[Solved] Unable to Delete Photos from 32GB Kingston Memory Card after Wondershare Data Recovery
Kariama 10518 3
  • #1 17362284
    Kariama
    I warmly welcome
    I was looking for a similar problem on the site and did not find it
    1 card has no lock I was moving the pin
    it's a 32 GB Kingston card
    the problem occurred after recovering files from the card / I accidentally deleted the photo which I later recovered with Wondershare Data Recovery /
    Nothing helps to delete now
    1 Formatted in computer and camera
    2. I deleted data on the computer as well as individual photos on the camera
    The folder will disappear for a moment ...
    after removing the card from the reader or restarting the camera
    the folder appears again
    I don't know what to do anymore
  • #2 17362289
    safbot1st
    Help: 2719
    Rate: 1585
    Check if the card can be formatted by deleting the partition and re-establishing with diskpart.
  • #3 17362298
    jozefg
    Help: 197
    Rate: 746
    I also had such a case.
    The medicine turned out to be Linux G-Parted on CD. He cleared everything
  • #4 18121323
    Kariama
    Problem not solved
