Camspot 4.5 and 3.2 Wi-Fi cameras. No image on Camspot 2.1 recorder
16czarny16 5724 13
How can I get one Overmax Camspot camera to show video on a Camspot 2.1 recorder when the recorder detects it but returns an IP/error or login/password error, while the same camera works on PC and phone?
The most likely fix is to update the firmware in both the recorder and the cameras, and then re-check the camera settings such as resolution and FPS in the recording schedule, because the recorder may reject a camera after a firmware/settings mismatch [#17048620] It is also worth testing a different, simpler login/password combination, especially one without special characters and with a different length, because the recorder reports a login/password error when adding the camera [#17049729] The thread also points to possible incompatibility between the problematic Overmax camera and the Camspot 2.1 recorder, since the other cameras work, the bad camera uses different firmware/model, and the issue persisted even after factory resets and changing routers [#17049729][#17103981] In the recorder UI, a successful add should turn the icon green, but the failing camera turns red instead, which reinforces that the recorder is rejecting that camera during pairing [#17080370]
  • #1 16886094
    16czarny16
    Rate: 141
    Hello, I have the following problem.
    I have two cameras from Overmax Camspot 4.5 and 3.2 and two similar ones, only bought in China, but identical for me and the Overmax Camspot 2.1 recorder.
    The problem is that I have all the cameras connected to the router, I can see all four and the image of them on my computer. I also have a program on my phone and I can see all four cameras, while on the recorder I can see four, but three work flawlessly and there is an image from them and the fourth is detected but after entering the password I cannot get the image from it. Only IP and error are displayed.
    Please, could someone guide me what is wrong.
    I will add that the fourth camera with which I have a problem on the recorder is also from Overmax.
  • #2 16886271
    dawidedziu
    Industrial cameras specialist
    Help: 500
    Rate: 642
    Firmware have the same cameras? What are these models? Have you tried factory settings?
  • #3 16886500
    16czarny16
    Rate: 141
    These are Camspot 4.5 and 3.2 cameras and two Chinese such as 4.5. The problem is that these no name Chinese work without a problem, and the only problem is with this Overmax. I tried factory settings. I forgot to add that the settings of these cameras are identical on the computer, so I have no idea where the problem is. I only have IP, but I don't know how to figure it out.
  • #4 17048103
    16czarny16
    Rate: 141
    Can I see no help? I just don't know if it's a question of a problem or not the company's equipment.
  • #5 17048620
    dawidedziu
    Help: 500
    Rate: 642
    Try to upload the newer firmware to the recorder and cameras. But first, check if anything changes if you change the settings in the recording schedule, regarding resolution, number of frames per second, etc.
  • #6 17049145
    16czarny16
    Rate: 141
    This is the case. I had three cameras, I bought a recorder and everything was flickering. I bought the fourth one and after connecting it was ok. After a few days this one camera disappeared from the recorder vision. Two days later she returned. It was ok for a month and now she's gone and hasn't come back in a month or two. I have already done factory resets of cameras, recorder and router. Nothing helped. I changed the number of frames, the resolution and the same. The recorder sees the camera but there is an error. In the details there is a description that the password or login error is impossible.
  • #7 17049729
    dawidedziu
    Help: 500
    Rate: 642
    Well, have you tried to figure out something with a different login / password? Different length of this password, any special characters? What about the camera firmware? They have the same models?
  • #8 17050045
    16czarny16
    Rate: 141
    Buddy, you would have been with the slogan, too, and so on. Yesterday I came back from work and the image from the fourth camera is displayed ? and how should I understand it ??? I wonder how long.
    As for the firmware, there are different models and different firmware.
  • #9 17054894
    16czarny16
    Rate: 141
    And yesterday at 7:00 p.m. the picture disappeared again for some unknown reason and it is not there to this day. It reappeared and disappeared by itself. I will add that when it was, it was fluid, of good quality, without hanging etc.
    Do you have any ideas because I've already lost all of them.
