Focus MK1: Cold Engine Clutch Smooth, Warm Engine Issues - Pump, Air System, or Slave Cylinder?
zagert99 6822 3
  • #1 16862839
    zagert99
    Hello! For some time I have been looking for help on the Internet, but I have not been able to clearly determine what is wrong with the focus. Namely, the symptoms are that the car on a cold engine starts smoothly, and the clutch catches and releases immediately, and after warming up (after about 5-6 minutes) the clutch has the impression that it does not bounce. After releasing the clutch before the car accelerates it takes some time instead of going, he howls. Does it look like the shield doesn't let go? I have no idea if this is the fault of a pump, air system or maybe a slave cylinder?
  • #2 16863382
    sulof1601
    Help: 94
    Rate: 281
    Hello. If the fault was on the side of the air system, it would not declutch. At what point in the cold, as you define, does it take the clutch down or near the top or maybe in the middle? (It's about the position of the clutch pedal)
  • #3 16865252
    zagert99
    For cold it catches lower than for warm. After warming up, it catches almost at the end. However, there are sometimes moments where he catches well and drives normally.
  • #4 16867165
    sulof1601
    Help: 94
    Rate: 281
    Rather, it is an extreme possibility, but once I met, although I bet that replacing the clutch will not pass you. Drain all the old liquid from the system, blow the muck because the old liquid may contain water particles pour fresh liquid, vent and check how the clutch will behave.
