware that under the metal plate it is the same Chinese. Otherwise organized panel. 100% heating elements in the flasks are the same, probably also in HA.
    And this is not a plastic welding machine, only a HA + soldering iron.
  • #7 16838290
    zlotowinfo
    Help: 7
    Rate: 59
    What about the compressor? Do you think the same too?
  • #8 16838294
    marek216
    Help: 1077
    Rate: 932
    I have three different Chinese people. They can be donors to themselves :)
  • WEP 872D chosen for real temperature readout
    #9 16838306
    zlotowinfo
    Help: 7
    Rate: 59
    So finally and after consulting a colleague who needs it, we chose auction allegro nr. 6950866288. WEP 872D PLASTIC WELDING MACHINE + BUT Nozzle
    Because good price, free inpost delivery, needed items and ...
    "Real temperature reading from hot air and from grinder !!! THIS OTHER WELDERS DO NOT HAVE, like 852D +, 850AD, 850BD ..."
    Added after 22 [minutes]:
    https://allegro.pl/uzytkownik/17182143/oceny?recommend=false&page=1
    STRONG PLASTIC WELDING WEP 872D LED GUIDE (6820985258)
    "Welder 873 d dziadność I do not recommend to anyone impractical and arduous to use invented by the Chinese moron. All right, it is a pity that such" g "sells fast shipping, it is possible to return, but I did not use it, I tried to convince myself to the equipment ... a shop for amateurs. "
  • #11 16838409
    zlotowinfo
    Help: 7
    Rate: 59
    Marek216 has already written it, once it was enough ... Do you want to prohibit people from using this to weld plastic?
    A colleague for 2-3 years used 853d + to weld plastic until finally the compressor sat down and stubbornly wanting to finish the job, lit the heater.
  • Hot air station parts are replaceable
    #12 16838435
    tzok
    Help: 3176
    Rate: 6549
    The heater (as well as the whole "butt" HA) is the same in all of them and relatively easy to replace. The compressor is also available as an exchangeable element.
    What friend is so nervous? I don't want to call it real and not like some creative Allegro trader. This is a hot air soldering station, not a "plastic welding machine". Where have I forbidden something here?!?
  • Plus version has a higher-power soldering iron
    #13 16838464
    zlotowinfo
    Help: 7
    Rate: 59
    I glimpse how it is with parts.
    Returning to the plus and no plus, in this guest's auction what I wanted to buy are links to hotair.pl
    By. what is given the difference with plus or without plus is the difference in the power of the soldering iron.
    http://www.hotair.pl/pl/sklep/stacje-lutownic...ownicza-5w1-wep-853d-z-zasilaczem-15v-1a.html
    http://www.hotair.pl/pl/sklep/stacje-lutownic...cza-5w1-wep-853dp-1a-kolba-wiekszej-mocy.html
The discussion centers on comparing the Yiuhua 852D+ and WEP 872D plastic welders, focusing on their power and durability, particularly the heater and compressor. Users express a preference for models with compressors over those with fans, highlighting that the 852D+ features a compressor while the standard 852D has only a fan. The WEP 872D is noted for its real temperature reading capabilities, which some users find lacking in the 852D+. Concerns are raised about the overall quality and usability of these devices, with some users sharing experiences of using similar models for plastic welding. The consensus leans towards the WEP 872D due to its features and pricing.
TL;DR: Prices noted were PLN 234 (Yihua 852D+) vs PLN 248 (WEP 872D); “Prefer the compressor.” For plastic repair, pick a compressor-based hot‑air station, then check display features and spares. [Elektroda, zlotowinfo, post #16836276]
Why it matters: It helps DIYers choose a durable hot‑air station for plastic welding-style repairs without buying the wrong airflow type.
Which is better for plastic welding tasks: Yihua 852D+ or WEP 872D?
Go with a compressor-based unit and lean WEP if choosing between these two. One expert noted, “Either way WEP.” The 852D+ has a compressor, while 852D does not. That airflow stability helps when directing heat on plastic seams or tabs. Pick based on airflow first, then features like display behavior and included nozzles. If you see 853D/853D+, remember those are turbine-in-handle designs and not what you want for compressor airflow. [Elektroda, tzok, post #16837742]
Are these actually plastic welders or just hot‑air soldering stations?
