[Solved] Experiencing Slow Transfer Rates with T-Mobile Internet LTE and Huawei B525 on Fixed IP
Cobrix 3915 2
  • Fixed IP APN causes severe throughput drop
    #1 16846163
    Cobrix
    Hello. Has anyone met this situation?
    I took the T-Mobile internet LTE probe with a Huawei B525 router. BTS 1.5 km from me - tests on the pages show speeds around download 50Mb / s, upload 20Mb / s. Everything is OK.
    The problem starts when I switch to the IP from T-Mobile permanently. According to the instructions you should change the APN profile with Internet on date .
    Yes, it gets a steady IP but the bandwidth drops dramatically.
    Interestingly, the pages with the meters still show their speed as ok - 30Mbps download and 10 upload but the link is very slow.
    The same file sucked from the company's ftp on dynamic ip is flying with a speed of 1.5Mb / sa on a fixed IP 40kb / s.
    On a fixed IP, RDP sessions break up, sometimes even displaying errors when opening pages - that dns servers do not respond.
    T-Mobile sent me to the tree - on line info they say that the technical department found no problems.
    Of course I will give away the equipment but in my location T-Mobile was the only option for fast internet. On dynamic ip it's ok but I have to have permanent access to the company's resources.
  • #2 16847152
    bogiebog
    Help: 2569
    Rate: 1530
    I do not understand access to the company through VPN?
    The VPN is secure enough that you don't need to filter ip addresses.
  • #3 17447130
    Cobrix
    However, it was a tech problem. T-Mobile
