[Solved] T-Mobile Internet Connection Slow: Issues with Download Speed & High Ping (30mbps to 2-3mbps)
OziPL4 28182 10
Why is my T-Mobile home LTE suddenly dropping from 30 Mbps to 2–3 Mbps with very high ping, and how can I check whether the cell tower or LTE band is the problem?
The most likely cause is congestion on the BTS you are connected to, which can reduce speed and make ping jump to several seconds; in the thread it was suggested to first verify the LTE signal parameters and nearby BTSs instead of just changing settings blindly [#17179181][#17179143] Use a tool like Huawei Manager or LTEWatch to force and test bands on the Huawei B528, because the B528 can aggregate two LTE bands and T-Mobile uses LTE2600, LTE800 and LTE1800 [#17179223] Check which BTS is serving you by CID and test LTE1800, LTE2600 and LTE1800+2600 one by one, then compare the results with speedtest [#17180883] For the reported area, three nearby BTSs were identified about 3 km away: Węgierska 144 (FAKRO), Wyspiański 2, and Magazynowa 7, all with LTE1800NW and LTE2600 for T-Mobile [#17180883] Test the router outside and post screenshots with the BTS CID, signal values and speedtest parameters so the exact cell/band can be confirmed [#17180883]
  • #1 17179120
    OziPL4
    Rate: 8
    Hello, the last two years I had internet home with T-mobile, everything went as it should. Two months ago, something started to go wrong. With max 30mbps of dowload it got max 5 but usually 2-3. At the same time ping jumped from 60 to 8,000. Well but ok, it was over. A week ago my contract ended. I took a packet up to 20mbps, because the second packet was up to 60mbps, and so far it would not have reached even close speed. After that, I do not have as many buds as I need. On the first day of my test for the new internet, I managed to reach 10mbps, but it was usually around 7-8. PING on speedtest was within 35. Well, but the weekend came. And from Friday, the internet lives its own life. Download jumps from 0.5 to 5. Upload the same. And with ping it's a pity to talk. He can jump from 60 to 9,000. When one person is attached only to the discord. It's almost all the time since Friday. Could someone tell me if to fix it somehow, somehow change the frequency or something. Two years ago, he managed and now he is like it is. I live 7 km from the center of Nowy Sącz. Thank you in advance for your help.
  • #2 17179143
    matek451
    Help: 4351
    Rate: 5805
    What is the location, what LTE band are you using in T-Mobile? What is your router for this offer, did you check the parameters of the LTE signal?
  • #3 17179181
    irekr
    Help: 1192
    Rate: 1239
    Probably increased traffic on BTS which uses your modem. Have you checked how many BTSs you have and what are available near you? Maybe the operator changed the settings ...?
    I have several Orang LTE endings in Warsaw and it was not too bad at the beginning, transfers up to 20 Mbs (business agreement is up to 40) but up to several months there are facilities in which LTE transfer does not exceed 1 Mbs with pings up to 4 seconds. There is one facility in the western part of the city where sometimes there is no transfer. A new housing estate was built and several thousand LTE modems arrived. In new buildings there is neither a meter of light or copper.
    I also tested one own modem (D-Link) with LTE 4G on PLUS for Warsaw and initially it was 4-6 Mbs, now it does not exceed 2 Mbs. BTSy behaves like totally sucked.
    At my home LTE in T-Mobile does not work at all because BTS-y do not support LTE and in Orange on (two-way modem) LTE you can squeeze max 3 Mbs and this occasionally .... Even HSPA in T-Mobile works better.
    Fortunately, I have Neo 10/1 (it is 12 / 1.4) and stable with good pings. More will not be because my part of the village does not have any ONU cabinet. The line has 6 km copper, partly overhead, and partially cable.
    Call the operator, maybe you'll do something, but I doubt ...
  • #4 17179214
    OziPL4
    Rate: 8
    Could I ask for help in how to check the bandwidth? On the router page (this 192 .....) there are 2 dashes on 5. I have a router: huawei b528s -23a.
  • #5 17179223
    matek451
    Help: 4351
    Rate: 5805
    Kreski is not interested in anybody, the LTE signal has certain parameters. To manage B528, choose LTE bands and aggregate them http://www.mediafire.com/file/99t05l2dv6vany8/Huawei_Manager_1.1_PL.apk on Android or on the Windows http://www.lte-anbieter.info/ltewatch/count_huawei .php? Datei = ltewatch_h T-Mobile uses its own LTE2600, LTE800 and LTE1800NetWorks. B528 aggregates two LTE bands. Lack of location does not allow to check where are the nearest NetWorks BTSs and what LTE bands on them / W / w applications also show CID BTS.
  • #6 17179237
    irekr
    Help: 1192
    Rate: 1239
    In other words: we will ask for locations, so +/- 100 meters.
  • #7 17180850
    OziPL4
    Rate: 8
    I'm sorry that it's only for the next day but so:
    And if it comes LTEWatch, I would ask for help in how to use it. When I enable it, it generates:
    08: 58: 50.035 PM set Language is: en-US
    08: 58: 52.358 PM Routine started ... LTEWatch [H] version 1.1 Release Candidate 1 (Build timestamp: 03/10/2017 05:05:54)
    08: 58: 52.510 PM set Language is: en-US
    08: 58: 52.510 PM timer started => 1.5s
    08: 58: 52.545 PM Login was successful ... (Token method)
    08: 58: 52.546 PM fetching Drive / MonitoringStatus Data ...
    08: 58: 52.572 PM Fetch Drive Error!
    08: 58: 52.578 PM Fetch Monitoring Error!
    08: 58: 52.578 PM fetching Drive / MonitoringStatus Data failed!
    08: 58: 52.578 PM ConnectionStatus Error => 0
    And there are no indications in the tables on the program (attachment).
    Added after 4 [minutes]:
    Could I somehow remove this answer with the location? Is not it too much?
  • #8 17180883
    matek451
    Help: 4351
    Rate: 5805
    At a distance of about 3 km, three NetWorks BTSs with LTE1800NW and LTE2600 T-mobile and their aggregation. It is Węgierska 144 (FAKRO), Wyspiański 2 and Magazynowa 7. Force one by one LTE1800, LTE2600 and LTE1800 + 2600, Hmanager. Take the B525 test outside. Show screenshots with CID BTS and signal and speed test parameters. In LTEwatchH you choose the option with Password?
  • #9 17180897
    OziPL4
    Rate: 8
    Here with speedtest: T-Mobile Internet Connection Slow: Issues with Download Speed & High Ping (30mbps to 2-3mbps)
    The program is there in defaut settings.
    I have a b528 router.
  • #10 17184521
    OziPL4
    Rate: 8
    Ahh, it's hard to get tired this year like maybe a fiber optic. Thank you for your willingness. Greetings.
  • #11 17184523
    OziPL4
    Rate: 8
    Added after 43 [seconds]:
    Thank you. Greetings.
The user reports a significant decline in internet speed with T-Mobile, dropping from a maximum of 30 Mbps to as low as 2-3 Mbps, alongside a drastic increase in ping times from 60 ms to over 8,000 ms. The issue began two months ago, coinciding with the end of their contract, after which they switched to a new plan with a maximum of 20 Mbps. Users suggest checking the LTE band and signal parameters, as well as the number of nearby Base Transceiver Stations (BTS). Recommendations include using tools like LTEWatch to monitor signal quality and potentially changing frequency bands. The user has a Huawei B528s-23a router and is seeking assistance with bandwidth checks and troubleshooting connectivity issues.
