Replace T25-4-H0 Diode in Car Rectifier Bridge: Identifying Cathode/Anode, Startup & Burnout
gekonos 21252 3
  • #1 16850983
    gekonos
    Rate: 30
    I warmly welcome
    What to replace the T25-4-H0 diode from the car rectifier bridge with start-up?
    The diodes burned out
    this diode T25-4-H0 has a cathode or anode "on the wire"?
    Diode as in the picture
  • #3 16851425
  • #4 17983489
    rajucorsa
    Rate: 31
    Hello, I had a similar bridge on four diodes. 3 diodes are T25-4-j3 and one T25-4-C4.
    And it turned out that these T25-4-J3 had an anode on the wire and the one marked T25-4-C4 had a Cathode on the wire
    Maybe someone will need this information.
