Peugeot 407 (2006) Automatic BVA AM6 20GK01 Gearbox Issue: Difficulty Shifting from P to R or D
borki 10749 9
Why does a Peugeot 407 2006 automatic AM6 gearbox drag or strain the engine when shifting from P to R or D, even though it drives normally afterward?
The thread points to a faulty torque converter clutch as the most likely cause of the engine dragging when you shift from P to R/D. Other possible causes mentioned were the TCC solenoid, the valve body, or the transmission control computer, but the later replies favored the converter clutch because the ATF looked dark/burnt and the idle speed was normal [#16881704][#16881813][#16885041] The suggested next step was to try replacing the clutch first [#16886698]
  • #1 16881492
    borki
    Hello, I bought a peugeot 407 2006 year automatic transmission bva am6 20gk01 the problem is with it after turning on from p to R or D position, the car starts to move if I press the brake, the car can strangle it as if the clutch did not work, someone may help me, maybe it had a similar case greetings
  • #2 16881704
    romuald-f
    A/T specialist
    Help: 407
    Rate: 1551
    There may be a problem with the torque converter or with the TCC solenoid, or with the valve plate itself, or with the transmission control computer (one failure causes adolescence). The AM6 gearbox (that's what the French mean) is the gearbox of the Japanese manufacturer Aisin Warner TF80SC.
  • #3 16881780
    borki
    But the box works properly later, neither jerks nor slips
  • #4 16881804
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    @borki What are the free spins?
  • #5 16881813
    Tomasz Downacki
    Help: 10
    Rate: 49
    It looks like the converter clutch is damaged.
  • #6 16881913
    borki
    The turns are equal
    I also checked the oil was quite wholemeal and it felt like it was burnt but there were no filings
  • #7 16881939
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    @borki I did not ask about it, but about their value.
  • #8 16885040
    borki
    Turns on the cold around 1000 later go down above 800
  • #9 16885041
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    So correct .... Therefore, a suspicious converter clutch, as said by a colleague @Tomasz Downacki .
  • #10 16886698
    borki
    So we will try replacing the clutch so far, thank you in advance
The discussion revolves around a 2006 Peugeot 407 experiencing issues with its automatic BVA AM6 20GK01 gearbox, specifically difficulty shifting from Park (P) to Reverse (R) or Drive (D). The user reports that the car moves when the brake is pressed, suggesting a potential clutch problem. Responses indicate possible causes, including a damaged torque converter clutch, TCC solenoid issues, or problems with the valve plate or transmission control computer. The user notes that the transmission operates normally otherwise, with no jerking or slipping. After checking the transmission fluid, which appeared burnt but without filings, the user plans to replace the clutch as a potential solution.