They’re hot‑air soldering stations. Sellers may market them for plastic work, but they are not specialized plastic welders. You can still repair many plastics with proper temperature, airflow, and filler rods, yet the platform remains a hot‑air station at its core. Expect trade-offs versus dedicated plastic welders, especially in nozzle geometry and thermoplastic-specific accessories. [Elektroda, tzok, post #16838391]
Which models use compressor versus fan/turbine airflow?
Reference mapping: 852D+ uses a compressor in the base. 852D appears in both fan and pump variants. 853D and 853D+ place a turbine (fan) in the handle. Verify the exact sub‑model before buying. Compressor airflow feels steadier for heat-shrinking and plastic tab welding, while turbine handles are lighter but can be harsher in flow profile. [Elektroda, tzok, post #16839732]
Are the internals and heaters different between brands like Yihua and WEP?
Expect similar guts. A repair pro reported that under the faceplates they’re the same Chinese designs, with “100% heating elements … the same.” This means many nozzles, heaters, and handles interchange, simplifying maintenance and donor-part harvesting. Still, confirm connector pinouts and mechanical fit before swapping. [Elektroda, marek216, post #16837910]
Does WEP 872D really show live hot‑air and iron temperatures?
A cited listing claimed real-time readouts for both hot air and the soldering iron. That’s useful when dialing plastics within narrow melt windows and when logging process stability. Treat it as a product-claim feature and verify on arrival or with the seller’s documentation, since listings vary by batch. [Elektroda, zlotowinfo, post #16838306]
Does Yihua 852D+ display the actual temperature while heating?
A shared video indicated the 852D+ did not continuously show live temperature during operation. If you rely on live feedback for plastics, that behavior matters. Consider models explicitly supporting real-time readouts or plan to validate tip/nozzle temperature with an external thermocouple when critical. [Elektroda, zlotowinfo, post #16836276]
What tends to fail first when using these for plastic work long‑term?
A user ran an 853D+ for about 2–3 years on plastics until the compressor weakened. Forcing completion of a job afterward overheated and destroyed the heater. Edge case lesson: stop when airflow drops, or you risk cooking the element. Keep a spare heater and verify airflow before heating. [Elektroda, zlotowinfo, post #16838409]
Can I replace the heater or compressor if they fail?
Yes. The heater and the entire hot‑air handle assembly are common service items and relatively easy to swap. Compressors used in station bases are also replaceable modules. Keep part numbers handy, and confirm wiring and hose routing before disassembly. “The heater … is the same in all of them and relatively easy to replace.” [Elektroda, tzok, post #16838435]
Is a compressor-in-station design better than a fan-in-handle for plastics?
Yes. “If you are wondering between the ‘fan’ in the handle and the compressor in the station, then without hesitation I point to the compressor.” Compressor airflow is steadier and easier to meter at low rates, which helps prevent warping thin plastic tabs. [Elektroda, tzok, post #16837416]
Are 853D and 853D+ compressor models?
No. Both 853D and 853D+ use a turbine (fan) in the handle, not a compressor in the base. If your priority is compressor airflow for plastics, choose 852D+ or another clearly compressor-labeled variant. Always confirm the sub‑model and airflow architecture in the listing. [Elektroda, tzok, post #16839732]
What prices were observed in the thread for a quick benchmark?
At the time, users cited PLN 234 for Yihua 852D+ and PLN 248 for WEP 872D. Use these only as historical anchors from November 2017. Modern pricing differs, but the small delta suggests choosing by airflow and features first, not by minor cost gaps. [Elektroda, zlotowinfo, post #16836276]
Fast pick: how do I choose between 852D+, 852D, and 872D?
  1. Confirm airflow type: pick compressor-in-base for plastic tabs and bumpers.
  2. Check display needs: decide if you want live temperature readout behavior.
  3. Verify model code in the listing and plan for spares (heater, handle, compressor). [Elektroda, tzok, post #16839732]
