Cyfral Smart 5P Intercom Installation: Step-by-Step Guide & Troubleshooting Ringing Issue
panznieba 38664 6
  • #1 16864988
    panznieba
    I bought a new intercom and wanted to install it, but I am not 100% sure how. I would like to add that the "ringing" does not work in the old intercom. Below I am attaching a diagram and photos of the old and new intercom. If possible, please provide a blatological explanation (of course, if you can infer something from the photos). Best regards.
    Cyfral Smart 5P Intercom Installation: Step-by-Step Guide & Troubleshooting Ringing Issue Cyfral Smart 5P Intercom Installation: Step-by-Step Guide & Troubleshooting Ringing Issue Cyfral Smart 5P Intercom Installation: Step-by-Step Guide & Troubleshooting Ringing Issue Cyfral Smart 5P Intercom Installation: Step-by-Step Guide & Troubleshooting Ringing Issue
  • #2 16865676
    zybex
    Helpful for users
    Help: 2094
    Rate: 2939
    Enter to which terminals the cables are connected and in what color. In the attached picture you can not see it exactly.
    Anyway in the old one:
    1 - microphone (in the new MIC)
    2 - handset (in the new SPK)
    3 - mass (in new MASS)
    5 - button (in new SW1)
    9 - calling (in the new RING)
  • #3 16865776
    suworow
    Help: 650
    Rate: 1278
    And can I refer to your knowledge / memory and ask about the model of this old uniphone?
    best regards
  • #4 16865842
    zybex
    Helpful for users
    Help: 2094
    Rate: 2939
    I tracked him down by browsing through different brands of intercoms. It took me a while, but I found and determined it was one of the Farfis models. As you can see in the picture, it has a buzzer, but the diagram also shows a handset to be called to terminal 9. Therefore, it is important that the author describes exactly what and where is connected.
    You must first find out why. The photo shows that one white wire in the installation cable is broken.
    One more auxiliary question, how did the ringing work, was it an acoustic signal in the handset, or was the buzzer visible on the top left?
    Possibly what call is the neighbors?
  • #5 16867784
    panznieba
    Thank you very much for such a quick response.
    So, as a colleague wrote above, the old intercom is Farfisa. Generally, it operated before the renovation (the apartment after my grandparents), but you know how the professionals work - on a grand scale ;) .
    The white vein is broken - it has been bridged - we will see if it works.
    As for the connections, it's hard to define the colors, but I'll try to:
    BROWN - 2
    LIGHT BROWN - 9
    BLUE - 3
    WHITE - 5 (it is bridged with the green wire).
    I am attaching more photos, maybe it will give a different view
    zybex
    Helpful for users
    Help: 2094
    Rate: 2939
    At the moment it looks like an extension of the cable, not a bridging. But I suppose it was a bit different. This short one might have been an additional bridge (although it doesn't suit me very well). Note that you do not have any wiring from terminal 1, and that is where the microphone line is to be connected.
    In any case, having so much information, you can try to connect a new uniphone. You can do it in stages. It is best to start with connecting the ground cable to the MASS terminal and the headphone cable to the SPK terminal. You should hear noises when the handset is picked up. If so, connect the microphone cable to the MIC terminal. Then you will hear your own blow. The last wire will be the call and you will put it on the RING.
    Then check if there is an opening. If not, we will wonder what needs to be done.
  • #7 16882071
    panznieba
    Thanks so much for your help! The topic is overwhelmed :)
The discussion revolves around the installation of a Cyfral Smart 5P intercom, with the user seeking guidance due to issues with the ringing function of their old Farfisa intercom. Participants provided detailed instructions on wiring connections, identifying terminal functions, and troubleshooting the ringing issue. The user confirmed the old intercom model as Farfisa and described the wiring colors associated with various terminals. Suggestions included connecting the ground cable to the MASS terminal, the speaker cable to the SPK terminal, and the microphone cable to the MIC terminal, followed by the RING terminal for the call function. The conversation concluded with the user expressing gratitude for the assistance received.