    I would like to add that all cameras are added to the same router, which is connected to the recorder by a cable.
    Neither camera has an automatic restart and neither does the recorder.
    On the computer and phone, the image is smooth and everything is fine.
    I was combining with the number of frames, resolution, etc.
  • #10 17079073
    wppk
    And the cameras are connected by cable or via wi-fi?
  • #11 17079326
    16czarny16
    Rate: 141
    All after WiFi, and this particular problem can be anyway. In both cases, it does not work on the recorder.
  • #12 17079483
    wppk
    I had a similar problem, but the solution was to connect a more efficient router. The problem is that the price of such equipment, e.g. 4G-AC68U Link is prohibitive.
    I recorded on a laptop or smartphone.
    I launched Camspot 2.1 yesterday but I forgot the password (I changed the factory one) and removing the battery only reset the clock :shii:
    Added after 2 [hours] 16 [minutes]:
    I forgot to add that the disk might still be a problem. The disk should be special for archiving, eg Seagate from the "SkyHawk" family.
  • #13 17080370
    16czarny16
    Rate: 141
    The disk is falling off and the router is in my opinion too. Why? I'm already writing.
    Even when I remove all cameras from the router, recorder, disconnect them from the network and electricity and leave only this one, I still do not want to communicate with it.
    You have Camspot 2.1, you know how it works.
    You go into the search for cameras, they pop up found with a blue plus.
    You press plus ? and they pop out with the white key. As you enter the password, it changes to a green circle and you can see the preview from the camera.
    For me, it looks like this with three, and the fourth one, after pressing the plus, pops up a red circle instead of the key.
    You know what the problem is now.
  • #14 17103981
    16czarny16
    Rate: 141
    Yesterday, the topic went deeper and focused only on the camera-recorder connection.
    I exclude the router because yesterday I replaced Funbox 2.0 with the super-efficient Tp-Link VR600 and the problem is still the same.
    It searches for a camera, but when you try to add it, there is already a problem.
    However, on the phone and computers unchanged. The picture is fluid and awesome.
The discussion revolves around connectivity issues with Overmax Camspot 4.5 and 3.2 Wi-Fi cameras when used with the Overmax Camspot 2.1 recorder. The user reports that while all cameras are visible and functional on their computer and mobile app, one camera fails to display an image on the recorder, showing only an IP error after entering the password. Various troubleshooting steps have been attempted, including factory resets, firmware updates, and adjustments to recording settings, but the issue persists. The user has also replaced their router, yet the problem remains unresolved. Suggestions include checking login credentials, ensuring firmware compatibility, and considering the quality of the router and storage device used for recording.
TL;DR: 1 camera out of 4 is detected but shows a login error; “The recorder sees the camera but there is an error.” [Elektroda, 16czarny16, post #17049145]
Why it matters:** This FAQ helps Camspot 2.1 users fix Wi‑Fi IP cameras that appear in the NVR list but won’t show video.
Why does my Camspot 2.1 show IP but no image for one camera?
The recorder discovers the camera but rejects authentication. The NVR then flags a login/password error and blocks the preview. This can happen even if the same camera streams fine to your phone or PC. In the thread, three streams worked and one failed on the NVR only. That indicates an NVR–camera auth or compatibility issue rather than basic connectivity. [Elektroda, 16czarny16, post #17049145]
How do I fix the “password or login error” on Camspot 2.1?
Standardize credentials and retry. Use a short alphanumeric password (no special characters), then re‑add the camera. If it succeeds, lengthen gradually. If it fails, update firmware on both NVR and camera, then test again. A helper advises: “Try to upload the newer firmware … change … resolution, number of frames per second.” [Elektroda, dawidedziu, post #17048620]
Does Wi‑Fi vs Ethernet change this symptom?
