Hotpoint Ariston AQSF29UEU - bearing replacement - bearing type, instruction
arlid 6153 6
  • #1 16864938
    arlid
    Help: 7
    Rate: 26
    Hello. I have a Hotpoint Ariston AQSF29UEU washing machine and unfortunately the bearings are to be replaced. Now the question is, does anyone know what bearings are there? Perhaps someone has instructions to disassemble this washing machine and remove the washing unit? I would not like to damage anything during possible demolition and read the procedure before disassembling it.
    I would be grateful for some information.
  • #2 16865081
    ROBSON33
    Admin of household appliances group
    Help: 465
    Rate: 1714
    Unfortunately, in this washing machine you have a glued and fully replaceable tank.
    https://north.pl/karta/wanna-kompletna-bebnem...ralki-hotpoint-aqsf29ueu,AIW-BT-CMMT-30G.html
    You can cut it open and replace the bearings, but it is definitely not to be done at home, you need experience and appropriate tools.
  • #3 16865111
    jalop
    Help: 40
    Rate: 204
    And how to connect the cut elements later? Are you using a welding machine or glue?
  • #4 16865295
    falo22
    Help: 89
    Rate: 649
    You can weld, you can use silicone seals
  • #5 16865428
    Gobro
    Help: 207
    Rate: 503
    It is better to seal them with silicone and screw them on because the bearings can be replaced in the future without re-cutting. It has been described many times.
  • #6 17576828
    ryba2010
    Rate: 69
    Hello. I am before replacing the bearings in the Ariston AVSF 109EUV washing machine or can someone describe to me briefly how to go about it or do you need to remove the entire drum from the housing, etc.
    mrice
    Moderator of Home appliances
    Help: 2213
    Rate: 6951
    Everything has already been described above, there is a lot of information on the forum on how to choose the glued tanks.
    ryba2010 wrote:
    whether it is necessary to remove the entire drum from the housing
    it cannot be otherwise
The discussion revolves around the replacement of bearings in the Hotpoint Ariston AQSF29UEU washing machine. Users highlight that the machine features a glued and fully replaceable tank, making the process complex. It is suggested that while it is possible to cut open the tank to replace the bearings, this should not be attempted without experience and proper tools. Recommendations include sealing the cut sections with silicone and using screws for future accessibility to the bearings. Additional inquiries about similar models indicate a broader interest in bearing replacement procedures for Hotpoint Ariston machines.
