32GB microSD Card Error: Unable to Format, Used in Car Camera, Deleting Files Problem
gonzolex 5829 8
  • #1 16876054
    gonzolex
    Hello! I have the following problem; when I want to format my 32GB microSD card, I put it in the adapter, move the jumper, adapter to the computer, open "My Computer" with the right mouse button on my card -> Format. And here comes the error. I'm trying to format but at the end I get the message "Windows was unable to format"
    What is wrong? Did the card fall?
    I would add that the card was used for over 2 years, it was used to record videos from the car camera. I came across the problem by accident, as it turned out that I need to rip something from the card and only old recordings there - that is, for a long time did not save anything.
    Or is it a trivial thing, but I'm too stupid to solve it myself?
    I will add that the eggs are with this card, if I manually delete files from it, i.e. PPM -> delete and almost all files are removed normally (a progress bar is shown, it takes a while, etc.) there are only 2 files about 0kb which I do not want to delete and with them the parent directories. The strange thing is that all files return after a while. They come back normally. I remove, disconnect the card from the computer, after some time (5 minutes np) I plug it again and what? The files are back intact ... Have you ever encountered anything like this?
    I tried to format the card with various programs (e.g. SD Formatter, gparted, sd format, hd low level format, DMDE, reset it with various other programs) and nothing. Either it undergoes zeroing / formatting, but the files still remain, or there is an error that it cannot reset / format.
    How I do chkdsk I have info: Deleting invalid long \ CARDV \ MOVIE folder entry ...
    90% done ..... - And it ends there
    Once I had info about "the file is crossed in the allocation unit .." and here were the numbers and the path along with the file
    Can the card be saved?
  • #2 16876065
    Kasek21
    Help: 4981
    Rate: 3548
    Check the card including: H2 Test
  • #3 16876382
    gonzolex
    log z H2Testw:
    Warning: Only 409 of 30179 MByte tested.
    The media is likely to be defective.
    0 KByte OK (0 sectors)
    409 MByte DATA LOST (837632 sectors)
    Details:0 KByte overwritten (0 sectors)
    0 KByte slightly changed (< 8 bit/sector, 0 sectors)
    409 MByte corrupted (837632 sectors)
    0 KByte aliased memory (0 sectors)
    First error at offset: 0x0000000000000000
    Expected: 0x0000000000000000
    Found: 0x05c805420582067f
    H2testw version 1.3
    Writing speed: 1.02 MByte/s
    Reading speed: 577 KByte/s
    H2testw v1.4
  • #4 16876385
    Kasek21
    Help: 4981
    Rate: 3548
    You didn't select the whole capacity for the test?
    Looking at the transfer, you may conclude that the card has been damaged.
  • #5 16876416
    gonzolex
    I marked "all available space" and shows me here differently, once 480 mb MB, now 690 mb MB and the card has 31,644 properties mb MB.
  • #6 16876425
    Kasek21
    Help: 4981
    Rate: 3548
    Damaged card.
  • #7 16876467
    gonzolex
    not to be saved?
  • #9 16876593
    gonzolex
    Prosze
    Spoiler:
    ========== Storage Volume on Disk 1 in Partition 1 ==========
    MountPoint = I:\
    Volume Label = ---
    Volume Size = 31,7 GB / 29,5 GiB / 31 653 363 712 Bytes
    Volume Size User = 31,6 GB / 29,5 GiB / 31 644 975 104 Bytes
    File System = FAT32
    Volume Serial = B4F0-5EC2
    File System Flags = CASE_PRESERVED_NAMES, UNICODE_ON_DISK
    Volume Name = \\?\Volume{7228a522-d915-11e7-90f9-bc84ee75fab7}\
    KernelName = \Device\HarddiskVolume11
    Win32 Device Name = \\.\HarddiskVolume11
    Writable = yes
    1st Cluster Align = 4 M
    Disk Size = 31,7 GB / 29,5 GiB / 31 650 877 440 Bytes
    Disk Geometry = 3848 Cylinders, 255 Heads, 63 Sectors per Track, 512 Bytes per Sector
    Disk Signature = 00000000
    Drive Type = removable
    Bus Type = Unknown
    Device Types = CardReader, RemovableMedia
    DeviceID = STORAGE\VOLUME\_??_SCSI#DISK&VEN_JMCR&PROD_SD&REV_#000000#{53F56307-B6BF-11D0-94F2-00A0C91EFB8B}
    DeviceID Drive = SCSI\DISK&VEN_JMCR&PROD_SD&REV_\000000
    DeviceID Ctrl = PCI\VEN_197B&DEV_2382&SUBSYS_3659103C&REV_00\4&9078216&0&01E4
    Host Controller = JMicron PCIe SD/MMC Host Controller
    DevicePath = \\?\storage#volume#_??_scsi#disk&ven_jmcr&prod_sd&rev_#000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}#{53f5630d-b6bf-11d0-94f2-00a0c91efb8b}
    Port Name = 0-0-0
    -------------------------- Disk 1 --------------------------
    Disk Signature = 00000000 (00,00,00,00)
    Disk Writable = yes
    Trim Enabled = no
    PtMgr DiskId GUID = {7228a520-d915-11e7-90f9-bc84ee75fab7}
    Volume Count = 1
    PartitionTable = MBR
    Partition Count = 1
    Partition1954512 Type = 0x0C
    Start = 0x400000
    Length = 0x75EB00000 (31,7 GB)
    Align = 4 M
    Name = \Device\Harddisk1\Partition1
    Win32 Device = \\.\Harddisk1Partition1
    Bus Type = Unknown
    Device ID = SCSI\DISK&VEN_JMCR&PROD_SD&REV_\000000
    Device ID Ctrl = PCI\VEN_197B&DEV_2382&SUBSYS_3659103C&REV_00\4&9078216&0&01E4
    KernelNames = \Device\Harddisk1\DR5, \Device\Scsi\JMCR1Port1Path0Target0Lun0
    Win32 Device = \\.\PhysicalDrive1
    DevicePath = \\?\scsi#disk&ven_jmcr&prod_sd&rev_#000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
    Capabilities = 0x74 (Removable, UniqueID, SilentInstall, RawDeviceOK)
    Removal Policy = surprise removal ('Optimize for quick removal')
    Hotplug Device = yes
    Hotplug Media = no
    Removable Media = yes
    Command Queueing = no
    Friendly Name = JMCR SD SCSI Disk Device
    Port Name = 0-0-0
The discussion revolves around a 32GB microSD card that the user is unable to format after two years of use in a car camera. The user encounters an error message stating "Windows was unable to format" when attempting to format the card via a computer. Despite successfully deleting most files, two 0KB files remain undeletable. Responses indicate that the card may be defective, as tests using H2Testw reveal significant data loss and corruption. The card's capacity appears inconsistent, suggesting damage. Recommendations include further testing and checking the card's information for diagnostics.