The issue persisted over Wi‑Fi, and the camera still streamed perfectly to phone and PC. That points away from RF coverage and toward NVR‑side auth/protocol handling. You can still test by wiring the camera or relocating the AP, but the thread’s failure remained NVR‑specific. [Elektroda, 16czarny16, post #17079326]
Could a router upgrade fix the no‑image problem?
A faster router can help stability, but it’s not a guaranteed cure. In the case discussed, replacing Funbox 2.0 with a TP‑Link VR600 changed nothing for NVR preview, while mobile/PC streams stayed smooth. That isolates the fault to NVR‑camera interaction. [Elektroda, 16czarny16, post #17103981]
How do I add a Camspot camera to the 2.1 recorder?
  1. Run camera search on the NVR and wait for devices with a blue plus.
  2. Tap the blue plus; a white key appears to enter the camera password.
  3. Enter credentials; a green circle confirms success. If you see a red circle, auth failed. [Elektroda, 16czarny16, post #17080370]
Why did the camera come back for a day and then vanish again?
Intermittent auth or session handling can pass once and fail later. In the thread, the camera returned after days, worked smoothly, then disappeared again around 19:00. No auto‑restarts were set on camera or NVR. That behavior flags unstable NVR authentication or firmware bugs. [Elektroda, 16czarny16, post #17054894]
Do mismatched firmware versions between cameras and NVR matter?
Yes. Different models and firmware builds can negotiate ONVIF/RTSP differently, producing discovery without video. Update the NVR and the affected camera first. As one helper put it, “Try to upload the newer firmware.” Then retest with simple credentials. [Elektroda, dawidedziu, post #17048620]
What recording settings should I change first?
Lower the camera’s resolution and frames per second from the NVR profile, then re‑add the camera. This reduces stream bandwidth and decoder load during auth/handshake. The helper specifically named resolution and FPS as knobs worth adjusting during troubleshooting. [Elektroda, dawidedziu, post #17048620]
Could the hard drive cause a missing live preview?
A marginal drive can disrupt recording and sometimes UI responsiveness. One member suggested using surveillance‑class disks such as Seagate SkyHawk. While storage issues usually affect recording, ruling them out removes a variable during live‑view debugging. [Elektroda, wppk, post #17079483]
I reset the camera, NVR, and router—still no preview. What next?
Confirm the camera works on phone/PC, then focus on the NVR. Recreate the device on the NVR with a simple password and reduced FPS. If that fails, update firmware and test with the problematic camera as the only device. This isolated test reproduced the failure in the thread. [Elektroda, 16czarny16, post #17080370]
Is this an Overmax‑only issue? My no‑name clones work.
In the report, two no‑name 4.5‑like cameras worked, while an Overmax unit failed on the NVR. That points to per‑model firmware differences, not brand quality overall. Treat it as a compatibility edge case between that camera build and Camspot 2.1. [Elektroda, 16czarny16, post #16886500]
What password rules avoid NVR compatibility pitfalls?
Use 8–12 characters with only letters and numbers to start. Avoid spaces and symbols until the camera authenticates reliably. If it works, extend length incrementally. A helper specifically advised experimenting with different login/password lengths and characters. [Elektroda, dawidedziu, post #17049729]
Any quick benchmark from this case to gauge severity?
Failure affected 1 of 4 streams (25%), while all four streamed to phone and PC. That contrast indicates NVR‑specific failure rather than network collapse. Treat it as an authentication/firmware compatibility defect first. [Elektroda, 16czarny16, post #16886094]
Expert checklist: what should I try in order?
Quote: “Try to upload the newer firmware… change … resolution, number of frames per second.” Then simplify password, re‑add the camera, and isolate the test with only the failing unit connected. This sequence matched the most actionable advice in the thread. [Elektroda, dawidedziu, post #17048620]
What’s an edge case to watch for during testing?
Live view can return randomly and vanish again hours later, even with smooth video when present. In the case, the image reappeared, worked flawlessly, then disappeared by itself the same evening. Document timestamps to correlate with changes. [Elektroda, 16czarny16, post #17054894]
