32GB Micro SD Card Not Formatting: Errors in Diskpart, SDformatter, Low Level & HP USB Tools
ubidragon 3390 5
  • MicroSD card appears permanently write-protected
    #1 16213607
    ubidragon
    Rate: 28
    Hello, I have a 32 GB Micro SD card, recently something has started to happen to it. It cannot be formatted. The card is normally read and visible on the phone and computer, but neither the phone nor the computer can be formatted. The files on the card can be read without any problems. When I try to format my computer I get the error "Windows was unable to complete formatting". I have tried with other programs but also there is a bug.
    Diskpart - Access is denied when wiping is attempted.
    SDformatter - write protected error
    Hard Disk Low Level Format Tool - formatting completed without errors, but the data remains intact
    HP USB Disk Storage Format Tool - formatting error
    I also tried to manually remove and add files from the card, but after reconnecting the card it turns out that the data is also unchanged.
    I also made sure that the adapter is set to the unlocked position.
  • #2 16213768
    scotch
    Help: 78
    Rate: 148
    What type card. Does write protection exist or not?
  • #3 16213835
    Micek64
    Help: 34
    Rate: 75
    As for mine, the card died
  • #4 16214073
    ubidragon
    Rate: 28
    The card is micro SD HC DATA 32GB class 10, U1
    diskpart shows no security, I even tried to remove it.
  • #5 16306917
    siwy1_1
    I have the same and there is nothing I can do. And he reads normally
  • #6 16374662
    ubidragon
    Rate: 28
    It looks like the card was amen. Various programs and methods do not work. It is true that the data that was on the card can be read, but any modification is blocked.
