[Solved] Comparing Single-Layer PEX and Multi-Layer Alupex for Underfloor Heating
sunlux 23064 6
  • #1 16882705
    sunlux
    Help: 20
    Rate: 120
    Hello colleagues.
    I am asking for simple advice.
    From what I'm talking about, the most common pipe for water underfloor heating is the alupex multilayer pipe.
    I know that single layer pex pipes are sometimes used, which are easily laid by passing hot water through the pipe during laying.
    I wonder two things:
    - due to the diffusivity of oxygen from the heat factor (water) is it not safer (durable) to use the alupex multilayer pipe?
    - do single-layer pex pipes sometimes have better thermal transmittance and thus do not give more heat to the floor because they have a thinner wall?
    Of course, single-layer pex is cheaper than multi-layer alupex, but for me, mainly due to the small amount of square meters to cover, the cost is not so important.
    What pipe do you recommend and why?
    Serwis Kotłów
    Help: 25
    Rate: 123
    1. Permeability is at a very similar level, often has the same value - so we skip this point
    2. When used for co, the pipe should always have an anti-diffusion layer - inform the manufacturer about it
    3. A multilayer pipe, e.g. PE-Xc / AL / PE, where the aluminum jacket and the external PE protective coating have definitely greater resistance to:
    mechanical damage
    buckling resistance,
    temperature
    pressure
    and almost 10 times smaller linear elongation ....
    The disadvantage is the higher purchase price, but it is just a permanently connected element with the building structure. So let's buy a branded product, invite an authorized installer to do a pressure test, have at least 20 years warranty and not do premature repairs.
    I also gave the multilayer pipe for the sanitaire, I do not like to return to the same topic twice.
    mietek654
    Help: 140
    Rate: 292
    Hello, multilayer pipes are more durable.
  • #4 16882825
    sunlux
    Help: 20
    Rate: 120
    Cool,
    thank you for your comments colleagues Kotłów and mint 654.
    I also think that multilayer alupex are better and more durable, and so several people rightly convinced me.
    I wasn't just sure about heat permeability.
    Now, of course - I choose alupex
    If anyone is interested, I need a good installer - a robot to make Poznań / the surrounding area - not a lot but 42m2, 4 loops, two rooms, so about 400mb of pipe for positioning and connecting to a concealed distributor with a pump-mixing group. The cabinet and manifold will already be installed. Styrofoam is ready, just put the foil and lay the pipe on the clips. Please write at PW.
  • #5 16882846
    misiek1111
    Level 37  
    Help: 325
    Rate: 1100
    400m pipe for 42m? :?: :?:
  • #6 16882863
    sunlux
    Help: 20
    Rate: 120
    It will come out a little less but on average I count 10mb / 1m?, spacing on average every 10 cm.
    I am more focused on spacing every 10 cm and the length will come out the same.
    I care about oversizing and heating the lowest possible temperature.
    The manifold with a mixing-pump group has a mixer range from 20-43 ° C, so it will not be a problem.
    If any of your colleagues have any comments or suggestions, I will gladly listen to them.
    Spout will come out less ... :D
  • #7 17495077
    sunlux
    Help: 20
    Rate: 120
    I chose the AluPex multilayer pipe
The discussion centers on the comparison between single-layer PEX and multi-layer Alupex pipes for underfloor heating systems. Participants highlight that while both types of pipes have similar oxygen permeability, multi-layer Alupex pipes (PE-Xc / AL / PE) offer superior durability, mechanical resistance, and lower linear elongation, making them a more reliable choice despite their higher cost. The author expresses a preference for Alupex due to its durability and seeks recommendations for a qualified installer for a specific project involving 42m² of underfloor heating. There is also a clarification regarding the amount of pipe needed for the installation, emphasizing the importance of spacing for optimal heating efficiency.
