Kiano KF10Q Tablet Won't Turn On: Battery & Charger Voltage Issues, Overheating Troubleshoot
cjerzy1 4518 6
  • #1 16856096
    cjerzy1
    Rate: 78
    The Kiano KF10Q tablet does not turn on either on the battery itself or on the connected charger. The battery, after removing the charger, has a voltage of approx. 3.6 V. The charger charges at a voltage of approx. 5.3 V, but it heats up terribly. I am asking for some tips on what to do with it.
  • #2 16856375
    nomudrek
    Level 36  
    Help: 406
    Rate: 472
    The battery is discharged, therefore the tablet cannot start, the heating of the charger indicates a high power consumption. What is the voltage on the battery while charging and is the battery warming up while charging?
  • #3 16856590
    cjerzy1
    Rate: 78
    The voltage on the battery during charging, if it seems to me well, should be the same as at the charger output, i.e. about 5.3 V. If the battery is warming up, I can't say it, as I can't access it and how to open the tablet I do not know. But I don't feel a very warm tablet outside. Or maybe colleagues will tell you how to get inside?
  • #4 16856639
    nomudrek
    Level 36  
    Help: 406
    Rate: 472
    The charging voltage on the battery should be around 4.25V.
  • #5 16857099
    cjerzy1
    Rate: 78
    I got inside and measured the voltage on the battery during charging, it is 4.1 V. After a dozen or so minutes. I have touched the battery, it is ice cold but the charger is still very hot. I suspect that it (battery) is dead. Please give me further instructions.
  • #6 16857233
    erwin2000
    Leave this miracle of technology under the charger for a day or two, it will wake up. At least mine does. Advice for the future, you see the inscription kiano, run away, buy se mante
  • #7 16857440
    cjerzy1
    Rate: 78
    Already slowly this miracle begins to come to life. It already "catches" the capacity and the power supply seems to heat up less. Hope it returns to normal. Thank you to everyone, buddy, for advice and close the topic.
The Kiano KF10Q tablet fails to power on, either from the battery or when connected to the charger. The battery voltage measures approximately 3.6 V, while the charger outputs around 5.3 V but overheats significantly. Users suggest that the battery may be deeply discharged, and the charger’s heating indicates high power consumption. After opening the tablet, the battery voltage during charging was found to be 4.1 V, and the battery itself remained cold. Following advice to leave the tablet connected to the charger for an extended period, the device began to show signs of recovery, with improved charging capacity and reduced charger temperature.
