[Solved] Speed Limit Issue with Netia Optical Fiber WiFi - 100mb, Modem, Router, Samsung S6, Huawei Mate 9
Lusy312 7446 11
How can I increase the Wi‑Fi speed on my Netia 100 Mb fiber connection, and can I replace the Netia router with my own?
Yes—if the cable connection reaches about 98 Mb/s but Wi‑Fi stays around 20 Mb/s, the Netia Spot is likely the bottleneck, so replacing it is the recommended fix [#16987508] The replies say these routers have poor Wi‑Fi range and limited bandwidth, so you should ask your operator whether you can use your own router instead [#16987508][#16987792] Rather than a basic TP-Link, look for a router with 802.11ac Wi‑Fi and gigabit ports so you are not forced to upgrade again if your speed plan changes [#16987792] Suggested examples were Netis AC1200 WF2780 and Tenda AC9 [#16987792]
  • #1 16987419
    Lusy312
    Hello for 2 weeks I am the owner of the Internet from Netia 100mb fiber for this gave a modem plus a black WiFi router from Netia whose speed is limited to 20mb some cable without restrictions 98mb speed checked on Samsung Galaxy S6 and Huawei Mate 9 and tv box sunvell. How to increase wifi speed or change WiFi router to tplink?
    • Speed Limit Issue with Netia Optical Fiber WiFi - 100mb, Modem, Router, Samsung S6, Huawei Mate 9 Screenshot_20180125-115548.png (569.73 KB) You must be logged in to download this attachment.
  • #2 16987440
    Pedros050
    Help: 2471
    Rate: 3927
    Hello. You signed the contract for 100Mbps? What router model did Netia give?
  • #3 16987498
    Lusy312
    Yes, the contract for 100mb as I wrote on the cable from this router is no problem is 98mb / 96mb only wifi lime distance from the router 2metry not saying what a lime in the other room walls thin lack of reinforcement gives a screen router.
    • Speed Limit Issue with Netia Optical Fiber WiFi - 100mb, Modem, Router, Samsung S6, Huawei Mate 9 Screenshot_20180125-123426.png (515.56 KB) You must be logged in to download this attachment.
    Pedros050
    Help: 2471
    Rate: 3927
    And Netia SPOT so advise you to replace the poor Wi-Fi range these routers have and is an option with a limited bandwidth.
  • #5 16987512
    Lusy312
    Ok thank you greetings
    I will check on tplink there was the same wifi speed as on the cable.
    Added after 1 [hours] 29 [minutes]:
    Will such a router improve speed
    • Speed Limit Issue with Netia Optical Fiber WiFi - 100mb, Modem, Router, Samsung S6, Huawei Mate 9 Screenshot_20180125-141317.png (823.07 KB) You must be logged in to download this attachment.
    LucekB
    Help: 143
    Rate: 137
    Ask your operator if you can have your router.
    This tp-link is a poor choice
    look for something with wi-fi AC and maybe with gig ports, because if you increase the option to e.g. 300, then exchange again,
    Proposed Netis AC1200 WF2780, Tenda AC9
    Price-your budget issue
  • #7 16987830
    sebap
    Help: 538
    Rate: 1083
    What is the distance from the router? Detached house or flat in a block of flats? Make a scan with inSSIDer or WiFi Analyzer on your phone and upload screenshots here.
  • #8 16987918
    Lusy312
    Distance from the router 2metry housing estate test I will do the next week on a business trip
    Added after 2 [hours] 21 [minutes]:
    Ok purchased router netis ac 1200wf 2780
  • #9 17218188
    majka420
    Rate: 27
    I connect to the topic I have a similarly connected net fiber with Netia router + modem. Router in my parents' room and I have a hotspot for wifi around 5 meters in a block of flats They promised max 100mb and today I'm pulling 30 mb. I have a Realtek RTL8723BE Wireless LAN 802.11n PCI -E NIC in my laptop
  • #10 17218252
    Pedros050
    Help: 2471
    Rate: 3927
    Make router model?
  • #11 17257166
    trompka36
    I am in the same situation (PON and 100 Mb + TV) - I want to exchange Netia Spot for Xiaomi 3g with preloaded Padavan.
    Were you able to replace the internet router with an alternative router?
  • #12 17464388
    Lusy312
    Changing the router to 5ghz wifi and after a problem
The discussion revolves around a user experiencing limited Wi-Fi speeds (20 Mbps) with a Netia 100 Mbps fiber internet connection, despite achieving close to the full speed via wired connection. The user inquires about improving Wi-Fi performance and considers replacing the provided Netia router with a TP-Link model. Responses suggest that the Netia router has poor Wi-Fi range and limited bandwidth, recommending alternatives with better specifications, such as routers with Wi-Fi AC and gigabit ports. The user ultimately decides to purchase a Netis AC1200 WF2780 router to enhance their Wi-Fi speed.
