Understanding Orange Fiber 300 Mb/s Optical Transmission & Reception Power: GPON, ONT, Funbox 3.0
berkos112 7578 4
  • #1 16867655
    berkos112
    Hello, My name is Marcin and I am new to the forum. For 2 days I have had the Orange Fiber 300 Mb / s service, everything works fine, but I am interested in this topic regarding the optical transmission and reception power.
    My results are 1 / -19 (dBm)
    I looked around in the subject and read that Terminal ONT in GPON technology, it should transmit the signal on average within +0.5 dBm / +5 dBm and -27 dBm / -8 dBm receiving. Unfortunately, I did not find detailed information about Funbox 3.0, what is the maximum signal sensitivity limit. I suspect Over -30 (dBm).
    In the contract, I should not disconnect the FB3.0 from the power supply for the next 10 days in order to optimize the signal. I am curious if these values will change.
    Are my parameters correct? and can they be better?
    best regards :)
  • #2 16867684
    sylweksylwina
    Help: 1882
    Rate: 2355
    If the speeds are ok, you have nothing to worry about ;)
    As you provide, the parameters are within those you provided for the ONT terminal, probably for FB 3.0 it is similar, after all, the technology is the same ...
  • #3 16867729
    berkos112
    I think so too :) I compared it to the WiFi Analyzer and the signal quality "very good" should not exceed -30 dBm is also oki, considering that the download and upload speeds exceed those offered by ISP. It's just a pity that I can't manually change the MTU to the maximum frame. In my case it is 1500 and FB3.0 is set to 1540.
    Before I close the topic, I will give a chance to others who are familiar with the topic :)
    Thank you very much for your answer.
    sylweksylwina
    Help: 1882
    Rate: 2355
    berkos112 wrote:
    I compared it to WiFi Analizer and the signal quality "very good" should not exceed -30 dBm is also ok
    It just has nothing to do with it :)
    Is it about LAN? It misses the point, as the sizes of the frames vary, the effect may be counterproductive. In fact, the speed gain will be small anyway, I prefer to leave the default MTU, because you never know what device I will connect to the network. For more switch-server bandwidth, I have the trunking port set, here is the bigger difference.
  • #5 16867915
    berkos112
    Oki, got it. Thanks for the clarification. I close the topic :)
