T-Mobile Home Internet: Best Antenna for B529 & B525 Routers (Load, Speed, YT Quality)
Takezos 2895 2
  • #1 16875061
    Takezos
    I have been testing home internet with t-mobile since yesterday. I have a B529 router, I'm going to replace it tomorrow with B525.
    At the moment, the B529 download jumps between 10-20 mb in the hours around noon, which is enough for me, but in the evening you can see that the load is heavy, the speed jumps a lot and the yt works at 240p quality and the range of 3 lte lines is cut. When I take the router outside, the range increases to 4 and yt is already running normally even in 1080 quality. I installed HManager and the router connects only to this bts, I have about 3 km to it from the roof of the house it can be seen http://beta.btsearch.pl /?dataSource=locations&network=&standards=&bands=cer=51.755582%2C20.248475&
    Now the question of what antenna to choose, so far I have an eye on the b525
    http://www.cybertech.com.pl/p162,antena-dualna-lte-4g-15dbi-mimo-do-huawei-b525-b715.html
    http://allegro.pl/antena-lte-huawei-zte-sma-dipol-2-polaryzacje-i5545325166.html
    or maybe some other?
    hmanager data from 20.00, tomorrow I can upload external data and screenshots
    car:
    download 13, upload 2.21
    lte +
    rssi -83dBm
    rsrq -13dB
    rscp -145
    rsrp -114dBm
    sinr 3db
    LTE_800
    download 6.73, upload 9.92
    rssi -75dBm
    rsrq -11dB
    rscp -145
    rsrp -100
    sinr 5dB
    Lte 1800 as for the car
    rssi -87
    rsrq -13dB
    rscp -145
    rsrp -114dBm
    sinr 3db
    lte 2100 does not connect at all
    edit
    I already have this b525 and with it I have better range and speeds of up to 30mega
    it is best for lte 800, speeds up to 30 pings 20, stable range does not lose reach and nothing jumps,
    on lte 1800 speeds about 10 mega pings 30, one dash range
    lte 2100 and more does not connect to them at all, despite the fact that the info about bts is that 2100 supports.
    and now it does not make sense to take the cabletech antenna on the 1800-2100 frequency
    to take this antenna? http://allegro.pl/antena-lte-huawei-zte-sma-dipol-2-polaryzacje-i5545325166.html
    or maybe some other on the frequency only 800 and 1800 ??
  • #2 16886531
    makosuu
    Help: 369
    Rate: 370
    On LTE800 you have sufficient range, but low sinr so BTS is loaded. If you are not satisfied with the wifi range, consider an additional AP connected by cable or PLC. Place the router on top where you have good range and you should do without an antenna.
  • #3 16887009
