Grundfos Alpha2 L Pump - Control Panel Flashing, All LEDs Blinking, Troubleshooting & Fixes
Przemek6699 17652 15
How can I fix a Grundfos Alpha2 L pump whose control panel LEDs all blink after power-up and the pump does nothing?
Yes — this symptom is often fixed by replacing capacitors on the pump’s electronics board. One user reported success by changing the SMD 47 µF / 35 V electrolytic capacitor and two 150 nF / 275 V MKP or MKT capacitors [#19347186] Another user confirmed that replacing the 47 µF / 35 V SMD capacitor alone made the pump work again [#20202214] The repair cost was reported to be low, and the flashing stopped after the capacitor replacement [#19651202]
  • #1 16878699
    Przemek6699
    I have a Grundfos Alpha2 L pump. After connecting the power supply on the panel all the LEDs are blinking and nothing works. Can it be fixed?
  • #2 16879137
    osiniak75
    Help: 350
    Rate: 544
    Everything is described in the manual. Just take a look. greetings
  • #3 16880704
    Przemek6699
    I only have the pump, no papers.
  • #4 16880863
    osiniak75
    Help: 350
    Rate: 544
    The manual is available on the manufacturer's website.
  • #5 16880954
    Felini
    Moderator
    Help: 124
    Rate: 433
    Instructions for the Grundfos Alpha2 L pump in the appendix.
    Grundfos A...pha2 L.pdf (7.63 MB)You must be logged in to download this attachment.
  • #6 16882260
    Przemek6699
    However, the manual does not respond to the blinking LEDs on the control panel after the power is applied.
  • #7 16882538
    osiniak75
    Help: 350
    Rate: 544
    Chapter 11. Troubleshooting - page 23 of this manual.
  • #8 16997240
    Świętoszek
    Help: 5
    Rate: 25
    I also have a problem with this pump. POWER LEDs are off and the rest are on simultaneously. What should be the supply voltage to control the board? There is a chance to get a working plate? There are nowhere in the websites - no spare parts for pumps of this type.
  • #9 17001615
    mariusz.lubicz
    Help: 44
    Rate: 146
    Take good photos of the electronics
  • #10 17199969
    banita_1
    I think it was about a glitch that I am also experiencing ...
    Everything just lights up and dims - there is no E ... the autoadapt is trying to ignite the hardest ...
  • #11 17232950
    mariusz.lubicz
    Help: 44
    Rate: 146
    So take photos of the electronics board too. We will estimate what might have gone wrong.
  • #12 17233590
    BUCKS
    Help: 536
    Rate: 1087
    How many years / months did your pump run as a failure-free device?
    I have an old pump that is 12 years old and spinning. And reading various posts on the Internet, I have the impression that in these modern, energy-saving pumps, the weakest link is electronics, which, if it collapses after a few years, the pump is suitable for scrap, because an authorized service does not repair it.
    Why is the EU not fighting for ecology and will not guarantee the option of replacing electronics with a new one. As you can see, ecology is empty words, because being ECO is promoted only when it is convenient, profitable for the promoter and specific interest groups.
  • Replacing failed capacitors fixed Alpha2 pump panel flashing
    #13 19347186
    bolo28
    Rate: 9
    I know that the topic is old, but maybe it will help someone. I also had the control panel on the Grundfos Alpha 2 pump flashing, and the pump did not work. The replacement of capacitors on the electronics board helped: one smd 47 uF / 35V electrolyte and 2 MKP or MKT 150 nF / 275V. Someone somewhere wrote about it on the net, it helped me. I replaced without checking the old ones (I had nothing) and maybe not all I need, but the cost is small, so I did not think about it.
  • #14 19651202
    GlenAllanEikeland
    Thanks a million. I had the same flashing light. Changed the capacitor and it worked like a charm. Capacitor cost approx. 10 USD.
  • #15 19691469
    MR
    Help: 73
    Rate: 116
    Has anyone measured the voltage on the SMD 47uF capacitor?
    After replacing it, I have 15 V.
  • #16 20202214
    jarakasan
    Just replace the 47uF / 35V SMD capacitor and it works. I did.
The discussion revolves around troubleshooting the Grundfos Alpha2 L pump, specifically addressing the issue of all LEDs blinking on the control panel after power connection. Users suggest consulting the manual for troubleshooting guidance, although some report that the manual does not specifically address the blinking LED issue. A common solution mentioned involves replacing the SMD capacitor (47uF/35V) on the electronics board, which has reportedly resolved similar problems for multiple users. Concerns about the longevity and repairability of modern energy-saving pumps are also raised, highlighting the potential for electronic failure after a few years of use.
TL;DR: If your Grundfos Alpha2 L shows all LEDs flashing and won’t run, a single $10 capacitor swap often restores operation; as one user put it, “worked like a charm.” [Elektroda, GlenAllanEikeland, post #19651202]
Why it matters: This FAQ helps DIYers quickly diagnose and repair the common flashing-LED fault without hunting scattered forum posts.
Why are all LEDs flashing on my Grundfos Alpha2 L and the pump won’t run?