TL;DR: On Netia 100 Mb fiber, Ethernet reaches 96–98 Mb/s while Wi‑Fi stalls around 20 Mb/s; “speed is limited to 20 Mb.” [Elektroda, Lusy312, post #16987419] Why it matters: This FAQ shows how to fix slow Netia Wi‑Fi, choose better routers, and verify if 5 GHz solves your cap—ideal for users asking how to get full 100 Mb over Wi‑Fi.
Why is my Netia 100 Mb fast on cable but slow on Wi‑Fi?
Users saw 96–98 Mb/s via Ethernet but ~20 Mb/s over Wi‑Fi on the supplied router. This points to wireless limits, not the fiber line. The radio, firmware settings, and 2.4 GHz congestion often cap throughput. Verify with a wired speed test first, then compare Wi‑Fi beside the router. If cable is near 100 Mb/s and Wi‑Fi isn’t, upgrade the Wi‑Fi layer. [Elektroda, Lusy312, post #16987419]
Does switching to 5 GHz fix the Netia Wi‑Fi speed cap?
Yes, the thread’s resolution was to change the router and use 5 GHz Wi‑Fi. After that, the speed problem disappeared. 5 GHz reduces interference and supports higher modulation rates than 2.4 GHz, lifting the cap many users see. “Changing the router to 5 GHz Wi‑Fi and after a problem.” [Elektroda, Lusy312, post #17464388]
Is the Netia SPOT router limiting my bandwidth?
A contributor advised replacing Netia SPOT, citing “poor Wi‑Fi range” and an available bandwidth‑limit option. If you must keep it, review its wireless mode, channel width, and any QoS/limit settings. However, swapping to a modern 5 GHz AC router is the cleaner fix. “Poor Wi‑Fi range” reflects repeated user reports. [Elektroda, Pedros050, post #16987508]
What replacement routers did users recommend for 100 Mb fiber?
Recommendations included dual‑band AC models with gigabit ports: Netis AC1200 WF2780 and Tenda AC9. These support 5 GHz and higher PHY rates, better matching a 100 Mb/s service and leaving headroom if you upgrade later. Confirm compatibility with your operator first. [Elektroda, LucekB, post #16987792]
Can I use my own router with Netia fiber?
One poster said to ask the operator if you can use your own router. Policies vary by service and TV bundle, so confirm before buying. If allowed, bridge the provider device or connect your router behind it, then test speeds. [Elektroda, LucekB, post #16987792]
How far can I be from the router and still get 100 Mb/s on Wi‑Fi?
Distance and obstacles matter. A user reported about 30 Mb/s at roughly 5 meters in a flat on an 802.11n laptop. That shows 2.4 GHz N may underperform at short ranges too. For near‑100 Mb/s over Wi‑Fi, use 5 GHz AC close to the router. [Elektroda, majka420, post #17218188]
How do I check for channel congestion on my Wi‑Fi?
Scan nearby networks with inSSIDer or WiFi Analyzer on your phone. Note channel overlap and signal strength, then pick a quieter channel. This simple check often boosts throughput without new hardware, especially on 2.4 GHz. Upload screenshots if you need peer review. [Elektroda, sebap, post #16987830]
What if I’m only 2 meters away and Wi‑Fi is still slow?
That happened in the thread. Even at 2 meters, Wi‑Fi stayed sluggish while Ethernet was fine. Thin walls and router design can still bottleneck 2.4 GHz. Switching to a 5 GHz‑capable router resolved the issue later. Test near the router first to confirm. [Elektroda, Lusy312, post #16987498]
Will my 802.11n laptop reach the full 100 Mb/s?
It may not. One user with a Realtek 802.11n card saw around 30 Mb/s at about 5 meters. 802.11n link rates depend on spatial streams, channel width, and noise. Upgrading to 5 GHz AC or adding a USB AC adapter can help. [Elektroda, majka420, post #17218188]
How do I fix slow Netia Wi‑Fi right now? (3‑step quick win)
  1. Confirm wired speed is ~100 Mb/s using Ethernet.
  2. Replace the router with a dual‑band AC model (e.g., Netis AC1200 WF2780, Tenda AC9).
  3. Ask Netia whether using your own router is permitted, then configure and retest. [Elektroda, LucekB, post #16987792]
Does replacing the router affect my service or TV bundle?
It can. The advice was to check with the operator before swapping gear. Some bundles require the provider’s device for authentication or TV features. If allowed, use bridge mode or place your router behind theirs for Wi‑Fi duties. [Elektroda, LucekB, post #16987792]
Was anyone able to replace Netia SPOT with a Xiaomi 3G (Padavan)?
A user asked about swapping Netia SPOT for Xiaomi 3G with Padavan on a 100 Mb PON + TV setup. The thread’s final success came from moving to 5 GHz, but no direct Xiaomi confirmation was posted. Ask your operator first. [Elektroda, trompka36, post #17257166]
