12V Charger Not Charging: Rectifier from Belgium, H7 Bulb, 4 LEDs, Photos Included
chudi075 6255 14
Why does my 12 V charger not charge a battery and only light a few LEDs when I connect it through a bulb test load?
The charger likely has an open 1 Ω 5 W resistor or a damaged polymer fuse, possibly caused by reversed battery polarity. Check the yellow polymer fuse and the white ceramic resistor with a multimeter; if the fuse is open, the charger will not pass current, and if the resistor is open, it also will not charge [#16448502][#16449625][#16450102] Do not test it with a 55 W H7 bulb first, because a 4 A charger may not light it even when the charger is otherwise okay; use a smaller 21 W or 5 W bulb instead [#16449000] If the smaller bulb lights, the fuse is likely good; if it does not, the polymer fuse is damaged [#16449000] If the fuse is good but the bulb still does not light, the resistor is likely the faulty part [#16449000][#16449625] One reply also noted that a momentary polarity mix-up can kill the 1 Ω resistor, which then protects the fuse [#16450102]
  • #1 16448479
    chudi075
    I warmly welcome. I bought a rectifier in Belgium on a brocade and when I returned home and after connecting it turned out that it does not charge. I tried to connect it under the H7 bulb and nothing, the bulb does not light, only 4 LEDs light up. I disassembled the case and there is no fuse. I will attach photos.
    • 12V Charger Not Charging: Rectifier from Belgium, H7 Bulb, 4 LEDs, Photos Included IMAG0638.jpg (2.21 MB) You must be logged in to download this attachment.
    • 12V Charger Not Charging: Rectifier from Belgium, H7 Bulb, 4 LEDs, Photos Included IMAG0639.jpg (2.25 MB) You must be logged in to download this attachment.
    • 12V Charger Not Charging: Rectifier from Belgium, H7 Bulb, 4 LEDs, Photos Included IMAG0641.jpg (2.33 MB) You must be logged in to download this attachment.
    • 12V Charger Not Charging: Rectifier from Belgium, H7 Bulb, 4 LEDs, Photos Included IMAG0642.jpg (2.27 MB) You must be logged in to download this attachment.
  • #2 16448502
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    Terrifying Chinese trash. :cry: Check the polymer fuse (this yellow plate), is its resistance "0"? And this ceramic resistor 1?
  • #3 16448508
    Wojciech.
    Level 37  
    Help: 319
    Rate: 467
    Multimeter in hand and check the voltage at the output of the hits and the bridge.
  • #4 16448526
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    Wojciech. wrote:
    the voltage at the output goes and the bridge.
    For what? The LEDs glow to him :D Break in either polymer fuse or resistor, but most likely in "crocodiles" :D
  • #5 16448532
    chudi075
    With this check I will have to wait until I go to Poland, but thanks for the information, at least I know what to do.
  • #6 16448542
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    chudi075 wrote:
    With this check I will have to wait until I go to Poland but thanks for the information at least I know what to do.
    Twist it together, slide the insulation sleeves off the spring clamps and see what's going on there. This is all you can do on the road. :D
  • #7 16448556
    chudi075
    I'm green when it comes to electronics etc. The polymer fuse is the yellow plate and the resistor?
    Added after 45 [seconds]:
    Ok, I will.
  • #8 16448562
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    chudi075 wrote:
    resistor?
    White ceramic cube.
  • #9 16448579
    chudi075
    Crocodile clips approx.
    • 12V Charger Not Charging: Rectifier from Belgium, H7 Bulb, 4 LEDs, Photos Included IMAG0643.jpg (1.81 MB) You must be logged in to download this attachment.
    • 12V Charger Not Charging: Rectifier from Belgium, H7 Bulb, 4 LEDs, Photos Included IMAG0644.jpg (4.48 MB) You must be logged in to download this attachment.
  • #10 16449000
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    This rectifier is probably 4 amps (although I recently saw a 4A rectifier with a 6A fuse) so if there is a 4A polymer fuse and you test it with a 55W light bulb it may not shine because the fuse may work. Test with a smaller light bulb.
    Give photos of descriptions from the polymer fuse.
    Connect a standard 21 or 5W light bulb here.
    If it lights up, connect it here
    If it is off then you have a damaged polymer fuse.
    If it is lit, connect it as marked here
    If it is not lit, the resistor is damaged.
    Where is the resistor and where is the fuse here
  • #11 16449240
    chudi075
    Thanks. Today after work I will check the bulb you wrote about if I have one and write what results afterwards
  • #12 16449625
    Sniezynka
    Help: 199
    Rate: 841
    If all the LEDs are lit after switching on the power supply and the battery connected, the 1 Ohm 5W resistor is damaged. Only the battery connected to the charger (without mains power) LEDs are off, the charger connected to the mains without battery also.
    I've already done that.
  • #13 16449639
    chudi075
    After turning on the power, nothing is lit until you connect the crocodile clips under the bulb or the battery then all of them are lit.
  • #14 16450102
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    @ chudi075 Well. Now the bulb in series with the battery. I suspect that despite all this rectifier was working, only a colleague ...... It was enough for a moment to confuse polarities when connecting the battery and the 1? resistor fell. He protects the polymer fuse more than vice versa.
  • #15 16450321
    chudi075
    I bought it at a flea market at risk because it could not be checked and when I returned and connected it did not work. I will replace this resistor and we will see. Can you put some fuse in the input?
The discussion revolves around a rectifier purchased in Belgium that fails to charge when connected to an H7 bulb, with only four LEDs lighting up. Users suggest checking the polymer fuse and ceramic resistor for faults, as well as testing the output voltage with a multimeter. Recommendations include using a smaller light bulb for testing and inspecting the connections, particularly the crocodile clips. The author expresses a lack of experience in electronics but plans to check the components as advised. There is a consensus that the issue may stem from a damaged resistor or fuse, and the possibility of adding a fuse to the input is raised.