This fault indicates the control board isn’t initializing. Users report the panel flashing, dimming, and no motor activity on power-up. It often traces to aging capacitors on the electronics board. Replacing the supply/filter capacitors restores startup logic and drive. Start with the 47 µF/35 V SMD electrolytic. If symptoms persist, consider the two 150 nF/275 V film capacitors. This behavior matches reports where the control panel flashes and the pump remains off. [Elektroda, bolo28, post #19347186]
What single fix most often solves the flashing-LED problem?
Replace the SMD electrolytic capacitor rated 47 µF/35 V on the control PCB. Multiple users confirm the pump immediately returns to normal after this swap. One successful repair notes, “Just replace the 47uF / 35V SMD capacitor and it works.” Keep polarity correct and use a quality part. This is the fastest low-cost repair reported for the Alpha2 L flashing issue. [Elektroda, jarakasan, post #20202214]
Which exact capacitors have others replaced to fix this?
Common replacements are one SMD 47 µF/35 V electrolytic and, in some cases, two film capacitors marked 150 nF/275 V (MKP or MKT). One user replaced all three parts without even measuring the old ones and restored full function. These parts sit in the low-voltage supply and EMI sections of the board. Use equal or higher temperature and voltage ratings. [Elektroda, bolo28, post #19347186]
How much will this DIY repair cost me?
Expect about $10 for the main replacement capacitor, based on a user who reported a successful outcome. Prices vary by brand and local supply. Even with two film capacitors added, the total remains low compared with a new pump. This cost-to-benefit ratio makes the repair attractive for out-of-warranty units. [Elektroda, GlenAllanEikeland, post #19651202]
Do you have a quick 3-step how-to for replacing the capacitor?
  1. Isolate mains, remove pump head, and access the control PCB.
  2. Desolder the 47 µF/35 V SMD capacitor, clean pads, and solder in a new quality part (match polarity).
  3. Optionally replace two 150 nF/275 V MKP/MKT film capacitors; reassemble and test. This approach restored normal operation for multiple users. [Elektroda, bolo28, post #19347186]
What voltage should I read near the new 47 µF capacitor?
One user measured about 15 V across the replaced 47 µF capacitor. Use this as a ballpark check that the control supply is alive. Measurements vary with meter and board revision. If you read zero or erratic voltage, recheck solder joints and upstream components. [Elektroda, MR, post #19691469]
Where is troubleshooting in the official manual?
The forum pointed to Chapter 11, Troubleshooting, on page 23 of the linked manual. That section covers symptoms and corrective actions. Use it to complement the capacitor check described here. It helps verify installation, air locks, and operating modes before board-level work. [Elektroda, osiniak75, post #16882538]
I don’t have the paperwork—where can I get the manual?
The manual is available on the manufacturer’s website. Download the correct version for your pump’s exact model code. Check the rating plate to match series and variant. A forum responder explicitly directed users there for documentation. [Elektroda, osiniak75, post #16880863]
My AutoAdapt tries to start, everything lights, then dims—what does that mean?
That behavior aligns with a control glitch described by another owner. The LEDs light, then fade, and AutoAdapt struggles to start. This again points to weak supply capacitors on the control board. Replacing the noted capacitors restored normal AutoAdapt operation for others. [Elektroda, banita_1, post #17199969]
Can I buy a replacement control board for the Alpha2 L?
A user searching for a working board reported no spare parts available online for this pump type. They asked about supply voltage and could not find a replacement PCB source. This suggests official boards are scarce at retail, making component-level repair preferable. [Elektroda, Świętoszek, post #16997240]
Should I post photos of my electronics for diagnosis?
Yes. Helpers requested clear, well-lit PCB photos to estimate what failed. Show both sides, connector areas, and any heat-discolored parts. This makes remote troubleshooting faster and safer. Several replies specifically asked for good electronics photos before advising. [Elektroda, mariusz.lubicz, post #17001615]
Is this type of failure common in modern high-efficiency pumps?
One commenter noted older pumps running 12 years without issues, but newer energy-saving models fail at the electronics. They added that authorized services often don’t repair boards, pushing full replacement. This highlights an e-waste concern and a reason DIY repairs matter. [Elektroda, BUCKS, post #17233590]
What does “MKP/MKT 150 nF / 275 V” mean in this context?
They are polypropylene or polyester film capacitors (150 nF, 275 V AC class) used for suppression or filtering. In one successful repair, two such caps were replaced with the 47 µF electrolytic. Match capacitance and voltage rating, and use reputable brands. [Elektroda, bolo28, post #19347186]
Will replacing only the 47 µF capacitor be enough?
Often, yes. One user reported “Just replace the 47uF / 35V SMD capacitor and it works.” Start there, then evaluate. If instability remains, consider the two 150 nF film capacitors. Keep soldering neat to avoid new faults. [Elektroda, jarakasan, post #20202214]
Any proof that this fix actually works?
Multiple owners confirmed success after the capacitor swap, including a clear report: “Changed the capacitor and it worked like a charm.” This supports the repair path for flashing-LED failures. It’s a low-risk, low-cost attempt before replacement. [Elektroda, GlenAllanEikeland, post #19651202]
What does SMD mean when ordering the 47 µF capacitor?
SMD stands for Surface-Mount Device. The 47 µF/35 V electrolytic on this board is an SMD style component. Order the same footprint and orientation. Observe polarity during replacement to prevent reverse-bias damage. [Elektroda, bolo28, post #19347186]
